Home » Language IDEs » ServerTools (WTP) » JSDT not parsing alternative fn syntax
JSDT not parsing alternative fn syntax [message #216339] Sun, 29 June 2008 00:30 Go to next message
I just installed Eclipse Ganymede with WTP 3.0. The JSDT module for
JavaScript editing seems to be coming along nicely. However, it doesn't
seem to recognize functions defined using the following syntax:
alertHello = function() {
alert('hello');
It has no trouble parsing
function alertHello() {
alert('hello');
The former syntax is useful for defining method on objects, so this seems
to be an important missing feature.
Or am I missing some configuration trick?
Chris
Re: JSDT not parsing alternative fn syntax [message #216400 is a reply to message #216339] Mon, 30 June 2008 14:09 Go to previous messageGo to next message
JSDT does recognize this syntax. See the attached screenshot-- the method
is parsed and visible in content completion.
-brad
"Chris DiGiano" <digi@computer.org> wrote in message
news:3462c24ba92d1bed49b967746efd9d78$1@www.eclipse.org...
> alert('hello');
> alert('hello');
> Chris
Re: JSDT not parsing alternative fn syntax [message #216424 is a reply to message #216400] Mon, 30 June 2008 18:01 Go to previous messageGo to next message
--------------040108060806020203010202
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
I see your screen shot and raise you one... ;)<br>
<br>
<img alt="screen shot" src="cid:part1.02020602.01020605@resnbl.com"
height="167" width="376"><br>
<br>
What you see above is the only code in the file.<br>
Maybe this only happens when you've got jsDoc attached,<br>
or could you be running with non-default validation settings?<br>
<br>
Bob Shields<br>
<br>
<br>
Bradley Childs wrote:
<blockquote cite="mid:g4b7de$e3k$1@build.eclipse.org" type="cite">
<pre wrap="">JSDT does recognize this syntax. See the attached screenshot-- the method
-brad
"Chris DiGiano" <a class="moz-txt-link-rfc2396E" href="mailto:digi@computer.org">&lt;digi@computer.org&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:3462c24ba92d1bed49b967746efd9d78$1@www.eclipse.org">news:3462c24ba92d1bed49b967746efd9d78$1@www.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">I just installed Eclipse Ganymede with WTP 3.0. The JSDT module for
alert('hello');
alert('hello');
Chris
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<center><img src="cid:part2.06060805.05040907@resnbl.com"></center>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="screenShot001.jpg"
Content-ID: <part1.02020602.01020605@resnbl.com>
Content-Disposition: inline;
filename="screenShot001.jpg"
/9j/4AAQSkZJRgABAgEAyADIAAD/wAARCACnAXgDAREAAhEBAxEB/9sAhAAE AgMDAwIEAwMD
BAQEBQYKBgYFBQYMCQkHCg8NEA8PDQ4OEBMYFBARFxIODhUcFRcZGRsbGxAU HSAdGh8YGhsa
AQQEBAYFBgwGBgwaEQ4RERoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoa GhoaGhoaGhoa
GhoaGhoaGhoaGhr/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQ AAIBAwMCBAMF
BQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJ ChYXGBkaJSYn
KCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SF hoeIiYqSk5SV
lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz
9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAME BwUEBAABAncA
AQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZ GiYnKCkqNTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqS k5SVlpeYmZqi
o6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery 8/T19vf4+fr/
2gAMAwEAAhEDEQA/APrW7dLvWbiK5VJrW2dY0gcBlkbaHy6nhlCsmPfPpVZZ h+bmn6/oZVqv
JPlK0Pi3UJGtM3fh+zF7czW1hFqGstDNcmOTyztQxncc44BJG4evPN9c9hzx 5b+8+pq2rJMs
6D4sbU7dgXe3u4gvn2zMdyEjIxkAlTzhiAPXB4ruwWKVdWcPxOetTaV0WW8S Qpew2T6lEt1N
E88UDTAO6IVDMBnJVfMTceil1zjIr0HQj2sckakkLpniWDUdOg1DTtRS7tLi ITQT28nmRyoV
3KysuQykHIIyOeM84tYWLK9qyZdZcyBPtROTgEPwR3P6jk4HfNJ4WK6B7Vgu tSlFcTybWGQc
n/Pr06Yo+qxD2rA61IMfv3JJwArZJwSDgDk88cUfVYh7ZgdZl4Jnbaf4t+B6 9z6duvrjrQ8J
EPbsF1mUrkTvwASNxP6jj0/X0NH1SF7FKs7AdYm5PnsRnA+Yjk5xnPHbrmj6 pEftmDaxKCP3
7jnHzEjtk9eeOfyNVHDwWlgdZ2uQ6l4jTT9Oub+8uZYre2ieaY7WLIigsxwO uAD0zUzowSvY
Ua7bsZ2oeI9Lv9PP22Ga6KyeULSWwlecSbd2BAyeaG2fPjbu2/NgDmuZRpyR rJyWqG6RfQT2
FrqWgXhltbmJZYobiRjFKjDKn5gWjJHQf+Og5rCvgHa8SqVfWzNvSr6O9gLI GjkQ7ZYmJDRn
0OOvUYPevJrUJQep2cylqi0cg4O4HuCx4/WueLd7MAyff/vo/wCNaSQ0GT7/ APfR/wAaQwyf
f/vo/wCNABk+/wD30f8AGgAyff8A76P+NABk+/8A30f8aADJ9/8Avo/40AGT 7/8AfR/xoAMn
3/76P+NABk+//fR/xoAMn3/76P8AjQAZPv8A99H/ABoAMn3/AO+j/jQAZPv/ AN9H/GgAyff/
AL6P+NABk+//AH0f8aADJ9/++j/jQAZPv/30f8aADJ9/++j/AI0AGT7/APfR /wAaADJ9/wDv
o/40AGT7/wDfR/xoAMn3/wC+j/jQAZPv/wB9H/GgAyff/vo/40AGT7/99H/G gAyff/vo/wCN
ABk+/wD30f8AGgAyff8A76P+NABk+/8A30f8aAOJ8QXf2XXdQUnCi4DYHC58 qEc5/wAa+ryK
ip0Zu/Vr8EeXjkvbJ3/q5wnia31oeG7bxfHfaXFpGnzPHG95MVFvKNZ812Kh AsgYw2qgvNGi
4JYgEmubAuEVWg1r7WX/AAP1OfFuo6kXDblRvab4k1HVdXTUdTktzPcabBLu tY2jQr9pugjB
WZhyuCSGdWySrMhUnswlKSlaLLlVnyao5LX/AIeaRqnxYtvHU2q30E8G6R7c bTC8ge1ZGK4K
tgWnLOrvloyHU28Hl+hWwkm05S6djnp4hpWseYfCrx/qek/C7whY+HvHEmu2 MWj6XNq4YWsq
6AsdzYpJETFGPKjNvJe7jNvcLb7gy7HLc7hKCOrmTbTR0tx8WTrXjDVIV+Jd tovhMajMlv4g
sZbIxeZHaae6WwlmV4WDPPeyEMN5MXDBUZTOstQbtpY4zwFr+i694X8Ra5PP pF18W7+CxudH
uY1hGrSXbaNYlCm35xEZi+8ECIIZQ42bwGqbY3LbsbPir4pfEW0vfGFzF4m0 m3ks7fV9mjCd
Jbm0hginNtci1Frui3eVbt5k07xMso2pmSJVfI1oS2uxr+IvHnjzwxd6wNP1 y68RXFhqNzo1
vaXtrAftjJpD6jHI4gjjczGbbH8pVCg+4XJcnKyE0+hFrnj3wtLp+o6d4n8U ad4+8OeZajT7
7Wbu0Szm1CRbnzILiaJEtzHHHFFMQyOyF1IV3MCg5XsCv2O8+G+raDbeC9M8 L6J4vju5by0v
JrPUNJCNEkayASC2/wBZEiRNNEkcTFwqqiHf5ZNW6TtuS5O92jg/gX8QNYut V8IaVe69C8E+
iWLppHh9rARW6f2esjvf24jE1upkf920TCPBiQqh2mSKd3NRaKqO0Xp1PZde 1i1ttDvZ76FZ
7aO3lllhZFJdFX5lweDkfLjODkDPOa6sVQSp8xhRn7xfGv6PJ4bFm2vWba39 j+zHxZlTB5fm
+Z9j+2A+Zt2Yj87GN3zbvOwtfNwhJz5ktLnqOrHlsyloes2s+iWk1mnkW0kC PHEVUFEKghSB
wMccdsY7V9PQpqUUpHm1Gk7pluDV2gu1u4pVWVBg5+4wz91/brjqck1xY/Ll NcyfQ1w+OcHy
