Home » Modeling » GMF (Graphical Modeling Framework) » Problem creating link from derived class
Problem creating link from derived class [message #217253] Wed, 04 February 2009 10:09 Go to next message
I want to create a link between nodes.
The ecore model is like this:
the nodes: Class A
a link: Class B
another link Class BA -> Class B
I can create a link with class B but not with class BA. When I draw the connection with class BA
than I get the following exception:
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:399)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:411)
at
org.eclipse.gmf.runtime.diagram.ui.tools.ConnectionCreationT ool.handleCreateConnection(ConnectionCreationTool.java:341)
at
org.eclipse.gmf.runtime.diagram.ui.tools.ConnectionCreationT ool.handleButtonUp(ConnectionCreationTool.java:181)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1064)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:263)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:538)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:207)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:failed to create a view
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.gmf.runtime.diagram.ui.commands.CreateCommand.do ExecuteWithResult(CreateCommand.java:99)
at
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:169)
at
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:403)
at org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:135)
at
at
at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
.... 37 more
I debug a bit and found that for Class BA is no ViewProvider registered but it is for class B. I
have no idea where I could register this ViewProvider.
Does any one know how to solve the problem?
Thanks, Martin
Re: Problem creating link from derived class [message #217269 is a reply to message #217253] Wed, 04 February 2009 11:03 Go to previous messageGo to next message
in addition to the information below I found that the EditPart for class B is used when generating a
diagram from a the model. But for my understanding it should be EditPart for class BA.
Any idea how to solve the problem?
Martin
Martin Jacob wrote, On 04.02.2009 16:09:
> the nodes: Class A
> a link: Class B
> connection with class BA than I get the following exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .... 37 more
> but it is for class B. I have no idea where I could register this
> ViewProvider.
> Thanks, Martin
Re: Problem creating link from derived class [message #217277 is a reply to message #217269] Wed, 04 February 2009 11:37 Go to previous messageGo to next message
hi martin,
could you please post your .gmfgraph and .gmfmap files (just the relevant
portion) so we can reproduce your problem? its way easier than just
textual description...
cheers
christian
Re: Problem creating link from derived class [message #217294 is a reply to message #217277] Wed, 04 February 2009 11:51 Go to previous messageGo to next message
Hi Christian,
please find below .gmfmap and gmfgraph
Please note the class names are different than described before. The class Isolator is derived from
class Conductor.
..gmfmap:
<links>
<domainMetaElement
href="psc.ecore#//Conductor"/>
<labelMappings
xsi:type="gmfmap:FeatureLabelMapping"
editorPattern=""
editPattern="">
<diagramLabel
href="psc.gmfgraph#ConductorNameLable"/>
<features
href="psc.ecore#//Conductor/name"/>
</labelMappings>
<containmentFeature
href="psc.ecore#//Network/conductors"/>
<tool
xsi:type="gmftool:CreationTool"
href="psc.gmftool#//@palette/@tools.0/@tools.2"/>
<diagramLink
href="psc.gmfgraph#Conductor"/>
<sourceMetaFeature
xsi:type="ecore:EReference"
href="psc.ecore#//Conductor/nodeFrom"/>
<linkMetaFeature
href="psc.ecore#//Conductor/nodeTo"/>
</links>
<links>
<domainMetaElement
href="psc.ecore#//Isolator"/>
<labelMappings
editorPattern=""
editPattern="">
<diagramLabel
href="psc.gmfgraph#IsolatorNameLable"/>
<features
</labelMappings>
<containmentFeature
<tool
href="psc.gmftool#//@palette/@tools.0/@tools.4"/>
<diagramLink
href="psc.gmfgraph#Isolator"/>
<sourceMetaFeature
<linkMetaFeature
</links>
..gmfgraph:
<gmfgraph:Canvas xmi:version="2.0"
xmlns:gmfgraph="http://www.eclipse.org/gmf/2006/GraphicalDefinition" name="psc">
<figures
name="Default">
<descriptors
name="NodeFigure">
<actualFigure
xsi:type="gmfgraph:Rectangle"
name="NodeFigure"
lineWidth="2">
<layout
xsi:type="gmfgraph:FlowLayout"/>
<foregroundColor
xsi:type="gmfgraph:ConstantColor"
value="black"/>
<backgroundColor
value="lightGreen"/>
<children
xsi:type="gmfgraph:Label"
name="NodeIDLable"/>
</actualFigure>
<accessors
figure="//@figures.0/@descriptors.0/@actualFigure/@children.0 "/>
</descriptors>
<descriptors
name="ConductorFigure">
<actualFigure
xsi:type="gmfgraph:PolylineConnection"
lineWidth="4">
<foregroundColor
value="black"/>
<children
name="ConductorNameFigure"
text="&lt;...>"/>
</actualFigure>
<accessors
figure="//@figures.0/@descriptors.2/@actualFigure/@children.0 "/>
</descriptors>
<descriptors
name="IsolatorFigure">
<actualFigure
lineWidth="8">
<foregroundColor
value="black"/>
<children
name="IsolatorNameFigure"
text="&lt;...>"/>
</actualFigure>
<accessors
figure="//@figures.0/@descriptors.3/@actualFigure/@children.0 "/>
</descriptors>
</figures>
<nodes
name="Node"
figure="NodeFigure"/>
<connections
name="Conductor"
figure="ConductorFigure"/>
<connections
name="Isolator"
figure="IsolatorFigure"/>
<labels
name="NodeIDLable"
figure="NodeFigure"
elementIcon="false"
accessor="//@figures.0/@descriptors.0/@accessors.0"/>
<labels
name="ConductorNameLable"
elementIcon="false"
accessor="//@figures.0/@descriptors.2/@accessors.0"/>
<labels
name="IsolatorNameLable"
elementIcon="false"
accessor="//@figures.0/@descriptors.3/@accessors.0"/>
</gmfgraph:Canvas>
If you need more details please let me know.
