Home » Modeling » GMF (Graphical Modeling Framework) » Custom property editor for EDataTypes
Custom property editor for EDataTypes [message #216543] |
Wed, 28 January 2009 01:02  |
I am trying to create a custom property editor for a model element with
a property of EDataType - a file reference, which is also serializible
according to EMF.
After much searching I found
http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg10837.html
which describes how to add a custom property editor to a field, which
works well. It adds a '...' to the CellEditor of the property cell,
which when clicked, can be edited with a dialog box (in my case, a
FileDialog).
However, the result returned is not saved anywhere. Once the FileDialog
is closed, the filename is displayed in the cell field, but it is not
saved back to the original model object/property. If I select away from
the model element and reselect it, the value is reset to its previous
value. The diagram file is not marked as dirty.
My code is almost identical to the code in the thread above; am I
missing a setValue() somewhere, or something similar? I thought that the
result from the ExtendedDialogCellEditor would be used to set the property.
I also tried extending createEDataTypeCellEditor(EDataType, Composite)
with the same approach, but got the same result.
I tried setting the value manually, i.e. ((MyObject) object).setFile(new
FileReference(filename));, but this throws a "Cannot modify resource set
without a write transaction".
It appears that while the approach above would work for normal property
values (e.g. EStrings), it isn't working for EDataTypes.
Any ideas? Is there something special I should be doing in order to
handle custom EDataType property editors? Or should I just ignore
EDataTypes in EMF and change my property type to EString?
Thanks!
Jevon
Re: Custom property editor for EDataTypes [message #216620 is a reply to message #216543] |
Wed, 28 January 2009 20:21  |
After more debugging and referring to the EMF source, I found a
solution: The Object returned by the openDialogBox() method needs to
first be passed through a EDataTypeValueHandler, and likewise,
retrieving results must also be passed through this handler.
That is:
protected class CustomizedPropertyDescriptor extends PropertyDescriptor {
public CustomizedPropertyDescriptor(Object object,
IItemPropertyDescriptor itemPropertyDescriptor) {
super(object, itemPropertyDescriptor);
public CellEditor createPropertyEditor(Composite composite) {
EClassifier eType = ((EStructuralFeature) itemPropertyDescriptor
.getFeature(object)).getEType();
final EDataType dataType = (EDataType) eType;
if (dataType.equals(DomainPackage.eINSTANCE.getFileReference()) ) {
CellEditor result = new ExtendedDialogCellEditor(composite,
getEditLabelProvider()) {
// based on
org.eclipse.emf.edit.ui.provider.PropertyDescriptor.createED ataTypeCellEditor(EDataType
eDataType, Composite composite)
protected EDataTypeValueHandler valueHandler = new
EDataTypeValueHandler(
dataType);
protected Object openDialogBox(Control cellEditorWindow) {
Shell shell = PlatformUI.getWorkbench().getDisplay()
.getActiveShell();
FileDialog dialog = new FileDialog(shell, SWT.OPEN);
dialog.setFileName(valueHandler.toString(getValue()));
String fileSelected = dialog.open();
if (fileSelected == null) {
return getValue();
return valueHandler.toValue(fileSelected);
return result;
return super.createPropertyEditor(composite);
Hope this helps someone else out!
Cheers
Jevon
Jevon Wright wrote:
> according to EMF.
> FileDialog).
> Thanks!
> Jevon
Current Time: Sat Jul 19 00:09:51 EDT 2025
Powered by FUDForum. Page generated in 0.04223 seconds