WudpoeoQanZiWD5WXh4SRlD1x+uefWvj69H2c7NnswalG5b7VnJN6x1BN9gq Ept2sWkwqnGa
6Caa6BU2n2Fr2Ci0+wa9gotPsGvYKLT7Br2Ci0+wa9gotPsGvYKLT7Br2Ci0 +wa9gotPsGvY
KLT7Br2Ci0+wa9gotPsGvYKLT7Br2Ci0+wa9gotPsGvYKLT7Br2Ci0+wa9go tPsGvYKLT7Br
2Ci0+wa9gotPsGvYKLT7Br2Ci0+wa9gotPsGvYKLT7Br2Ci0+wa9gotPsGvY 818eP/xVeobf
4JFfP/bOP/AV9tw7SSw7cus/zSPAzTm9rp/W5zyWXklhb6hq9ujOXCxancxo GLbmK4fAySem
PvfTHbPJKMpyly3u77v/ADMPrk6NoNdB9varHey3BnvLieQLG8l1cyTyFNxK j52JA+YnA4Bz
9TvQyulSd1D8X/mEsTKqiQYKAlsEDAKnoenB+o4Ppiutxpx0ascz54sUjIYE KNxJIAXHJz0P
1P501Gk9/wBSo1JooeJ9GtNe09LS+mv4lR/MV7HUJ7V9wBAy8UisRhiNpODw TkgGodOlfcp1
pluytLSzsILGztYbe1t41hggjwEiRQFVVGeAoAAx0HSrjCkS602SkDJ4U7iS 3CjOe3GOMnOP
YelDhSD2sxVZhIHDEN/vD/P+R1IFLkpB7SY2MbdpBIIxyGGenPPXnr17n2xL p097h7SZFf20
d3p9xZytIqTxNCzRTNG6q3Xa6EMp9wQQQCMEZpWpvQFUmLYW1vY2MFnYwQ29 vAgjhhjVUWNQ
MBVC4wOBwMDgdMVSp0lqJ1JtEoJAI3Eg4ydwycevOD+NP93LRihOcXcDksGO 0sOQWweeOT78
HPrn8KpYeitV+pc5zm7iAYUKDhQMAbhgD0HNDdNaIShN7iqSDnPP1FCnT+Fh JTjsT6de3Fhc
LNazGF16Ecg+zDuPrXnY7KKOIjdfr/mb4XF1Iyszq9M8dBsLqNgynHL2x3Ae +w8gfixr5PE5
NVoS5aW39eZ7ccZoan/CXaB3vJf/AAFmwf8AxyuD6hiE/wDhjRYwP+Ev8P8A /P5L/wCAs3/x
NU8BiX/SG8WH/CX+H/8An8l/8BZv/iaX9n4n+rf5i+th/wAJf4f/AOfyX/wF m/8AiaP7PxP9
W/zD62H/AAl/h/8A5/Jf/AWb/wCJo/s/E/1b/MPrYf8ACX+H/wDn8l/8BZv/ AImj+z8T/Vv8
w+th/wAJf4f/AOfyX/wFm/8AiaP7PxP9W/zD62H/AAl/h/8A5/Jf/AWb/wCJ o/s/E/1b/MPr
Yf8ACX+H/wDn8l/8BZv/AImj+z8T/Vv8w+th/wAJf4f/AOfyX/wFm/8AiaP7 PxP9W/zD62H/
AAl/h/8A5/Jf/AWb/wCJo/s/E/1b/MPrYf8ACX+H/wDn8l/8BZv/AImj+z8T /Vv8w+th/wAJ
f4f/AOfyX/wFm/8AiaP7PxP9W/zD62H/AAl/h/8A5/Jf/AWb/wCJo/s/E/1b /MPrYf8ACX+H
/wDn8l/8BZv/AImj+z8T/Vv8w+th/wAJf4f/AOfyX/wFm/8AiaP7PxP9W/zD 62H/AAl/h/8A
5/Jf/AWb/wCJo/s/E/1b/MPrYf8ACX+H/wDn8l/8BZv/AImj+z8T/Vv8w+th /wAJf4f/AOfy
X/wFm/8AiaP7PxP9W/zD62H/AAl/h/8A5/Jf/AWb/wCJo/s/E/1b/MPrYf8A CX+H/wDn8l/8
BZv/AImj+z8T/Vv8w+th/wAJf4f/AOfyX/wFm/8AiaP7PxP9W/zD62H/AAl/ h/8A5/Jf/AWb
/wCJo/s/E/1b/MPrYf8ACX+H/wDn8l/8BZv/AImj+z8T/Vv8w+th/wAJf4f/ AOfyX/wFm/8A
iaP7PxP9W/zD62H/AAl/h/8A5/Jf/AWb/wCJo/s/E/1b/MPrYf8ACX+H/wDn 8l/8BZv/AImj
+z8T/Vv8w+th/wAJf4f/AOfyX/wFm/8AiaP7PxP9W/zD62H/AAl/h/8A5/Jf /AWb/wCJo/s/
E/1b/MPrZnWFrb3XxO1aK6hjnQRrgSoGx8kfqPeu6VapDL+aHSf/ALac+Kpq deMO8U/xOhXS
dLB3jTbMHqMQqPf0+v5+5B8t4vEykm+3kdsKFJxvJaoybr4E/DzU521C5i8S iW4ZppEg8T6n
DGGfk7I0nCRjPRVAUcYHAx6VPE1HHVmEqNO9kjs9J8I+HdO0m20+LSbeSK2h SFGuQZ5GVQAC
0khZ3bA5ZiSepJNJ159GJUYEtv4f0JpZt2i6ccPgf6On90e1J15vqHsYdiX/ AIR3QP8AoC6d
/wCAyf4UKtPuDow7AfDug/8AQF07/wABk/wp+3n3F7CHYB4d0H/oC6d/4DJ/ hR7efdjVGHYP
+Ed0D/oC6d/4DJ/hR7efdj9jDsH/AAjug5/5Aunf+Ayf4UfWJ92HsYdg/wCE d0H/AKAunf8A
gMn+FL28+4exh2D/AIR3Qcf8gXTv/AZP8Kft592Hsodg/wCEc0H/AKAunf8A gMn+FHt592Dp
Q7APDug4/wCQLp3/AIDJ/hS9tU7i9jEP+Ec0H/oC6d/4DJ/hQq011E6MQHh3 Qf8AoDad/wCA
yf4U3Xm+rKjSilqH/CO6D/0BtP8A/AdP8KSr1F9pg6MH0EPhvQSMHR9PIznB t0/wq/rNTu/v
IVBCJ4a8PgH/AIkmnH/t1T/Codeb6spUkhf+Eb8P/wDQD03/AMBk/wAKft59 2P2aD/hG/D//
AEA9N/8AAZP8KPbz7sPZoP8AhG/D/wD0A9N/8Bk/wo9vPuw9mg/4Rvw//wBA PTf/AAGT/Cj2
8+7D2aD/AIRvw/8A9APTf/AZP8KPbz7sPZoP+Eb8P/8AQD03/wABk/wo9vPu w9mg/wCEb8P/
APQD03/wGT/Cj28+7D2aD/hG/D//AEA9N/8AAZP8KPbz7sPZoP8AhG/D/wD0 A9N/8Bk/wo9v
Puw9mg/4Rvw//wBAPTf/AAGT/Cj28+7D2aD/AIRvw/8A9APTf/AZP8KPbz7s PZoP+Eb8P/8A
QD03/wABk/wo9vPuw9mg/wCEb8P/APQD03/wGT/Cj28+7D2aD/hG/D//AEA9 N/8AAZP8KPbz
7sPZoP8AhG/D/wD0A9N/8Bk/wo9vPuw9mg/4Rvw//wBAPTf/AAGT/Cj28+7D 2aD/AIRvw/8A
9APTf/AZP8KPbz7sPZoP+Eb8P/8AQD03/wABk/wo9vPuw9mg/wCEb8P/APQD 03/wGT/Cj28+
7D2aD/hG/D//AEA9N/8AAZP8KPbz7sPZoP8AhG/D/wD0A9N/8Bk/wo9vPuw9 mg/4Rvw//wBA
PTf/AAGT/Cj28+7D2aD/AIRvw/8A9APTf/AZP8Karz7sPZoP+Eb8P/8AQD03 /wABk/wo9tPu
w9mg/wCEb8P/APQD03/wGT/Cj20+7D2aD/hG/D//AEA9N/8AAZP8KPbT7sPZ oP8AhG/D/wD0
A9N/8Bk/wo9tPuw9mg/4Rvw//wBAPTf/AAGT/Cj20+7D2aPPdIYL8U9XPfy1 wOOfkj4HeonX
ccuaX/Pz/wBtCtJLFQv/AM+1+Z1DZCEYIwSuT269T26ZrzFiJtLTodblF6HS 6eQbGHjoij9K
7KU3JamMoK5P/CcehrRoSjbQhgcLPMD3k/8AZVpATqwOeD+VNMAyPf8AKi4B ke/5UXAMj3/K
i4Bke/5UXAMj3/Ki4Bke/wCVFwDI9/youAZHv+VFwDI9/wAqLgGR7/lRcAyP f8qLgGR7/lRc
AyPf8qLgGR7/AJUXAMj3/Ki4Bke/5UXAMj3/ACouAZHv+VFwDI9/youAZHv+ VFwDI9/youAZ
Hv8AlRcAyPf8qLgGR7/lRcAyPf8AKi4Bke/5UXAMj3/Ki4Bke/5UXAMj3/Ki 4Bke/wCVFwDI
9/youAZHv+VFwDI9/wAqLgGR7/lRcBGkAYDByenbNFwFU5HQimAtABQAUAFA BQB4tqUV3N8S
NRtrLUL6yuJdqo1l5W5j5ceVYyxyKBjJztJ4NZ4zMFgMpjV5ObmqLrbeN/0M 5Yb22IjK9v3a
/Mq+LLPxpZW5uNM8Va9NJEwWa2Fpaz5jIZvMV0tQVAEUgxtzlgV3sFjk2ybO KWNhyVKfK7d2
+w8dgZUWpwnfTser/D+4uLjwPo9zdXRvJ5bKCSW4wimRjGpLYQsoz1wpI9CR yaxGlVxS0JoN
yhdsszaui3MkEVpcXDRttkaILhD75IqFTfLzMFVTbXmcn8cfEd9o3wD8deK/ D10ba/sNBvr+
zuBGr+XLHas6EqwIOCBwwI9axUn2NE0zitMvZNQ+Ilz4Itvjf8XTrdtzPFL4 UsooY1zIFc3D
6UIQjmGUI+/a5QhSxrCdeW6WnqWo3OsHgLxbsyfjh4/B54+x6Jn/ANN/JrP6 xL+UfJ5it4C8
WKpP/C8fH5AGeLPQ+n1On4o+sS/lE4g3gPxYoBb44+Phkgc2eh9+n/MPo+sS /lFyleTwd4oT
UobFvjb8RvNmieZGXTNHMe1WRSGk/s7YrfOuFJDNhtoIViE8TJfZCxOPAfis qSPjn49bGelp
oZ5H/cPpfWn/AChyijwF4swD/wALy8fAHp/omh8/+U+qWJk/shylDw74c1rX dPkvtK+PXxAu
II7q5snf+z9GTE0EzwyrhtOBOJI5BkDB25BIIJbxEv5Q5Sv4c0PxBres6/pt p8bPiKkuh6gu
m3LS2WhBXka2guQUxYHK7LhAc4OQ3GACZliZL7P4jUTV/wCEE8X+Yq/8Lu8f nIzkWeiYz6f8
g/8Az7cZX1t/yhy+Y4eAvFuR/wAXx8fkHoRZ6IQf/KfQsU/5Q5RD4E8V7sH4 5ePl4zzaaH/8
r/p+Yp/Wn/KHKKfAXi0EL/wvDx/uOcD7Jofb/twpfWpfy/iHL5mfdeHdag8S 2fh9/jz4/wD7
RvbO4vreD7Box3wwtCkjZGnYGGuIRjqd3AODhrEytflDl8y+PAfizkH44eP9 wGSos9DJx/4L
6PrT/lDlFbwF4sXO744+Ph/256H/APK+j60/5Rco0eBPFhK4+N/xAwe/2LRB /wC4+j60/wCU
fKKfAfiwLlvjj4/HGeLPRP8A5X0fWn/KHKULrw5rlv4mtPD0vx3+IC6neWlx fQW/2DRTvhga
FJG3DTiBhriEYzk7uAcHFRxDavyg4mfdad4lj+IKeELf4u/E68u0tFvr6eCz 8PiHToXMohaU
vZKzeY0EqqIxJgoS+xSGL9u7XsKx0H/CBeLQcH44+Pu/S00M/wDuP/zzUvEt fZGoiDwJ4qJX
Hxy8fEN0b7JoeD9P9A5/+tS+tP8AlDlOa8e/afB+qafpmrfHP4qzXuoQzXFt baX4c0/UJHji
aNZHK2+luVVTNEMnHLgDJNVHESavy/iJxN7R/B3ifU9JttRt/jf8RkhuIkmR bnTdHhkVWAID
xvpwZGweVYAg8EAggH1iX8ocpYTwD4tbp8cfH/8A4BaJ/wDK+peJkvshymRf 6Tqdpquq6Y/x
5+Ist9pVhFqV3a22laRNIkEhmEbKqaaTIzG3mARAz5UfL8y5f1mW/L+IWNYe A/FpGR8cPH/r
/wAeeidP/BfS+tP+UOUUeAvFpHHxx8enkDi10P8A+V9H1p/yhylDwr4c1nxL 4U07xJonx78f