thanks, Martin
Christian Muth wrote, On 04.02.2009 17:37:
> hi martin,
> relevant portion) so we can reproduce your problem? its way easier than
> just textual description...
> cheers
> christian
Re: Problem creating link from derived class [message #217341 is a reply to message #217294] Thu, 05 February 2009 05:51 Go to previous messageGo to next message
hi martin,
please also post your .ecore file, i don't understand the domain model
structure regarding Isolator and Conductor....
thanks
christian
Re: Problem creating link from derived class [message #217350 is a reply to message #217341] Thu, 05 February 2009 06:16 Go to previous messageGo to next message
Hi Christian,
here the .ecore file.
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="model"
nsURI="http://www.bahntechnik.de/opn/psc/prj" nsPrefix="de.bahntechnik.dd.opn.psc.prj">
<eAnnotations source="EAnnotation0"/>
<eClassifiers xsi:type="ecore:EClass" name="PSC">
<eStructuralFeatures xsi:type="ecore:EReference" name="networks" upperBound="-1"
eType="#//Network" containment="true" eOpposite="#//Network/psc"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Network">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="psc" eType="#//PSC"
eOpposite="#//PSC/networks"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="lines" upperBound="-1"
eType="#//Line" containment="true" eOpposite="#//Line/network"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="slices" upperBound="-1"
eType="#//Slice" containment="true" eOpposite="#//Slice/network"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="conductors" upperBound="-1"
eType="#//Conductor" containment="true" eOpposite="#//Conductor/network"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="tracks" upperBound="-1"
eType="#//Track" containment="true" eOpposite="#//Track/network"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nodes" upperBound="-1"
eType="#//Node" containment="true" eOpposite="#//Node/network"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="connectors" upperBound="-1"
eType="#//Connector" containment="true" eOpposite="#//Connector/network"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Line">
<eStructuralFeatures xsi:type="ecore:EReference" name="network" eType="#//Network"
eOpposite="#//Network/lines"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="firstSlice" eType="#//Slice"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="slices" ordered="false"
upperBound="-1" eType="#//Slice" eOpposite="#//Slice/line"/>
eType="#//Track" eOpposite="#//Track/lines"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Slice">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pos_m" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="line" eType="#//Line"
eOpposite="#//Line/slices"/>
eOpposite="#//Network/slices"/>
eType="#//Node" eOpposite="#//Node/slice"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nextSlice" eType="#//Slice"
eOpposite="#//Slice/prevSlice"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="prevSlice" eType="#//Slice"
eOpposite="#//Slice/nextSlice"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Track">
eOpposite="#//Network/tracks"/>
eType="#//Conductor" eOpposite="#//Conductor/track"/>
eType="#//Line" eOpposite="#//Line/tracks"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Conductor">
<eStructuralFeatures xsi:type="ecore:EReference" name="track" eType="#//Track"
eOpposite="#//Track/conductors"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nodeTo" eType="#//Node"
eOpposite="#//Node/nextCond"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nodeFrom" eType="#//Node"
eOpposite="#//Node/prevCond"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="line" eType="#//Line"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" eType="#//ConductorType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="x_m" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EDouble"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="y_m" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="equivalentRadius_mm"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDouble"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="r20_Ohm_km" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="temperatureCoefficient"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="temperature_GradCelsius"
eOpposite="#//Network/conductors"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="ConductorType">
<eLiterals name="ContactWire"/>
<eLiterals name="Earth" value="1"/>
<eLiterals name="MessangerWire" value="2"/>
