Home » Newcomers » Newcomers » Goober question: no updates work because of dependency failures
Goober question: no updates work because of dependency failures [message #217222] Thu, 21 June 2007 11:46 Go to next message
Originally posted by: msweetnam.gmail.com
Ok.. here's a noob question (I've reinstalled both the eclipse app and all
the listed prereq's for WPD):
When I try to either update or install new plugins via the wizard I get
some version of the following:
The current configuration contains errors and this operation can have
unpredictable results.
WST Server Adapters (2.0.0.v200706041905-4--_kE77Y7QI7EEEQ) requires
plug-in "org.apache.commons.logging (1.0.4)", or compatible.
BIRT Reporting for TPTP Feature (4.2.0.v200606131519--1G955G5G7A7E7M)
requires plug-in "org.eclipse.birt.core".
Eclipse Modeling Framework (EMF) Extender SDK (2.3.0.v200706130003)
requires feature "org.eclipse.platform (3.3.0.v20061208-Fj22sCYGm0XDWm3)",
or compatible.
XML Schema Infoset Model (XSD) Extender SDK (2.3.0.v200706130003) requires
feature "org.eclipse.emf (2.3.0)", or compatible.
WTP Web Page Editor (1.0.0.v200706110802-3--9oA55P5M78) requires plug-in
"org.eclipse.jst.jsf.common.ui (1.0.0)", or equivalent.
EMF Service Data Objects (SDO) Extender SDK (2.3.0.v200706130003) requires
Is this just an installation error?
How do I satisfy these dependencies?
Where to get the plugins?
I can't find any doc or links that talk about dealing with problems with
the install wizard (they all seem to assume that it works everytime)
Any insight would be appreciated!
Matt
Re: Goober question: no updates work because of dependency failures [message #217398 is a reply to message #217222] Fri, 22 June 2007 09:31 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
> all the listed prereq's for WPD):
[snip]
> How do I satisfy these dependencies? Where to get the plugins?
In the Update Manager GUI where you select the plugins you want, there
is a button labeled "Select Required" that will automatically select the
prereqs for whatever you have selected.
Hope this helps,
Eric
Previous Topic:Reading files within workspace
Next Topic:How to change the color of the variable locations when I highlight it?
Current Time: Sun Jul 27 05:36:57 EDT 2025
Powered by FUDForum. Page generated in 0.56782 seconds