XWmajaxXtpP9h0VPNhkQOjbW08MuVYHBAI7im8TJbxGol5PAfi1sf8Xw8fgf 9emhkj8rCoWL
le3L+IcvmZPgjQ/EHijRJtUsPjZ8RooYr+905lnstCDGS1uZbaQgCwPyl4WI PXBGQDkC5YiS
duUOU1k8B+LSuT8cPH4+tpof4f8AMPpfWn/KLlKPinw5rPhzwxqXiHWfj34+ ttN020lvbqf7
Bor+XFEhd22rp5ZsKCcAE8etOOIk/shylDwVZat4qW7Ol/Gb4uW5tQpcat4Y sNO3bs42fadK
j3/dOduduRnGRluvJfZ/ELG4fAni0YJ+OHj4DByTa6Hx/wCU+h4iVr8ocpzP xq0bxz4Q+D/i
vxVpvxr8by32k6Neajbx3NjoxjeSGF3UNtsVJUsAOCCRnFTTxMpu3KFj22Eb Ywud2Op459+K
74ppagx1UIKACgAoAKAPFdRvjZfEjUJFWMzun7mSQuNsvkoYwNqkZZ9seG2h vMwCWIVtHhFi
8qjF9Kq/9J+Rg63JVX+D9TK1vxNqVz4j0nUbpm0S5OoSGSK9VIn8jypmgkcS MrRg5tzgZO7f
GeHkx8JmVGthcWlS2su383z6H02FlTr4O0t/n2PavCTxP4XsGhSeKJraMqk8 jvIoKjAZn+Yt
jGS3JOSea+vpVZSowk97L8jw50VFuKOa1jw1dSalMzQX86tM0iNBqDwoAzFv mUOBnnGcH9K9
J1lKMfQ4ZUnGWhwn7Vcuoad+zN4y8NWNz/xMLrQNVvLiYkOI7WK2aSU4b724 vHCMEMPO3jOw
1lUcWtDWEWdTf+DE1v4oeNhrmmi58M+IPC2n6M48/b9pCy6j9oT5WDr+7uo/ n4+/wcg48RVl
G/qzoSZ4vqekSeIND+HfjTxloH/CybnxFr0MKWn2G0T+09Ot9H1H7NL5Mzxw L5rvNfbX2vH9
p8r5jCgrX2yu12HZh4i+C3jPUrixk1DTNfeAWs0WhWelXGkj/hGWe/u54g8t 1HK1n5dvPYxC
TTxIy/ZCFDCGDLVZNaCaZ6J+1D8O9Y8Z6qmo6NocGoXum+EfEEOlXDvGstlq 0pszZyQs7Axy
5hkKyjGwjlhkUoz79waOT8VfCPXIvF+v22neFdVtPBwivrbTdP8ADMmnQmOG b+wpDBDBcsLc
RSS2moGWN12OPO3AmUBmqja1/rcLFay+DGu35jvtW+HHhS1ufsmgWcEWj2Vv bQWtn/bN5LqE
KxmRxFvsbhROiSOkhklQNKp5Oez0Ao/Ff4Y/Ee+8CNpNl4Vv7m50v+2B4TbR E0dpdMle+umt
Q8t6d1tAsC6d5P2NlkjEcgbaUhAamu4jpH+GFzptvf283wtt9ZiPi281vXI4 EsWXxbZ3D6hJ
bxESyL5zW73Vq5W52BWhJjLlU3L2n5DsWLL4Uuuoa14r0f4dWOi67L4q0G50 qZIbSK9stJih
0yK6gWWJj5aLHFexNGr7WG9VDK43S6nTyA7++8Pa5dfA7xX4b8OWTeFNb1Ia 0lg51F3MVxPN
cNHd+amWTzHkWfCgmPzAgA2YEqWuoXPOvHfgCPW/Aen6Lo3wLn8OeHVv57q7 0LTtL8NyXz3e
yNYblY7h5bPyShmR2yJ9ywhfk350jLXV/mDZnfDL4SeK7TwuPEWv+GLd/iGN a8NTtrs08Emo
/ZobXSYtQ/0rcXw3lX6uu7MgZ+GEg3jmr6Bcg0b4La94e+G3gjSvD/guw06Q eF7aLxjYad9n
g/ti4hutLkkt5wpVLl5IYtSiDSHy/wB/IruqysxuM73uFzX8IfDK4tviZoni y++Fluvhy31C
8/sjwwY7FpfDRmXTAlyIhIYIgstldzHyHeQfaVYKWaRUynLdILna+M/DP2n4 72XiPWfAI8Ya
X9lsodMn2Wko8PXUdxO811tuZEMe9ZbY74A7t9m5A2R7ppyfLYDyy2+D3iS8 0DRdJuPh7Dat
bRaZaeLri4a0Mfi+6j1TTppb1tkjNchY7a/fdcqkhFzgKxkkA1cxHWX3wy8W aHe61e/Du2tv
Ds1rrUlpoCWcMDW1ppd3Y2UVy0UBPlxrFexteFNoeR7V0GBcMxXNtcZlD4LX mlfHGxvdL0vX
xpunXemroV/ZXOmi20vTbWC3je0kuJ45NQXJhuMxQny5ROFZ1Ms7gU3bUCf4 ZfB5PDGl/B67
1b4e22s3Gi6N9k1OB2t7q4sdUlGn4vS8z4KwCzeMNGzOiCJIlKKAsyqO7QGv 8dvhfc+Ldc+J
WtQeE9P1HUb3wEujeHr6VIfOS8YamsscUjndDuW5gDMSqsH6kK2FGo1b1Boo fGL4WXbXmoaf
4d8EnV0uNAWw8N6iZoZH8Mar5l08moySXEgmR5HntpGnhEs8jWzMwLKm+oTu tQZga98FdebS
fEF5pfgyyTW7y18X30V1EbdJn1aXUPM0e58zdnz0hebypcgwiR13IWIL5+/k Fz1T4meAj4v+
MvhbUr7+14tIsNG1SCa50vWbjT5UnlmsDEha3ljlYMsMxxyvyc87alTaQHJe JvB/ivTdT1Tw
1pXhPV9W0/V/F2ga9DrP9oQSR2drZnTUlFw9xOtw8oXT5WyEk3B0yxYuFpT6 sLHM6L8Fdc8P
/DXwRpfh/wAFafpso8LW0XjHT7A28H9sXENzpcstvOFIS5kkhi1KJS5Mf7+R WdVlJJz3bCxL
47+FX27TPEd34e+DEGlzat4JudA0O1WLTIpPD90BqJcOUmKQrcfbIgGgZ8kt 5gjHU5u4EfxO
+FPjDV9J8U6fpXgcDxNd/wDCRSXPinz7RP7dsrq3vUs9P83zPtDeWbmwGyZE iT7J8r4jiLNS
2EesfDjwVB4M+JviEeHfD1hoXhK50vTjbWemxRW9t9uWW8+0yeVHgK5ja0DP jLBUGSI8CHJt
DPL/AAj8LD4d8C+DNF1T4J2+v6ToVhPpuraFbxaW8Wq6mEslTV0SaVYpF229 ygklK3A87BjA
ZyL5nrqB2finwV4jk+Dfw90PxJpJ8dTaILb/AISXSfOjn/t3bZSwt/x9Mkc3 +kvDcfvmX/VB
/wDWKinOM/edgueRr8EPFdxa2nmeFNe021/04aHpmjy6Iv8AwjssmqX9wkry TJMbPMNxZYks
N8i+QflLRQg684je1/4Ka6+la/eaX4MsI9curbxfqEd1C1tHM+rS6h5ujXPm bgfOSF5/KlJ3
QCRxujLEUufp6AO+Jnwq8Y6xo/imw0jwVjxLef8ACQy3Pinz7RBrtldW96ln p/m+Z57+Wbmw
GyZEhX7Jw2Ej3JS2HY9D8UfD9/DN94a17wlZ+KPEMmka1/aV1p154guL65mQ 2N5agQG+uPKR
g94Hb54wVRuWZUVkqjejCx5pZ/B7xDquhfELxDqnw/tofE91o17N4VlvZLOS +0+/k1TWbuIw
zJIwglUXdi/mI4AJGGyhxfPoBr/EzwvJonwd+M1xrPgRv7dudA8RXDeNsWji +tZfOkt7bzRJ
9pPlwtDHteNY1+zlVJURlppy1TA+krcgqccEHBH+fz/Gu6MuZXEx9UIKACgA oAKAPnf4sRGX
xJer5RcebEvMe4ZaFVx9x+uduMc7toWXcYJfZyV8mBku1R/kv6/q55WN92pf +7YwtL1zW7W3
SPTdY1CGPeZFW2uHIZ3KuWGC4LM5jYn94WLj/XeaP7Q2lhKespR/r+vL/gY0 681JWelj6M8A
SG48DaPMZ/OL2ULGQyeZvzGpzu3ybs5673/3m6nw6kVCbS7nrxk5q5rFWB65 79Kx5dGr7mkX
pqZGuaDY69Z6hYapGLm0uFMMlvKoeNlZMNlSCGDKSpVsqRkEYLA4Oi/5vwNF NLocVL+z98FQ
rovwp8HKGUBSNFtjtIxzyhyflXrkHnj5myoYVvXmB1EJF+z58EnVmHwq8Gjg BR/YdrhSMcjK
ey9cjg5HLZJYdxfxA5rsTR/Ab4KW8jE/CXwRKrBch9BtCOO/KZOePxHuSdad JxVtyXLmdx5+
CHwUGC/wi8AAZJy2gWmOe/3Pcf5xTfKtX/T7AKnwM+CWMD4QeAgR0x4ftOO3 9zPWqi4y+ETd
ho+B3wTzvk+EPgADOQW0C0xjp/c56j8fwq1BdgQ+L4F/BUkE/CDwCcDH/IvW nX/vik4LsF9b
CSfA34JqFH/Cn/ARGc4Hh60P/tOolFp+6r/MTkk7Afgd8FGQD/hT3gEDdgA+ H7TAP/fHqaaj
1a6FNDT8DvgmSCvwf8BEEdB4fs8H/wAc/X+WaWnbpcVh0nwO+Cjrx8H/AAF6 5/4R+0+vXy//
AK38qpJWukIVfgd8FNwA+EHgLb0GfD9oP/af1+tNQurtBqI/wN+CargfB/4f jg8Hw/af/G/p
SSu+Ww7MQ/A/4I7FZvhD4AC88t4ftBxn3Tjn+dNx1skLUc3wO+Cjc/8ACnvA R6njw/Z/iPud
f8KfKkMI/gV8EyNy/B/wDwMA/wDCPWnPv/q8flS5UFx5+BPwVZs/8Kh8Ajtj /hHrTp252Ucq
EH/CiPgrg/8AFovAYyMHHh6zGfr+7osgB/gR8FGOT8IfAR+vh+0P/slCih3F PwJ+ChbP/CoP
AOc5z/wj1p/8RRyoLg3wJ+CpIz8IPAJGc4Ph60/+Io5UAh+BHwUIOfhB4BJP XPh2z/8AjdFk
IU/An4K4H/FofAWAMYPh60I/9F0uVDuIvwI+Co6fCHwCMdMeHrTj/wAc/wA8 0cqC4f8ACh/g
psC/8Kh8BYzk/wDFPWnP/kOnyoLh/wAKI+CeBj4QeAhjof8AhH7TI/8AHKOW PYLgfgR8FQm1
fhD4BA9/D1of/ZPSjlQXF/4UT8FOM/CDwEQO3/CP2n/xFHKguH/CifgrkH/h UXgPcMYb/hH7
TOR77M/rRZWsDEPwI+Cu3A+EXgIen/FPWnH4eXS5Y3uIVvgR8FCR/wAWh8BE ejeH7Q/+yU7I
dxD8CPgqRz8IfAWeuR4ftBz+CUcsewXBvgT8Fju/4tF4BJY5JPh60OT6/c+v 50OKC4p+BPwV
24Hwi8BDsP8Ain7T/wCIpciC4H4FfBTn/i0PgIg46+H7Q/8AsnpTUUFxF+BH wTH/ADSDwCeS
Rnw9af8AxFHKguegQp5akA5BORxT06CHUAFABQAUAFAHzt8VovM8UXp8rf8A voVz5e770Krj
Ox+u7bjHzbtu2bd5EnsZR/uc/wDr4/yR5WP+I5QZnw+PP3jH/PTfuB7/ALzO 7zemZN3nf8tv
NxqHfK/Jb+v6/r046fxI+nPh7J53gXR5fO87dZQN5nmeZuzGvO7e+7673z/e brXzlf436nuU
fhNZ+n4VhKHM7mqZDAcTTj/pp/7KtNRSBpnPfFfw2fFvhGXRRcSwC4dI5GS6 lgxCx2ynMZGW
8tpNqsChfZuBAralUSehlODbL/gaxuNK8I2FjekNeRwqbk/aZpwZiMviSVmk ZdxbG4k4x6VF
aUb7lwg1ucd8eW8IHxD4LPisaH5I1KbI1Xy9vk/Y5933+AvmeRntnZ3KiurD KTi+UzrScZJI
xPEviDxZo3h7RYDq8Oi2k8t/IdR1i+SzYRLcAWkTSzwyje0Dlirp5reWSzAh w2vs6PM+fy++
