Home » Eclipse Projects » GEF » CompoundDirectedGraphLayout creates Edge that shoots out to the side
CompoundDirectedGraphLayout creates Edge that shoots out to the side [message #216638] |
Mon, 22 May 2006 20:29  |
Hi All,
The following code which uses CompoundDirectedGraphLayout produces the
layout captured in the attached Compound.png. As you can see one of the
Edges inappropriately shoots out to the side.
This equivalent graph when laid out using DirectedGraphLayout does not have
this problem (e.g., see the attached "Not Compound.png" and the code that
produced it included below).
Am I doing anything wrong here? I'm using 3.2M5a.
Thanks for any help,
Rick
NodeList nodes = new NodeList();
EdgeList edges = new EdgeList();
Subgraph p = new Subgraph("parent");
nodes.add(p);
Node a = new Node("a", p);
nodes.add(a);
Node b = new Node("b", p);
nodes.add(b);
Node c = new Node("c", p);
nodes.add(c);
Node d = new Node("d", p);
nodes.add(d);
Node e = new Node("e", p);
nodes.add(e);
edges.add(new Edge(a, d));
edges.add(new Edge(a, c));
edges.add(new Edge(b, c));
edges.add(new Edge(b, d));
edges.add(new Edge(b, e));
edges.add(new Edge(c, d));
edges.add(new Edge(c, e));
CompoundDirectedGraph graph = new CompoundDirectedGraph();
graph.nodes = nodes;
graph.edges = edges;
new CompoundDirectedGraphLayout().visit(graph);
non-compound version:
Node a = new Node("a");
nodes.add(a);
Node b = new Node("b");
nodes.add(b);
Node c = new Node("c");
nodes.add(c);
Node d = new Node("d");
nodes.add(d);
Node e = new Node("e");
nodes.add(e);
DirectedGraph graph = new DirectedGraph();
new DirectedGraphLayout().visit(graph);
Re: CompoundDirectedGraphLayout creates Edge that shoots out to the side [message #216704 is a reply to message #216638] |
Tue, 23 May 2006 13:40  |
Please test using the latest release candidate, then open a bugzilla if it
is still reproducible.
"richbk" <richbk@hotmail.com> wrote in message
news:e4tl11$tdk$1@utils.eclipse.org...
> Hi All,
> have this problem (e.g., see the attached "Not Compound.png" and the code
> that produced it included below).
> Rick
> nodes.add(p);
> nodes.add(a);
> nodes.add(b);
> nodes.add(c);
> nodes.add(d);
> nodes.add(e);
> nodes.add(a);
> nodes.add(b);
> nodes.add(c);
> nodes.add(d);
> nodes.add(e);
Current Time: Thu Sep 18 14:17:48 EDT 2025
Powered by FUDForum. Page generated in 0.04191 seconds
