Home » Eclipse Projects » GEF » Vertical Text (Again)
Vertical Text (Again) [message #217075] |
Wed, 31 May 2006 18:02  |
I was wondering if ImageUtilities.createRotatedImageOfString() works on
Mac OSX (specifically the new Intel Macs). I'm trying to achieve some
vertical text with the following code:
public void validate() {
Dimension dim = FigureUtilities.getTextExtents(
text, JFaceResources.getDefaultFont());
dim.transpose();
setPreferredSize(dim);
protected void paintFigure(final Graphics graphics) {
Image foo = ImageUtilities.createRotatedImageOfString(
text, JFaceResources.getDefaultFont(),
ColorConstants.black, ColorConstants.blue);
graphics.drawImage(foo, bounds.getTopLeft());
foo.dispose();
When I run the code, the figure takes up the appropriate amount of space
(when I put a really long string in, I get a really tall figure, when I
put a short string in, a short figure). However, I get no text and no
background fill. I don't have a Windows box, so I can't really test if
it is a Mac-only thing.
Since this doesn't work, can someone suggest an alternate approach?
Josh
Re: Vertical Text (Again) [message #217281 is a reply to message #217075] |
Fri, 02 June 2006 09:26   |
Can you log a bugzilla and it can get investigated?
Alternatively, you can try to set a rotation value in your paint routine
using the Graphics#rotate method.
i.e.
graphics.push();
graphics.setFont(JFaceResources.getDefaultFont());
graphics.rotate(90.0);
graphics.drawText(text);
graphics.pop();
-Steve
"Joshua Reed" <jareed@iastate.edu> wrote in message
news:e5l3pj$g0l$1@utils.eclipse.org...
> dim.transpose();
> foo.dispose();
> Josh
Re: Vertical Text (Again) [message #217306 is a reply to message #217281] |
Fri, 02 June 2006 10:53   |
Thanks for the reply Steven.
Turns out I hadn't put a StackLayout on the containing figure so while
container's size was reflecting the size of the rotated label, the
actual label figure wasn't getting laid out. So when I was doing a
graphics.drawText("Some Rotated Text", bounds.getTopLeft())
nothing showed up because I was drawing somewhere off in wonkyland. I
discovered this quite by accident when I was working up a code snippet
to submit as a bug. It's all working once I set the layout manager or do a
getParent().getClientArea().getTopLeft())
I can't get he snippet you sent to work on Mac OSX for rotation values
other than 0.0f (and I've got my layout manager set this time :) ). I
can file a bug report with an example if it would be helpful.
Josh Reed
> i.e.
> graphics.push();
> graphics.pop();
> -Steve
>> dim.transpose();
>> foo.dispose();
>> Thanks,
>> Josh
Re: Vertical Text (Again) [message #217314 is a reply to message #217306] |
Fri, 02 June 2006 12:01   |
Just, the GEF palette is using the same method you are calling. So, if the
palette is working, there is no bug.
news:e5pjdk$1ob$1@utils.eclipse.org...
> container's size was reflecting the size of the rotated label, the actual
> discovered this quite by accident when I was working up a code snippet to
> other than 0.0f (and I've got my layout manager set this time :) ). I can
> Josh Reed
>> i.e.
>> graphics.push();
>> graphics.pop();
>> -Steve
>>> dim.transpose();
>>> foo.dispose();
>>> Thanks,
>>> Josh
Re: Vertical Text (Again) [message #217329 is a reply to message #217314] |
Fri, 02 June 2006 14:14  |
Which one?
The ImageUtilities.createRotatedImageOfString() or the Graphics.rotate()
one?
Josh
>> Thanks,
>> Josh Reed
>>> i.e.
>>> graphics.push();
>>> graphics.pop();
>>> -Steve
>>>> dim.transpose();
>>>> foo.dispose();
>>>> Thanks,
>>>> Josh
Current Time: Fri Jul 25 11:08:19 EDT 2025
Powered by FUDForum. Page generated in 0.06392 seconds