2uzXX5GXtJmf4h8eeILG30+4h8eaHc3a6Bqepta2ckF1DdtayqYSsgRDudRI shUAEJLsRCNy
aUsLSmnyxbXMlfVb79/l8ridSRqjxlqL60+mat42g0zSYp5V/wCEhtkgiWeQ wWc0UStKJIwr
C6nKgfMUhU7m2uzZvCQeqhr21815Pp9/yLU5He/DXU7zVPCUV3ez/aHM9xFF clQv2mFJnSKb
gBT5kao+VAU7sqACBXBiqDinGno/+AbU1KTuzh/2oLCy1Y+FdME/h+HWLm/n jsDrUEcyEm0n
H+rbqPMMA4DAOYiVbAU9WXTnTg+a+3TTsY14SctDa8QpY+A4vDY0q5h0Pw5F qFwl/CfKS1SO
SOZ9zOw/dfv9gXDKuZNuOVAhQWJcpzV5W0E3ONkcnp3jW8vrDwtaxfEBbW8u vEGo6RcG8t7d
LiWFTNs3wsiMk4AtgBtUBpVLo+5VPX9Sppy9zTkT676X+W/3aWDnkW7Dx4uq aXpy3PjyDStN
WbUrefXbd7UebLbzqkEbvKrQh5YWaYhVBbbuTagIOU8LGF1y9tNeq18/IqNS Vi34lvdUl8P+
FNYm+It1bWTajcfbdZsbaG1tWgeO48pyJlkURBhEkbMzK+9G+dmRhNOlTTaU Ondlc8i18XNZ
sx8CL3UovFrwIbOZbe6uYrYjVJFhkAjZJYjG6ylS2EUBhjb8p5VLDRlU5HDm 12u/8w9oy14v
8W2dxcaK9p4zt9I8PXkNy5121mt2R543jSOESSq8fzBpyRjd+5PICuKmOGTf JKF2umv6WG6j
MbUPFGrSQeDIn8Yw6ZPqmrXmnLNLHATqFoomWOdVYcuwS3ZWTEZaZSUZWVK2 9lBcyS2S76eX
y131MpzldWOw+D/iKLxL4Qa6XVLXUntr26snuYHRjIIpnSN32fLveMRucAKd +VAUgVzVVys3
hUfU6uMALx61gpcxo3cdTEFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAF
ABQAUAfO3xWi8zxRenyt/wC+hXPl7vvQquM7H67tuMfNu27Zt3kSexlH+5z/ AOvj/JHlY/4j
kx+/IfHn7xjP+s37h6/vN27zumZN3nf8tvN/4mHdJvlt/X9f16cdP4kfQ/gf X/8AijdK+QXH
+hw/vfP37/3Y53bpM59d75z95uteHXpWk3c9yj8J1UMnm2yS4270DY9MiuSS eyNEtSjcWtxP
cXDRXZh2sNgVf4sDlueRjjHHc5zgjiq4Zz+3b5GsZJdBkmnzoC/9pzgJ8434 xu7lumV4PHAG
T/s7eVYGSl/F/At1F2EXTrkREDU59w5UyKCd/fdjGQfQYxk4x8u0qYN82tX8 CfadkE1hOvK6
nMCvzoZACA38RboCuO3GMnGOMX9VrfYrWX+Fb9w9qusRP7OucELqc4IO9Q4B IfqdxGMr/s8A
ZIB+7tpYOf2ql/l17/8AAD2q/lHf2fdBPk1ObK/NGXQH5u+7GMqf7vGMnGOM TLBTv7tS3yH7
SL+yIul3CjEeqTHaA0e9Bw3fcBgEH04xlsEfLtX1Kp/z9/AFUXYP7PuQjLHq kxx8yb1Bw3fd
jGV/2eMZOCPl2tYOsndVtP8AChOok72BtPutxEWpXAZcOhdQfn77h3U+mBjJ xj5dpLB15O6r
f+SoTqp7xEj064Q/u9TnCIS0YYA4fvu9V9F4xk4xhdrlgastVU1tpotH3/4A /arrEDp06R7E
1GVVXmMSKCN+Od3PzL/s8AZOMYXaPAVtlU6dl8X83/2uwe1X8op0+5H+r1Wb K5ZNyhvn7lv7
w/2eAMnGMLth4Cqo+9U19Bqouw06feAFYtTuMqN0ZlUMN/q+MErx93jGTjHy 7XSwU7P3+ttg
512BNNuMEpqc5VTlQ6hsv3LY6jrheAMnHRdsxy+Tbbqdewe0XYcdNuFHy6nO cDdGXUHDd93T
Kn04xlsEfLtc8DKW9TT0D2i7Dhplz5ZVNUnIX5kEig4Y9d2Mbl/2eAMnGMLt r6lWk041dF5I
PaR/lLVlaSwBka7kmQ8jzANwbuc+ntjjoOMAdtGjKHxSv8iJST6FlRjNdBAt ABQAUAFABQAU
AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAHzt8VovM8UXp8rf ++hXPl7vvQqu
M7H67tuMfNu27Zt3kSexlH+5z/6+P8keVj/iOTGZyHx5+8AZ/wBZv3e/7zO7 zemZN3nf8tvN
xqHbLm5bf1/X9enHT+JHuPhGXzvCumy+d5260iPmeZ5m792Od2+TP13vn+8e teViNz26Pwne
WH/IPg/65L/IV58nrY2QkbbZp8jP7z16/KOlHInuFmc98VtP1vVvCE1l4c1O /wBPvpnSEXFi
8SvGjsEdyXByEVjIVUq52YVgSDW1DkpvVXMpylF2L/gganF4RsP7ZluZNQeE PcC6eJpEdhuM
ZaNERtuduQoB2+uTWdaaUtEaRm3ujN+IF3fC7ttOszKUlt5biTyHdX/dyRLn 5CHKqJGcohDO
UC5AJBqF2rpGVWo07Ix9P1/XrWPw7oQKi61Ge9U3N/bSblihdin7osHOU28s xPQncSTV8rbb
t+Jl7WRauvEuvQ3mh6UP7OF7qFzeRSXPl741WDfjCK/Vgq5y/wAuCDk9FyNq 9g9tIztJ8beI
dWHhX7J/Zlr/AG0lwshlt5JPLkhDEsBvThtv3TyvOSap02r3QKtIH8f6zdeE NB1Sx02FptRM
xmjjUTSBY22/u4S6NJngnDfKMnmmqUk2mg9tIi8Qa/ruoeEvCmo2mrWsU13r EcEstpFKsUpL
OqjDFWKfLgqcbvUYzScJRbVvxD2sjc8a+ItW0q00WbT30+7e6v47C53KyqzE kMVILeWAyMDk
Nj6jmFC/xIHWkNv9a8T2PifQtEuZ9JZ9RF0jyR28nytGrMjAb+hBTKk9mAY5 GDkjvYPbSMvQ
vHGt6vpvhiOOOwhvNZe78yYxPJHGsBPCx7gTkADO7g9jnhun7suVdBqtId43 1PxJ/ZHh111G
3trmXXhaTNbqSkmJHRNwWT7vyjcmc84JBBqqEZa3j9j8R+1kbHiDxFqNvq+g aTYSWMlzqDTp
NdtEzRq0KEuFj3DGWBHL/LtxzUxhKzbQe1kYx8c61P4M8M65Z2tgJNSvUs7i GUOAcsy7lbqg
Owk5VsbvVeadOd2rB7aR3vh/+0BpirqklrJdq7B3tVKow3HaQpJIJXaSMnBJ 5NYy3NqcnJXZ
dqSwoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKAPnb4rReZ
4ovT5W/99CufL3fehVcZ2P13bcY+bdt2zbvIk9jKP9zn/wBfH+SPKx/xHJqf PIcjz94xn/Wb
9w9f3md3m9MyZ87/AJbebjUO2fMo/wBf1/X3cdP4kfQPgvTLq78H6VcrcRzC WzhfeZjJuzGO
d2+Td1673z13HrXi16q5mrHuUfhOutkMdrHGSCUQKcewrkbNEildJfyXNx9l kjQIwYBhnzGw
Mqf7ox0PPJHGBg+fiKU5fDK3yNYyS3RFNDqmP+Pq3kCjeMx4Dn0PXaBjg8nk ddp3YUaWIg2l
PpfZF80Owph1fDgXULFfnU+XjzD3UjJwOuDz1Gc4O6p08Q5W9p9m+y+4fNHs Vta0q71G2WC5
uFkVSJY3iLwuXwQQHQ7kGNwyDkhsHIyGco4qNuWr0/lRLlHsQv4bR9Lj0+e2 0+8toWM6RXNu
HEkhJLZ3Zwcsx38sS2ST828UcZ/z96fyrfsK8ew+70I3Gmw2NxDpl1bW4WSG F7RfLyBjaFOQ
oAyARyMjOcHcNYyP/L3p2Qe72FOhBb23uo4NLE1rEEt5RaqGCdPLBwSiAE4x /eHBwdzisZ/z
+6dlv2/4Iny9iq3hKxMAhbSNFkijYzJGbGMLI7AbhjHyjCgZ6n5c52nc39eW 1S+nZfcNOPYt
SaHK+jDS5E0+5skRfLt3tkEbKMfu9nQKMDGP9nOdp3ZuGP8A+fnTst+3/BG5 R7Ed94bju4ba
O7s9Ju0tEzbpJaJtB4yqg58teBgjn7uc7TuIrMobVfwQc0bbC3vh5rrSk065 h026tIArQQPa
p5fAxsCnIVQMgEdiAc4O+4RzFO/tfwQOS7EbeF7NNPGnjTdGktFk+0Lb/YkE byHg5XBC98MM
nkZzg7idPMX/AMvb/JfcCaa2J59Hkm0j+zZk064tEQBbdrZRE4B/1ezoqjHH XHGc7TuUaWYR
X8Tz2X3f8Eakuwl3obXWmw2VxBplzb2+14YXtV8stjG0KchAATgjkZGc4O5R hmEU26n4L7gc
o9ht/wCHYbyK3iuLPSbqK0QfZkltEIU8DYuc7BgDBX/Z/u/M1HH3/ifZvsvu ByXY09EimsLZ
bJzbtBGqiHyUEYQdNgQcBRxtx2wD0y3Rh/rK92r73W+i+Vv1Ikk9UXoZRIhZ QcZxXX7yWq1M
tbjw2R0prbUbugzTFdijkUhoKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAo
AKACgD52+K0XmeKL0+Vv/fQrny933oVXGdj9d23GPm3bds27yJPYyj/c5/8A Xx/kjysf8Ryg
/fqH2+eXGM/6zfuB/wCum7d5vTMm7zv+W3m41Dtnzcv9f1/X3cdP4kfTfw8k 87wLo8vnCbdZ
QN5gk37sxrzu3ybvrvfP95utfP1vjfqe5R+E2G6H6GsHuaogh/1847+YP5LR p1Gc98VH8SQ+
Epn8KXEUGqMyQRO9mbgL5hEYIAYBArMrs5DhVRiUbpW9FQvrsYVL30LvgS41 G98I6fe6uAL2
5hW4kQ2htWTdhgrxF3KOoIDDceQenQTW5VLT0LhfqUfH+q3Fi0NnBI0HmQvO 9whUGNVeNOrK
wRMygu5DbUVsDJBFQpxlZvoTUquDsjJi8a3tj4Y0e/msodTN7qD6e0lvdLks JWRGU7Qr5Cf7
AJI4AJxSwkW2r9OYz+suxd17xfe6QdLs7vQv+JjfyTKsEczyIixn7wZI2Y5G 0gBM/Nz0NP6v
Gd3fbUHiWjO8VeKtdGg+GtS07T306S91KK3ubW8bY4ySPLIKnCnBO7ggY4Oc BRwsW2r/AN4f
1h2NrWfEWoaf4j0jRX0q2km1KCVlkF0wVJY03FT+7J2klQG68n5eACKg5Rco 7IX1iSdjIt/i
FLL4R0DX4tDEkWqXf2QwpdfPGd5VdpK7XztPGV5IGepD+pzba7e8P6y7F7UP FGuWet6RpEvh
+zS51Ezqoa/bahiJPURH5WUKw6HnBHGaI0W4uXb9TOWIkpJGv4H12LxJ4Vs9 ZitpLcXCnMLn
lGVirDPcZU4PcY6ZrKrTnBtXN6dZtFPxfrV/Z6zYaJo2mW19qN5BNcgXV01v CkUZjVssschL
Fpo8LtxjcSQQAxSo865qnR/11Q6lZrY4vSfiJrOl+FtLgu9Lv9X1a5utSVvt Ebs8cNtdNH+8
+xQzfvAGiHyoEJDfMDtDbywMFJpvtL71fq1/XQxWIZf1D4n6hZW1ncz+EJ1t pNLu9TuC9w0M
lutrIgm/dyxqxQq6tGThmLKGSIEstQwcXdc1nf8AP+tf1HLENMu2njzVL7WG 0Cw8MxR61G8z