<eLiterals name="NegativeFeeder" value="3"/>
<eLiterals name="Rail" value="4"/>
<eLiterals name="ReinforcementFeeder" value="5"/>
<eLiterals name="ReinforcementReturnFeeder" value="6"/>
<eLiterals name="unknown" value="7"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Node">
eOpposite="#//Network/nodes"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nextCond" eType="#//Conductor"
eOpposite="#//Conductor/nodeTo"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="prevCond" eType="#//Conductor"
eOpposite="#//Conductor/nodeFrom"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="slice" eType="#//Slice"
eOpposite="#//Slice/nodes"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="prevConns" upperBound="-1"
eType="#//Connector" eOpposite="#//Connector/nodeFrom"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="nextConns" upperBound="-1"
eType="#//Connector" eOpposite="#//Connector/nodeTo"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nodeID" eType="ecore:EDataType
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Connector">
eOpposite="#//Node/prevConns"/>
eOpposite="#//Node/nextConns"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="r_Ohm" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="x_Ohm" eType="ecore:EDataType
eOpposite="#//Network/connectors"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Isolator" eSuperTypes="#//Conductor"/>
<eClassifiers xsi:type="ecore:EClass" name="Switch" eSuperTypes="#//Conductor"/>
</ecore:EPackage>
thanks, Martin
Christian Muth wrote, On 05.02.2009 11:51:
> hi martin,
> thanks
> christian
Re: Problem creating link from derived class [message #217367 is a reply to message #217294] Thu, 05 February 2009 07:35 Go to previous messageGo to next message
Hi Martin,
your problem might be that you do not have a node mapping (top node
reference) for Isolator, but only for Conductors.
Though Isolator is a specialized Conductor, you have to give it its own
node mapping (second top node reference for Network->conductors, node
mapping inside with domain meta element Isolator and diagram node Node)
for being able to use it with links.
Cheers
Christian
Re: Problem creating link from derived class [message #217374 is a reply to message #217367] Thu, 05 February 2009 08:25 Go to previous message
Hi Christian,
actually Isolator shall be a connection and not a node. I try what u proposed but than I got a node
instead of a connection.
Please find below my complete .gmfmap file. Do you have any other suggestion?
<gmfmap:Mapping xmi:version="2.0"
xmlns:gmfmap="http://www.eclipse.org/gmf/2008/mappings"
xmlns:gmftool="http://www.eclipse.org/gmf/2005/ToolDefinition">
<nodes>
<containmentFeature
href="psc.ecore#//Network/nodes"/>
<ownedChild>
<domainMetaElement
href="psc.ecore#//Node"/>
<labelMappings
readOnly="true"
viewPattern="{0}"
editorPattern=""
editPattern="">
<diagramLabel
href="psc.gmfgraph#NodeIDLable"/>
<features
href="psc.ecore#//Node/nodeID"/>
</labelMappings>
<tool
href="psc.gmftool#//@palette/@tools.0/@tools.0"/>
<diagramNode
href="psc.gmfgraph#Node"/>
</ownedChild>
</nodes>
<links>
<domainMetaElement
<labelMappings
editorPattern=""
editPattern="">
<diagramLabel
<features
</labelMappings>
<containmentFeature
<tool
<diagramLink
<sourceMetaFeature
<linkMetaFeature
</links>
<links>
<domainMetaElement
href="psc.ecore#//Connector"/>
<labelMappings
viewPattern="{0}+{1}j"
editorPattern="{0}+{1}"
editPattern="{0}+{1}">
<diagramLabel
href="psc.gmfgraph#Connector_X_OhmLable"/>
<features
href="psc.ecore#//Connector/r_Ohm"/>
<features
href="psc.ecore#//Connector/x_Ohm"/>
</labelMappings>
<containmentFeature
href="psc.ecore#//Network/connectors"/>
<tool
href="psc.gmftool#//@palette/@tools.0/@tools.3"/>
<diagramLink
href="psc.gmfgraph#Connection"/>
<sourceMetaFeature
href="psc.ecore#//Connector/nodeFrom"/>
<linkMetaFeature
href="psc.ecore#//Connector/nodeTo"/>
</links>
<links>
<domainMetaElement
<labelMappings
editorPattern=""
editPattern="">
<diagramLabel
<features
</labelMappings>
<containmentFeature
<tool
<diagramLink
<sourceMetaFeature
<linkMetaFeature
</links>
<diagram>
<diagramCanvas
href="psc.gmfgraph#psc"/>
<domainModel
href="psc.ecore#/"/>
<domainMetaElement
href="psc.ecore#//Network"/>
<palette
href="psc.gmftool#//@palette"/>
</diagram>
</gmfmap:Mapping>
Christian Muth wrote, On 05.02.2009 13:35:
> Hi Martin,
> Cheers
> Christian
Previous Topic:Set attributes when a link is deleted
Next Topic:Changing a label to a dropdown menu
Current Time: Sun Jul 20 20:25:04 EDT 2025
Powered by FUDForum. Page generated in 0.26020 seconds
