Home » Archived » BIRT » JDBC vs JNDI
JDBC vs JNDI [message #216713] Fri, 02 February 2007 11:18 Go to next message
I want to be able to preview same report in Designer
and (render it) in application server. How can I achieve
such effect? I use JDBC properties in the Designer,
but I will have to use JNDI string in appserver. How will
it work, if both settings (JNDI, JDBC) are specified?
Do you have best practices / tips?
Thank you
Leos
Re: JDBC vs JNDI [message #216723 is a reply to message #216713] Fri, 02 February 2007 11:44 Go to previous messageGo to next message
The JNDI connection will be attempted first.
If it fails the JDBC connection will be used.
Jason
"Leos Literak" <literakl@centrum.cz> wrote in message
news:epvo9d$ocj$1@utils.eclipse.org...
> Thank you
> Leos
Re: JDBC vs JNDI [message #217031 is a reply to message #216723] Tue, 06 February 2007 02:55 Go to previous messageGo to next message
Thanks Jason, it really works this way. Unfortunatelly
I have not found this information when searching BIRT web
or in the designer. So I written small FAQ entry:
http://wiki.eclipse.org/index.php/BIRT/FAQ/Data_Access#Suppo rted_Data_Sources
Could you please review it, I am not native speaker.
Leos
Jason Weathersby napsal(a):
> Jason
>> Hi,
>> Thank you
>> Leos
Re: JDBC vs JNDI [message #217120 is a reply to message #217031] Tue, 06 February 2007 11:07 Go to previous message
Leos,
Thanks for posting this. I will talk with the developers to review.
Jason
news:eq9ca6$si4$1@utils.eclipse.org...
> Leos
>> Jason
>>> Hi,
>>> Thank you
>>> Leos
Previous Topic:Bet No one has an Answer
Next Topic:BIRT + RCP + Spring + Hibernate - classpath? problems
Current Time: Wed Nov 05 13:36:07 EST 2025
Powered by FUDForum. Page generated in 0.04407 seconds