S21/qAiijijS2kz5kaSHftvIAVC4DeYAxCqzx9XitXLTbRev+X5fKlXbML4m eL/EcnhPRdX0
BNYguWv7ywu9M0k2sjzvBFc71jaeNgQJbbghQxVj8pYhRpSpU7uM3e2vXy7e pM8Q07HV22oa
x4bufD+jalN/bbalfXNtJqMzLBLHiOaeP92ibHwkWwkFOQGx8xA56lKjWk6m zXr/AF/Vio1n
1M9PH2uNpmjSw+FbWe61DU7zSZYY9SO2CeEzAMGMQ3RnyGLHAZQeFc8VqsFR hJpytontvfXv
/wAD0G699UWovHOo3y2FppGg282p3H23zYrq9aKCP7JMsE22RYnZj5jrs+Qb l3MdpAUy8PST
d5aen/B/X7w9qdP4Vvr/AFHRlu9T0eXSbhpJFNpLMkroochCWQlcsoVsAnG7 GTjNYyhGLtF3
RpCXMrmjUlBQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QB87fFaLzPFF
6fK3/voVz5e770KrjOx+u7bjHzbtu2bd5EnsZR/uc/8Ar4/yR5WP+I5QZnAf Hn7xj/npv3A9
/wB5nd5vTMm7zv8Alt5uNQ7pJ8n9f1/X3cdP4kfTnw9k87wLo8vnedusoG8z zPM3ZjXndvfd
9d75/vN1r56t8b9T3KPwms/f6VjK9ro0T1M66lvEupvs9qsqo4dwWAL/ACj5 V9+/OB0HcleC
rVmn8JrGKfUjE2qbgr2sLBTubY/3lPRV6cjuT1Cjj5jtyVfEJ+5C/wA0WoR7 iJLqwVQ1rbvs
bcdkhG8f3Rn+Ic8ng4HTcdsyniZ6ez+1fdfcHKu5T1e01C9WOVYhFcQbmS5t XUSbG6xruBU9
shgVJRTweU1VfFx+ClfXuvuJdKLerKep+HTqFtaRana3F61lIblXXUJUeRyc 5BUqN4OcE4A4
C7AxCy62O/59df5lt2/4IvYw7k2o6M13BZR3OmiVrDLxSxXkizYK7SqShg+7 BOSzYbAzyxKV
Gvjl/wAuv/JkJ0IdxNS0Q3ejRabcaVDLFby/akKXD+YHznMcmQyy5LZfIJz1 G87ZdfHP/l11
/mW3b/gjVGC6iahoSXNrbxSaRGWtGeaOW3unjmy+d4SRSrbiWYkk/NxnliVq OJx8dFS/FBKj
Bu9ykfBtgmn2tiukSfZ7KZruGKHUp1w5IPyHePnByQTx6bd7bVLE5i/+XfXv Hbt/wQVGC6l4
6Kw1Ww1J9O8+606Jkgc3kj/IRghQzYL4Jy7cthckZO1xxOYKLTp7+cRulC9y Xw7pknh/S107
StMjitY2MohS4ZwQcfIm8naR17AkZ43HbM8RmEnd0/xiNQgtmQeJtDbWxAdR sXaS2LOstjfS
20xQkExpJEyMOVUkE7WKISP7jp4rMqe0PxiOUIvqZkHgHSLTTlsrPQ2tIop5 rpBp2p3FuyCU
hpIoWR1MaFgGMYKxsyqdoJymrx+ZvV09b947dtt/Pcj2MO4t74E0+52fbdPv r4R2c1k6za1d
y+dbSg+ZF88mGY7vvP12R9MDy6hmOaQtamviT+z0+QSowbvcln8F2RTP9mXA nWQTPdW2q3KX
Mo8uOPYJg4c/LDFu3NtcxoxGSSmbxuaP7HW+8bW7WtbruUqcV1JX8J2wXSM6 ZKTo07Xlr5Go
zIWkbO4khh5sh3PuaXdv3Nk/vHwLF5hZ81O7b7x27DcIN3L3iHTJ9YsEtNR0 9ZFgkE8b2t08
MqEAjEUiFWR9rMpYEblJHAdgubxGYc6mqena8ROEGrGNZeAdKsRYi10Vok06 9l1O2gttRnSJ
JJM7ljTeFXhnG3ATDMAqiRwOh5hmLd3S6W3j/kSqMF1Fh8B6db6alnFp18PK lluRNDrd4Lg+
YVaSNJvM3gMVVmUtsZlViASSpPMMxlr7L8Y/5D9lDudV4Ssl0rS102Kzjt4o 8upjkZ9xYlmL
M3zM5YksxJLElicsRWmHnXnFvEKzv5bfIiUVF2Rqjqa6CQoAKACgAoAKACgA oAKACgAoAKAC
gAoAKACgAoAKACgAoAKACgAoA+dvitF5nii9Plb/AN9CufL3fehVcZ2P13bc Y+bdt2zbvIk9
jKP9zn/18f5I8rH/ABHKDM+Hx5+8Y/56b9wPf95nd5vTMm7zv+W3m41Dvlfk t/X9f16cdP4k
fTnw9k87wLo8vnedusoG8zzPM3ZjXndvfd9d75/vN1r5yv8AG/U9yj8JrP8A 0rJzSNUQRIGl
uAQCC4ByOo2ilGSYNtHPfFbWNZ0HwhPfaDZ2F7fs6QQxX07Ro0kreXEPlRtx MjRrglBhiS64
zXRh6cJ1vfdlbsQ5voVx4snPwvt/Fb2drPPdwxvZ2trcsY7l5iFt1Ejxqy7y 8YyyAIXOcgZp
U8Mo13rpqJVGdDoNtdw6Ha22pX4vrtIUjuLowiPz3CgMxQcLk5O3oM4rlUZK UuV6XZSvItmM
EEF92euR1HpVWqdx8rAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9KLVO4crAx gggvuz1yOo9K
LVO4crAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9K LVO4crAxgggv
uz1yOo9KLVO4crAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9KLVO4crAxgggv uz1yOo9KLVO4
crAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9KLVO4crAxgggvuz1yOo9KLVO4 crAxgggvuz1y
Oo9KLVO4crHonB+bdzzkVSTS1Y0rDxTAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAKACgAoAKAPnb4rReZ4ovT5W/8AfQrny933oVXGdj9d23GPm3bds27yJPYy j/c5/wDXx/kj
ysf8RygzPh8efvGP+em/cD3/AHmd3m9MybvO/wCW3m41Dvlfkt/X9f16cdP4 kfTnw9k87wLo
8vnedusoG8zzPM3ZjXndvfd9d75/vN1r5yv8b9T3KPwms/f6VlJK12aJmfPe SW91OsVpLMAw
ZyoPygqBxx8x4zgc4HqQDwVcTKm/dhf5msYp7sjkvrgkl9LnOBlxkH5D6Y+8 fVRzwcZyu7CO
Pm3zSpa+pTpR/mMvVbW7vfEmmalcW9wYNN82YW20H966+WkoYdSsbTqU5B8w nkrHnVZi7fw/
x/4AOjD+Y3tNmkk3pJbPbsPmCkggg+47+o/n1rpw01Vi5ONte5nOPK7RZbAP rW/LHsRr3Daf
Wjlj2DXuG0+tHLHsGvcNp9aOWPYNe4bT60csewa9w2n1o5Y9g17htPrRyx7B r3GO21sE8etH
Kr2SJlLlWrDfx1q/ZoXtI9xUJKknipcI3sWrvZige9HIuwWl3A5z1pcsewO6 6h+NHKuwrvuJ
z34pqER2l0DPvRyRC0xydKdkthq/UWgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKAC
gAoAKACgAoA+dvitF5nii9Plb/30K58vd96FVxnY/Xdtxj5t23bNu8iT2Mo/ 3Of/AF8f5I8r
H/EcoMz4fHn7xj/npv3A9/3md3m9MybvO/5bebjUO+V+S39f1/Xpx0/iR9Of D2TzvAujy+d5
26ygbzPM8zdmNed299313vn+83WvnK/xv1Pco/Caz9/pWMo3dzVHL+NfGege EZ0XVn1CW5un
YwWem6dc39w6Iq75BDbo8nlqXQM+3apkQEguoLUkguzlPAfxp0HVvhxpnijV YCk+oXV/bwWf
hxbnXPPW0upLd54fs8JkkgJRG80xqo86ME5Zcl4y1YtZamhf/Gr4Y6feafBq HiU2UmoW0l3a
/arO4jVkik8ucFmQBHhIYzoxDwKrtKEVWIOWIcrLL/F3wANJivrHWLjV0nme KK30bT7nULht
gRjIIII3k8orLC4lK7GWeBgxWaMsJLoNKxzXxz+O1n4E8F+H/F+l22hX2g6r dXFpcX+tapPp
y2MkUEsux0FtK+/NvNE0RVZVl2x7GYkKwOu0Tx1PbHw9pXjrRh4e8Ra5d3dn a2NrLLfWzvB5
jjF0sSovmQRGVFkEbEblxuVgAChc/Gz4d2+iaNq1zqeoW9rrN1dWNiZtIvEe W6t2kWS3KGLc
k+6KVVhYCSRlKorHigDQv/il4OtdE03VBd6hdx6iZRb2un6XdXd3+6YJKXto Y2lj8tyqSb1X
y3ZUfa7BaANrwF4q8P8AjXwxF4i8L6pb6ppU0s0MV5bndFK0UrxPsb+JQ8bg MPlYDKkggkAr
ePPGeleETaf2pY+ILkXO/Z/ZGhX2o7duM7/s0Umz7wxuxnBxnBwAaHhTWbXx BoEGr2UGoQQT
7tseoWM9nMNrFTuhnRJF5BxuUZGCMgg0AcL+0L8XLL4ZxaZajQ9T1bVNTvLe ztIY7S5FsWkd
hlp44pBuARz5aB5DgYTByNacOZXO/AYCpi5y5NlFt7dPmg0n4waFHHoNj4lt rvSte1m2uLq1
06HTtQl8xIfMLhDJbRuzBI9xQorfMuAdyFq9k3dBDA1ZqbW0X3X+YyD4+/DC e20Sa11rUbxd
cjll0wWuiX8zXYjZ1k2KkJJKmNtwxlRtJADKSo0JdETHKsW02o3S31S/NmjL 8Y/h1/Yeh6tb
699vt9dLDTE0+2muZroqpZwsMaNJ8oU7vl+QjDYPFN0JoTy7GJuLhtvql+Nz A+JXx50Hw3of
hTVtL0rU9WtNf1xdGJ+x3UL22HaOUlDCWMqsuBAQrvhtudppKm+ppRy+rKUo VFZpX3W3rext
/F34p6R4G8Aw+J7qGZUuIklha+tL2GBFZox+/kit5Wt2/eABXQFm+XHDFRQ1 sc9LBOdVwX9f
ia/jTx/4Y8KTadb63fTJd6nI8dlZWlpNd3FyUUu+yGFGdgqjLELhcjJGRk9k xQwVSV+XZehg
TfHT4aqNDNvrl5ff27btc6X/AGdpN5d/a1XdvCeVE2XTad6feTjcFyMnsmX/ AGfX1v09P8zo
LP4h+ELn4YTfEO21qG48Mw2UmoyajCrMqQRoXkYoBvyoVspjcCCCAeKicXF2 ZjUozoy5Km5V
1Hxtqej+F/Cer+IvDQ0xtWurSy1WH7asv9kTXC7I13Ip8/Ny0EGUwP3vmfcV iIMzsYn3puxj
2oAwPif4o/4RHwm2rJYG+uJLq00+2tzJ5SPcXNxHbQh3wSieZMm5grFVyQrE BSAJ8QvFP/CK
6bpupS2BubS41a00u4KOVkh+0zrbRuilcPiaWHcCVwhdgWKqjgHQRNvTdxjt g5zQA6gAoAKA
CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAPm740XdhZeIr2bULi2gTzY/nm Kjj7OCwyUbHy
7uMfMNw2zZMEntZUrYGUv+nj/JHlY9Nzt/ducZc67ogZ2uNZ099quHLzq27A k3dS+4H98esm
Qzf67zD9v7ZtKG/9f1/Xbkpxd0z6r+HsvneBdHl87zt1lCfM8zzN3yDndvk3 fXe+f7zdT85X
+N+p7VF+6a7Hg/Ssr3VzW+tjz74l6Dql3410/wATeG9estJ1rTbe5sjLqOnN fWotbg27yF40
lhZW32sOH34C+ZlT95OWriOT7N/maximeb3XwOWfR9Oi1vWPD/iS90u/1a5t 5/FvhRL2EW2o
XKXUjzwLNGPtAlTCzIY1CNIvkjll5nmdKLtNWf3/AKFSpdmWPEHwk1TUtBt9 Fi1/wx4e0tPC
2s+HJrPRPCb2cMK6gys1xGguyIVVooDsIbcVmJK7sxL+18P3/P8AyF7J9zXj 8BeILDxpd+Ot
M8X6fa+JruWR7ia90KWSyjgmtNPgl/cLcpIpL6ZC6sZTtV5FZWK71Fm+H7/n /kHsvMXUPhvL
PpXhLTptZ06Wx0vWNQ13WrfU9EaaPUGvhdC4UJ54EEJF/dBVkExUbNxby5N5 /a+H7/n/AJB7
LzOu+J+my+IodFvdK1EaPq2h3x1KyuL2za4toy1vNbMZ4VkjcoYriXG2RCrg MeEZSf2vh+/5
/wCQey8ziPD3w68TaP8A8ItDJ48tby20HxTqHiWSbUPD5FzcxXYuAVlaOdI0 fF7dfvFjC58s
+UgjcOf2vh+/5/5B7LzF8K+APF3h6Kz1S38baN/wkNpdaxKLy58NzfZFtdSu 0vJleAXgcMJ4
12SeaAE3K0bFTIp/a+H7/n/kHsvM9P8ACV7d6b4et7bXdRm1K+UGS6vDarbo NxLZEYJ8uIZ2
qCWYKvzsxV3J/a+H7/n/AJB7LzM/x54e8BeNDat408FaNrosw7Q/21pkNyLV X27mxIp2Btq5
6fd5HynB/a+H7/n/AJB7LzNDwqnhzwvoMGi6BoVvoul2+5o7OztUt4bdWYsW 2KAFDMxJ4zks
T0Yg/tfD9/z/AMg9l5nDfHvwhrHxB1Lw9LaeJLLRLPQ9SttbSO60Z7mQ3EJf Y0jidAISH+7t
3AqTuGDjWnnmHjp/n/kenluLhg+fmjzc0HHe1r212exD408Eavr+s+DfFVx4 ns7TxN4Ya6Zb
ptGkNlJFcRmNi9ubjenyiPDeacFXJGMhdI5/hk3/AMH/ACMsLVhQ9onG6k+9 ra37fojk/hb8
Db3wjq3gObUPG8d9YeDhqDW8Q0RoJZUvFbe00hnYABmyMKOAQfukjV8R4Z7L 8/8AI66mPg4y
UIWbt17fId4I+CV94U0LwOln42gOqeDZ7+Wyu7rQ28hre8U+Z58IuA2dzEq4 dQACGU7Was5c
QYaX9P8AyMKuKjNt8u/n/wAA6zx18PYvEXgbQ9Nl1v7Dq2j67H4mS/Glolv9 pErysZLdGU+S
xmk43+Z/E7syuzRHPcOn/wAP/kRQxPsZN2umrEfxs8Da18QvhB/wgl54vhs4 rkCTU7640Uu5
AlSVDGqTIIYwVKgN5jbQNzbldylnuHu3/n/kGGxCoVva2v8AP/gDvGfgfV9f 1zwd4rn8T2dp
4l8Mtdlbg6NJ9hkhuIzGfMt/tG9MKI8N5vBVyVAyFuPEGHV/+D/kOGK5FKKW jf8AXQ5/wH8E
bXwrqvw5kj8UTy6f4Ltr4NDcadiW6ku1fzZXk8zEUe5gVTaSoVgzHBK1/rDh +n6/5Gs8wnLm
01dvw+Rp+Cvhk3h79lbWfgzeeJTcR32n31hHqi6WYWto7pX/AHkkRlbdh5HP 3l44IG1mrGrn
eHqO/wDn/kcmLqPEVPaPQ6Lxb/a/jf4f+G4NR0j/AIR+9k1DSdY1e1mkMz6c LaeK8MYZRtlJ
lhSHdlAFZ5OfLKHP+18P3/P/ACOX2Xmd0ut2wyXjmQD5nZkIEa9mb/ZPHP1z ja2D+18P3/P/
ACD2Xmcv8XLSXxH4dtf7KAtdY02/tdVsprkNGI2ilVmRpFBaFJ4vNt3cBiI5 pMo6h1Is3w/f
8/8AIPZeZL8R9KufG/hiDw7bOltazajaNqi3oIMllHKJXi8oDEqTrF5LIxVR HNIWBKGNuzD4
mFePNDa5Elyux2kGAhAJwDxk10akXHk0BcTNAXDNAXDNAXDNAXDNAXDNAXDN AXDNAXDNAXDN
AXDNAXDNAXDNAXDNAXDNAXDNAXDNAXPKtGyfihqw6fuUx3/5ZxD/AD9BWtOr KGWtr/n5/wC2
mFWClVV/5DqB0LYUEgncBz6/Trg9McD0rzvr03ZeR1LDRUU/I6fTciwhyc/I O/tXRCTlqyXF
LRErHg/Sr62BLQydQz9vm6YJAPHbAzW9OjGS1MZ1GiA8k557H6elbxpcqtF2 M1WkKRn3zwfp
6VXLLuP20gIz754P09KOWXcPbSAjPvng/T0o5Zdw9tICM++eD9PSjll3D20g Iz754P09KOWX
cPbSAjPvng/T0o5Zdw9tICM++eD9PSjll3D20gIz754P09KOWXcPbSAjPvng /T0o5Zdw9tIC
M++eD9PSjll3D20gIz754P09KOWXcPbSAjPvng/T0o5Zdw9tICM++eD9PSjl l3D20gIz754P
09KOWXcPbSAjPvng/T0o5Zdw9tICM++eD9PSjll3D20gIz754P09KOWXcPbS EZQTk5J6c9x/
P9f65FGXcPbSAhTjKq3XO4A5/wA8f/Wo5Z/zB7aQBccZJHQluSfXJ75o5Zdw 9tICoJLEAtjG
T6Z6evYfr60csu4e2kOU7SMFgMg8HHfPbt/n1ynTvq2S6je4A4UKBgAYABNH s0LmYZ+v50ci
DmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cq DmYZ+v50cqDm
YZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDmYZ+v50cqDm YZ+v50cqDmYZ
+v50cqDmYZ+v50cqDmYZ+v50cqDmZw2if8lS1X/rjH/6BFXNFr+zHp/y8/8A bTblvi1T/wCn
f6nUD/Vj6f0NeRBK69DtlLTl7aHUaf8A8g+D/rmv8q9CD0MHuSMMA/SqT1Hc yb/H2+bJA5H8
hXRT2OeoQkD+8PzrbXuZJ2DC+o/OjXuFwwvqPzo17hcML6j86Ne4XDC+o/Oj XuFwwvqPzo17
hcML6j86Ne4XDC+o/OjXuFwwvqPzo17hcML6j86Ne4XDC+o/OjXuFwwvqPzo 17hcML6j86Ne
4XDC+o/OjXuFwwvqPzo17hcML6j86Ne4XDC+o/OjXuFwwvqPzo17hcML6j86 Ne4XDC+o/OjX
uFwwvqPzo17hcML6j86Ne4XAY/vD86afdg2HH94U7iDj+8KT1AOP7wo0AOP7 wo0AOP7wo0AO
P7wo0AOP7wo0AOP7wo0AOP7wo0AOP7wo0AOP7wo0AOP7wo0AOP7wo0AOP7wo 0AOP7wo0AOP7
wo0AOP7wo0AOP7wo0AOP7wo0A4fRP+Spar/1xj/9Airjj/yLH/18/wDbTpj/ AL+v+vf6nUD/
AFY+n9DXlw6eh0v4n6nUaf8A8eEH/XNf5V3Q2M3uSv0P0oe4iCGNHnnLIrHz Mcj/AGRVqTRD
jckEEWP9Wn5U3NgoB5MX/PNPyo52PlQeTF/zzT8qOdhyoPJi/wCeaflRzsOV B5MX/PNPyo52
HKg8mL/nmn5Uc7DlQeTF/wA80/KjnYcqDyYv+eaflRzsOVB5MX/PNPyo52HK g8mL/nmn5Uc7
DlQeTF/zzT8qOdhyoPJi/wCeaflRzsOVB5MX/PNPyo52HKg8mL/nmn5Uc7Dl QeTF/wA80/Kj
nYcqDyYv+eaflRzsOVB5MX/PNPyo52HKg8mL/nmn5Uc7DlQeTF/zzT8qOdhy oPJi/wCeaflR
zsOVB5MX/PNPyo52HKg8mL/nmn5Uc7DlQeTF/wA80/KjnYcqDyYv+eaflRzs OVB5MX/PNPyo
52HKg8mL/nmn5Uc7DlQeTF/zzT8qOdhyoPJi/wCeaflRzsOVB5MX/PNPyo52 HKg8mL/nmn5U
c7DlQeTF/wA80/KjnYcqDyYv+eaflRzsOVB5MX/PNPyo52HKg8mL/nmn5Uc7 DlQeTF/zzT8q
OdhyoPJi/wCeaflRzsOVB5MX/PNPyo52HKg8mL/nmn5Uc7DlQeTF/wA80/Kj nYcqDyYv+eaf
lRzsOVB5MX/PNPyo52HKg8mL/nmn5Uc7DlR//9k=
Content-ID: <part2.06060805.05040907@resnbl.com>
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAGKAZMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD0VgF1eJh1eBw3vtZcf+hN +dQx3PkeHR5b
FW+y+ZkHncy7ifzJNTyf8hW3/wCuEv8A6FHWBJcMdH8tQSfsoUAd/kohG6fo EnZo62aOxeWW
1t5Jbe5TGyWS93LncFA27yeSQOV7461BFeuVZZdvmI7Rtt6EqxUkflVSfWbK W4iddQnREmEp
X7PdZPIOOGAxx0II9utZi3u953UNteeV1ypBILsQcHnoaqnTSloKU79B0Hjq wl1Ce1lxbpCH
LTyzxBAFOCc7ufwzjo208VebxXoyWiXbavYLbPnZMblAjYODhs4PPFYWqm5u LCZLJhFcPtyw
cxl1B5XeASuRkbgMjORWRpGkXNnfPdXAj+ZZdqm4knZd4iH33G4/cPP0/Dbl ZF0d8dZtArMb
uEBCqsTIOC2NoPucjHrkVzln8QYL+6lS2WzmhWdYUaK9VpP9aIyzRgZUZOVI JyOu3IrFtrCa
HUNLjbd5dvax/adq/I7x8RgE+7Men8K9O5JpN072x8yICKWR2+Y5w1wsoxx1 wp/H86fLr5Bf
TzO6ttesL2eaC1vraeaA7Zo4pVZoz0wwB46Hr6VWh8UWT6lPp81zbwXKTeVF E8yh5vkVsqp5
/ixxnpXFaPpd9pETeVDC1zDbNBbTy6hPKrdMZibiMHaCQpOMYFX5LGVzdsBE Hnv4brP+ynl9
eOvyHH4UKGq/rqDe50Vp400S8j3Jqlmp81odj3CBtwbbjGe/GPXI9amh8R21 1fw29pLFcRSx
SSedFKGUFGVSvH+968YriJdHvbiO6hlW1MbQ3UULbiS3nOHG4beMcg4J/pWh Z2U1tr099mPy
pN+FXr8yxAdv+mZ/SiMNVcG+x12oX9xHZlrUqJA6ZZozIFTcN7bQQWwu44By cYFMv7jV7fTX
njeyGE/0a4/1sd+5GUWJVcEZHJLHCgH76guMa7uZng2wjLb0LKZDHuTcNy7g CVyuRkcjORT7
7VdRubCW3WG0KFMWluP3aWDqMI0bKuTgcEEYbJHyqSpmUXfQaaN24aK6C+Zu DJnY6MVZc+h/
ocg4GQaZb3BL+RMR5oGVYDAkHqPQ+o7fTBOT9sPoaa9zvGDuGDkEcFT6j3/z 0onS5loCnY6G
is+y1JZisMx2zHgHGFf6eh9v5jmtCuRpp2ZqncKKKKBhRRRQAUUUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBQVZ 11WHz5I3/cSY
2RlcfMnqxrHsbWe4s4njTcAijOQOwrdk/wCQrb/9cJf/AEKOqvh//kFJ+H/o IrWnJxTaIkru
xWTS7x3VFhyzHAG4dfzqy/hzVkRna0wqjJPmJ0/Otq0/4/IP+ui/zro7v/jz n/65t/KrVeTE
4I4P/hGdX/59P/Iif40f8Izq/wDz6f8AkRP8a7AautzdC306E3e19s0wbbFF 6jdzub/ZXPPX
b1qG21iX7VJb3NtKwW4MP2mOMLGCfuggsWJ6DIBGfTtXtZGfunK/8Izq/wDz 6f8AkRP8aP8A
hGdX/wCfT/yIn+NdhBqk82oT239l3SpFJsM2+Ir90HJG/PfsD/QVf+EmiDEP p1+gBYFmVMAK
21jkP0BIHvnjPNHtZDfKtzmf+EZ1f/n0/wDIif40f8Izq/8Az6f+RE/xrs47 i6XW3tZXhaBo
TLGFjKsuCBgncQevoKY+rraXRh1GE2qM2Irgtuif0Bb+BvZsZPALUKrJg+Vb nH/8Izq//Pp/
5ET/ABo/4RnV/wDn0/8AIif416FRS9tIrkR57/wjOr/8+n/kRP8AGj/hGdX/ AOfT/wAiJ/jX
oVFHtpByI89/4RnV/wDn0/8AIif40f8ACM6v/wA+n/kRP8a9Coo9tIORHnje GNWZSrWQYHqD
IhH86li0LxDb48lHwP4JJVcfq2fyIrvqKUqnNugUbbHEf2d4m/59bb8h/wDH KP7O8Tf8+tt+
Q/8AjldvRUadite5xH9neJv+fW2/If8Axyj+zvE3/PrbfkP/AI5Xb0Uadg17 nEf2d4m/59bb
8h/8co/s7xN/z6235D/45Xb0Uadg17nEf2d4m/59bb8h/wDHKP7O8Tf8+tt+ Q/8AjldvRRp2
DXucR/Z3ib/n1tvyH/xyj+zvE3/PrbfkP/jldvRRp2DXucR/Z3ib/n1tvyH/ AMco/s7xN/z6
235D/wCOV29FGnYNe5xH9neJv+fW2/If/HKP7O8Tf8+tt+Q/+OV29FGnYNe5 xH9neJv+fW2/
If8Axyj+zvE3/PrbfkP/AI5Xb0Uadg17nEf2d4m/59bb8h/8co/s7xN/z623 5D/45Xb0Uadg
17nEf2d4m/59bb8h/wDHKP7O8Tf8+tt+Q/8AjldvRRp2DXucR/Z3ib/n1tvy H/xyj+zvE3/P
rbfkP/jldvRRp2DXucR/Z3ib/n1tvyH/AMco/s7xN/z6235D/wCOV29FGnYN e5xH9neJv+fW
2/If/HKP7O8Tf8+tt+Q/+OV29FGnYNe5xH9neJv+fW2/If8Axyj+zvE3/Prb fkP/AI5Xb0Ua
dg17nEf2d4m/59bb8h/8co/s7xN/z6235D/45Xb0Uadg17nEf2d4m/59bb8h /wDHKP7O8Tf8
+tt+Q/8AjldvRRp2DXucR/Z3ib/n1tvyH/xyiu3oo07Br3OGk/5Ctv8A9cJf /Qo6q+H/APkF
J+H/AKCKtSLKmrW6zRNFIIJcoxBI+aP0JH61V8P/APIKT8P/AEEVK+Fj6m1a f8fkH/XRf510
d3/x5z/9c2/lXOWn/H5B/wBdF/nXR3f/AB5z/wDXNv5Uo7AyCXTYnvlvYpZo J8jzDEwAlUdn
Ugg/XG4diKgOjZRl/tG75uBcZxH1HOPudOnv71PNqlvFerZRh57okbooRuMa n+Jz0UY55OTj
jJ4psus2MN2LZ5JBIZFiDCFym89F3gbc89M1epm+TUV9MD3xuVu7qNWZXeGN gEdgMAk43dhw
CAccjrmo3h6N4TG+oXjZEgLHy8kOwY9E7MMj+o4qxNrmnwXBhkmcMHEZYQuU DnopcDaDyOM5
ofXNPjvGtHlkE6EBk8h8gE43fd+7n+L7vvQrg+TqNGkSjUFvDq16zqNu0rDt K5zt/wBXnHHr
n3qaPTI1vzezTTXEwJ8rzWG2EHsqgADuNxy2DjOKdHfxy6lJZKrBo03ksjrn nHGV2sPcE1Xi
8QabNN5SSy7hJ5TFreRVV842sxXCnPYkdR6ihX6A1DqadFZ8Os2019LZrHdi SN/LJNrIEzjP
3tuAOe5H8q0KRSaewUVlzeIdNt79bOSWYStKsIYW0hj8xsYXzAuzPPTNNk8S 6VFqD2DzTC6R
wrR/ZpcqCcBz8v3M8b/u+9UoyfQvkl2Naism48SaVa3f2aWeQOJFhLi3kaMS EgBDIF2hskcZ
zzUR8V6cLo2/2bWN+/Zn+xrvZnOPveVtx75x3zSsxOLWrNuiua13xVPpF9cW tvpn2sw20Muf
P2bpJZvKSP7p6/Mc+3Q10o6c1pOjOEVKS0e34f5oQUVS1K9e1hSO3VXu528u BG6bv7x/2QMk
+wx1IqrfeJdL0u5NrezypchAwRbWVjIO+wBTvxySFzgAk4xRGjUnblV/QDXo rOOqwy6jbWcE
zCSVPOy1rIySR4/hk4QHJU9ScduciK48S6Xbak+nyyXH2iMoJAtpKypu+6WY KVVT/eJxweeD
gVCo9FFvrs9g8zWorMvPEGm2F2baeaTzFx5hjgkkWEHoZGVSsY75YjjnpWnU ShKKTkrXAKKy
7jWrdNTi05WuI7h5QoaSwmMT8biokwEztB53HGOh6UuoeINO0ycw3Lzl1UM/ k2sswjB6Fyik
LnB+9joatUKjaSi7vXZ7dw2NOiua13xVPpF9cWtvpn2sw20MufP2bpJZvKSP 7p6/Mc+3Q1sR
apbvfGylD29zk7ElGPNA5yh6MMc8cjuBROjOEVKS0f8AwP8ANCbS3LtFUptU t4r1bKMPPdEj
dFCNxjU/xOeijHPJyccZPFLc3Tpe21pAFMkhLyFh9yMdT9SSAPqT2rOwuZFy iqEus2MN2LZ5
JBIZFiDCFym89F3gbc89M02bXNPguDDJM4YOIywhcoHPRS4G0HkcZzRZj5ku po0VnPrmnx3j
WjyyCdCAyeQ+QCcbvu/dz/F933qaO/jl1KSyVWDRpvJZHXPOOMrtYe4JpWDm Xct0VmReINNm
m8pJZdwk8pi1vIqq+cbWYrhTnsSOo9RT4dZtpr6WzWO7Ekb+WSbWQJnGfvbc Ac9yP5U7MXNH
uaFFUo9Ut2v2sZQ8Fzk+Wkwx5oHOUPRhjnAOR3Aq7SGmnsFFFFAwooooAKKK KACiiigAoooo
AKKKKACiiigDktY/5GZP+uD/APtOsnw//wAgpPw/9BFa2sf8jMn/AFwf/wBp 15dqtlb3Eto8
1rFK4gUKXiDH7w4GVOedvHzckDHzeVcVThz3QpO2p6raf8fkH/XRf510d3/x 5z/9c2/lXg3h
7TtPTxHpLpZ2q7buAqwRRj548EHd/wBc+dxzleX3g3XvN3/x5z/9c2/lTnTU NEwjLmKa6UbW
887T5lto3fdPb+WGjf1YAYKufUHHqCarNoUkurC9llsyVm8wSJZ7Z8Donmhu mODxyOK07i/t
rSWGKaUCWdtsUYBZnPfCjnA7noBycU19SsIrsWkl7bJckgCFpVDnPT5c5qU3 uQ4w1RXWwvop
mWC/jjtGlMhT7PukGTuYBy2MEk9VJwfpSxWd/Hqkt0by2MMuAYvszBgozgbt +M89cfhU8mpW
EN0LWW9tkuDjETSqH56cZzSHVNPWXyjfWokEnlbTMud/93Gevt1o1KaiVjYa idXF6L218sKY
/L+ytnZuzjd5nXjrj8KoWNjqc7XcVwPs1pJdNL5csSs7qWzhXSQ46DOVzzwf Tajv7aa+ks4p
Y3liXdIFkUlPYjOR+WKZHq+mzTpBFqNo8z52RrMpZsZzgZ56H8qE2JqL6kbW N2uoSTQ3qxW8
rq8kfk5ckADAYnABAGflJ64I7aFUY9a0uW8azTULVrlX2GLzRu3egHf8Kmgv 7a5nmgilBmgO
JIyCrL6HB5wex6HtRqNON9zDPhiWXXxqc02nFln80TR6eEuto+6hmD8jGFPy 8rx3zV2DT9Wi
1qe8bULJrWYgGEWThwq52jf5uM88nbz6Cteiq55GrqSe/oY66XqcNwyW2qRQ 2DTGYx/Zd0w3
NuZRIW24JJ6oSATznBDD4N8Lm6N0fDejm4L+Z5v2GLfuzndnbnOec1t0VLdy ZSctwqk1tfHW
UuRqGLAQFDZ+SPmk3Z37+vTjb+NXaKcZOOwijbWcg1Ge+uSrSn91CqkkRxde /diMn6KOduTT
XS9THiNtTN9YNCyCERGxbzFjBJwJPNwCSRk7cHaOOK2qKtVpq9uqtstgMWfT dZk12K/TU7Fb
eJWjWBrB2bYxQtl/NHzfIMHbgZ6Gop9E1KZNQH9pWgN3dRzAmzY7I12jYf3n OQo546txyMb9
FUsTUVrW08l3v27gYVxoV5NNcwLqMSaXdSGSeAWx85wR8y+bvwFOMfczgkAj gjQa2vjrKXI1
DFgIChs/JHzSbs79/Xpxt/GrtFS605b/AJL/AC389wMYveahrNqH0y6tYLOV 5POmkiKynYyD
aEdj0Yn5gPzqpd+G7y916PUZNQto1jlVkeC1aO5EakHyjKsmGQkcqykHJ4zg jpKKuOJnB3hp
pb+r3AKzZNKa8uzJqM63MCNmG1EQWNfQsCSXYepOO4UEZrSornTsJxUtGZq6 UbW887T5lto3
fdPb+WGjf1YAYKufUHHqCamtLWSO6urqcqZZnAXachY1+6P1JPuxq5RTuLkS 2MRtCkl1YXss
tmSs3mCRLPbPgdE80N0xweORxVlbC+imZYL+OO0aUyFPs+6QZO5gHLYwST1U nB+laVFFw5UZ
0Vnfx6pLdG8tjDLgGL7MwYKM4G7fjPPXH4Uw2GonVxei9tfLCmPy/srZ2bs4 3eZ1464/CtSi
i4cq2OcsbHU52u4rgfZrSS6aXy5YlZ3UtnCukhx0Gcrnng+mm1jdrqEk0N6s VvK6vJH5OXJA
AwGJwAQBn5SeuCO2hRRcORGbJpTXl2ZNRnW5gRsw2oiCxr6FgSS7D1Jx3Cgj NaVFFK41FLVB
RRRQMKKKKACiiigAooooAKKKKACiiigAooooA5LWP+RmT/rg/wD7TrzPUEy1 uNmd8Cj7ud3V
cfdOfv4x8/39uPn8q49M1j/kZk/64P8A+068z1BMtbjZnfAo+7nd1XH3Tn7+ MfP9/bj5/KuN
cPuyamxLoD/8VHpb7+t3Ed27rlxznd38zruOfM6v5mbv267/AOPOf/rm38q8 R0B/+Kj0t9/W
7iO7d1y45zu7+Z13HPmdX8zN37dd/wDHnP8A9c2/lTr7oUDPi0uaw1R7qy8m SO4YfaBcFjIB
6rJySB2Q8ehUcVVk0e7m1UTvDbpGtyJvMW6kOQOmYSNm4gY3Z46jmugorK73 D2atYxvsF4kk
kC22ny2z3Bn86YkuCW3cptwSOgO4dB6YpUs7w63PdS2Ng0MqrF5hmJkCAk9P L75HGccd62KK
Lj5TJMWqf22LoW1n9nCGLP2lt20sDux5eM4HTP41mWEN3dm+t0so44JL0zNN MkkUmN+QQrJh
jheCGGOPTnqaKE7CcL9f6tYzfI1CLUpmgFr9mnkV3kkZt64UKQFAwc7eu4Yz 0OOYp9Ln1HUo
573yYobZiYBAzea2e5k4Kgjqq9ccsRxWvRRcbgnowooopFBRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQByWsf8jMn/XB//adeZ6gmWtxszvgUfdzu6rj7pz9/GPn+/tx8/lXHpmsf 8jMn/XB//ade
Z6gmWtxszvgUfdzu6rj7pz9/GPn+/tx8/lXGuH3ZNTYl0B/+Kj0t9/W7iO7d 1y45zu7+Z13H
PmdX8zN37dd/8ec//XNv5V4doshXXtOkD8/aY2D7vVhzndznzOu458zq/mZu /YJrqZoJFL8F
SDwPSqrK4oGvRUctxFAYxI2DK4RBgkluTj8gT+FO3p5nl7l343bc849cVgWO opu9PM8vcu/G
7bnnHrinUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHJax/ yMyf9cH/APad
eZ6gmWtxszvgUfdzu6rj7pz9/GPn+/tx8/lXHpmsf8jMn/XB/wD2nXmeoJlr cbM74FH3c7uq
4+6c/fxj5/v7cfP5Vxrh92TU2F0Z/wDieae+/rcxndu65Yc53d/M67jnzOr+ Zm79bl/1L/7p
ryTRn/4nmnvv63MZ3buuWHOd3fzOu458zq/mZu/W5f8AUv8A7prSqKBbtyL7 VZbnOYbXMEXu
/wDG34cL+DetQ/8ACPxf24dT+0Tfez5HmN5Y467c4zu59PbPNbFFcw3FPcx/ +Efi/tw6n9om
+9nyPMbyxx125xndz6e2ea2KKga9tFvFs2uoRdMNywmQbyPUL1xwfyo8h2S1 J6KKKBhRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHJax/yMyf9cH/9p15nqCZa3GzO +BR93O7quPun
P38Y+f7+3Hz+Vcemax/yMyf9cH/9p15nqCZa3GzO+BR93O7quPunP38Y+f7+ 3Hz+Vca4fdk1
NhdGf/ieae+/rcxndu65Yc53d/M67jnzOr+Zm79bl/1L/wC6a8k0Z/8Aieae +/rcxndu65Yc
53d/M67jnzOr+Zm79bl/1L/7prSqKBu1i/2Tff2+b7+0ZPsnQW/HTr97bnG7 +HPTvj5a2qK5
utymr6MK5N1uG1ZfLH7v+0cy7WjBL5GN247v9XjATnrmusqA2NobwXhtYDdA bRN5Y3gem7rR
1TFOPMrGGt/53iG4s4/EcShGUpb/ALouXydydMlQByPvf7VVI9V1I635cupW EB+1GM2c90qt
s3YGE8rcWK4IO8gk+nFddRSQnBvqc9HcLba/cQ3Ot3O9plMNmRGd6lR0UJu2 g55BwMEk9TUU
utJbXC282r7biO+CNE3lgmNiMbht4XB4PHbk101FNb/15A4uzsznFv8AzvEN xZx+I4lCMpS3
/dFy+TuTpkqAOR97/aqH+1TDqE8j68jxR3624t2MIXawGQSAGyCWxz/Dznmu popIHFvqFclJ
r00XiJUOoQLbm68hraWZN6jpnYI8qCRkEvzkccgV1tFPrcck2rJ2OW/tUw6h PI+vI8Ud+tuL
djCF2sBkEgBsglsc/wAPOeauTy3q38unLezrPNKssMgSPCQ/xgfL2wRzk/Mv PNbtVE023jv2
vR55nYFctcSMoB6gKW2jp2FC0sJxff8ArX9DJjuFttfuIbnW7ne0ymGzIjO9 So6KE3bQc8g4
GCSepqnb3sFlPLNBq1vHbf2j5P2VPLEfzH5snG7dyTwR06HmutooW9/66f5A 4t9f61OfTVLG
LxU8LatbSM8WwRu8QaN9wGwEAN+BJqt/aph1CeR9eR4o79bcW7GELtYDIJAD ZBLY5/h5zzXU
0Ulpb+utwcW76/1Y5STU55LyOMa15N0955L2KpGSke8gEAqWGQAdx4O7jGRX V1VfTreW9W7f
zWkUgqpncxggcHZnbn3xVqmtrDSabbCiiigoKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKAOS1j/kZk/64P/7TrzPUEy1uNmd8 Cj7ud3VcfdOf
v4x8/wB/bj5/KuPTNY/5GZP+uD/+068z1BMtbjZnfAo+7nd1XH3Tn7+MfP8A f24+fyrjXD7s
mpsLoz/8TzT339bmM7t3XLDnO7v5nXcc+Z1fzM3frcv+pf8A3TXk2iEvr+nE Py11F827rlhz
nd38zruOfM6v5mbv2KeykS3lYsmAhPX2rSqxQNSsXydb/t8uZ4v7N6AbPnx9 7+9jGflzjPt/
FW1RXN1uU1fQzZP9O1dYusFnh39DKR8o/AHP/AlrSqKC3itw4iXG9zI2STlj 1PNS0AkFFFFA
wooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDktY/wCRmT/rg/8A7Trz PUEy1uNmd8Cj
7ud3VcfdOfv4x8/39uPn8q49M1j/AJGZP+uD/wDtOvM9QTLW42Z3wKPu53dV x905+/jHz/f2
4+fyrjXD7smpsS6A/wDxUelvv63cR3buuXHOd3fzOu458zq/mZu/brv/AI85 /wDrm38q8Q0K
QL4h02Uvx9qiYvu9XHOd3OfM67jnzOr+Zm79pubuBrWZQ+SUYDg+lVX3FTRz c9z4kv8Axnc6
fbzRWtjaRwyN5Nwu50dn+Yh4HycJ90FQP7xzxOPFGorcFZNKtRCmorYSOt6x YMxXDBfKAIww
7itJPDWmx6tJqafbRdyMGdhfz7WwSQCu/aVGThcYGTxTbrwtpF7dtdT28plM qz/JcyookXGH
CqwAbjG4DJGRnk1mnHS51udJ9On6epSh8U3Lai0E+mJHbpqBsGmW4LHeVDIQ pQZByM88Z43c
4VvEmpzGS40/RFurCO8+yM/2kiY4kEbuIwhG1TnqwOFJ4q2fCmkNI0hjutzX Quz/AKdPjzR0
bG/9OnT0qSXwzpU921w8M2XkErxLcyrC7gg7miDbGOQCcjnHNJOOl/62/wCC JypX0X9feUbH
U9dn8VanZva2RsbdogD9qYMisCdwHlfMT3BYAdAT1q3Df3h8Wz6fPGFg+yCa HZMGBAfBJXyw
Vbn+8wwBwDU154f02+vheXEMrS/JuVbiRY32nK70DBXwf7wNOOh2J1oauRc/ bQuzd9ql2bcd
Nm7ZjvjHXnrzRdEuUHfTp+P3mUfFc2w339mj+yBefYzcef8Avd3meVu8vbjZ v4+9uxzt7UQ+
KbltRaCfTEjt01A2DTLcFjvKhkIUoMg5GeeM8bucaB8M6Q1+Lw2reYJvtHli Z/K83/np5Wdh
bvu25zz15qM+FNIaRpDHdbmuhdn/AE6fHmjo2N/6dOnpQnHr/W3/AASnKlrp /X3/ANdjarn7
DU/EFzrt9ay6bpi2Ftc+V5yX0hlCmNWB2eVgn5h/EMZxzjJ6Csq48OaXdaqu pTwSPOrK+03E
nlMy/dZot2xmHGGKkjAweBiVuYdDAtvHlxc64LWLQbySwN21qLmOC5Zshyhc /uPK2bgST5pw
vOM/LVi+8XX1n4ni0r+w3NrJcRwfapGlQfNj5gxi8ojnAHm7ieMZOK1W8M6a dSN+hvopjKJW
SDULiKJn65MSuEOe+V55znNNj8LaVHqRvwl2ZTMbjy2vp2h8wnO7yS/l5yc/ d4PI5oXS4PrY
gsNT8QXOu31rLpumLYW1z5XnJfSGUKY1YHZ5WCfmH8QxnHOMm1e38y+JNL0y F9iyxzXMxwDu
SPaoXnplpFOf9n3pbjw5pd1qq6lPBI86sr7TcSeUzL91mi3bGYcYYqSMDB4G J7rThcanY36S
+XNa71Py53xuBuTrxyqNn/Z96a6AQWt9MPEt/pkzF0EEV1A2ANqsWRk464KZ yf7/ALUfaZpv
FBtUnlSC3tt8kXlgLIzHAOWXJwAfunAJ57VPbacIdVvdQdxJNcBI1+XGyNAc L7/MznP+17U9
7BW1WLUFnlR0iaJo127JATkZyM5B6YI685pLp/XcH1t5foW6KKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA OS1j/kZk/wCu
D/8AtOvM9QTLW42Z3wKPu53dVx905+/jHz/f24+fyrj0zWP+RmT/AK4P/wC0 68z1BMtbjZnf
Ao+7nd1XH3Tn7+MfP9/bj5/KuNcPuyamwujv/wATuwff1uYzu3dcsOc7u/md dxz5nV/Mzd+s
Sf6t/oa8n0Zidc09g2SbmM7t3XLDnO7nPmddxz5nV/Mzd+tywyiJyY3ACnna a0qlUtmbtFFF
cwBQeATjPtRRQBzZ8Xotv5h0XUxMb37CLfMHmGTGenm4xjnOenPTmnnxjYR+ IY9FnikiupJB
GuZ4G+YruGUWQyDI7lQKvHQ7Y68NX3y+aEx5WR5e/GPMxjO7aduc4x2rOPg2 3EqtFqeoQxx3
hvY4ozFtSViSx5jJbO4/eJx2xgVS5epvek0/6/q2n4jm8WxjWbrS10fVZLi1 KmUxxIyrGxws
mQ/Q9dv38A/Lwa6Ksy30YW2uXeqJf3ZN0FEluwj8v5RhcfJu45/i71p0nYzn y3905J/F81n4
gvdHezk1S8W4Agt9ORFkjhMavvl8yUADJK78gE4GM11o6elc3N4Ohl1s6xHq uoQXxuDMZYhC
CUKKnknMZzHhQcHnIBzkAjpKXQh7nEt8T9HXVDYGD96JvJz/AGnp/Xdj7v2n d+G3Ptniu2oo
o6B1OXuPHem2/ilPD32e4lvGmWH93JCSGYA5MZk83aAcltm3AJzVuz8QXl3r V3p58PajHFbz
+Sbsy25jxsDBiPM3gHcMYU9RnByBlNp95PqAnkk1y6tTc/bILGZoBFhW3DLG MSIQ2CsZfnKA
4AcJNLaXU+sNfwJrMcUzpcfZI5Y4opwgA3OSokRsKuI94DfKGAHmbaUdFf8A r+tTd4ed3t96
/wA/617HWUUyKRZoklUMFdQwDqVOD6g8g+x5p9SYNW0YUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAclr H/IzJ/1wf/2n
XmeoJlrcbM74FH3c7uq4+6c/fxj5/v7cfP5Vx6ZrH/IzJ/1wf/2nXmeoJlrc bM74FH3c7uq4
+6c/fxj5/v7cfP5Vxrh92TU2JdAf/io9Lff1u4ju3dcuOc7u/mddxz5nV/Mz d+3Xf/HnP/1z
b+VeI6A//FR6W+/rdxHdu65cc53d/M67jnzOr+Zm79uu/wDjzn/65t/KnX3Q oE1FFFYlhRRR
QBzk3jC10+/ubTVInhkW7+zWy2sct08/7oSZ2pHlTtJyOQMda6McjNci/hC+ TxXL4js9UtYL
2aXbKWsmcSW2xVEJ/ejkFQ28Y57YJB3zaah/b4vBqf8AxLfs3lmw8heZd2fN 8z73Tjb070/6
/r+t/LUHv/X9f130IYNSvD4in0y4s4I4RB58E8dwXZxuCkMhQBTk9mamL4o0 ltS+w+dOJPNM
Ala1lEBkzjYJivlls/LgNnPHXiqx0jXj4lGpjV9NFuF8ryP7Nk3+VvDY3+fj dxjdtx/s1mRe
Abe01z7dbW3h4xfajc7rnRRJdKS29sTiReck7SVJHHXFKPS/9a/5A+tv60/z NmHxbo8+qtpi
S3QuUmNu++ynWNZMZ2mQoEBIwRzzkYzkU2fxjolte/ZJJ7gymb7OrJZTOjy5 wUV1QqzA5yAS
RtbONpxXk8P6w8twy6tYhZdRS9AOnuSqqANmfO5Pyr831454zW0nXotftdOg VjocN79sErW8
QxlmkKGTzi5wzEDES9stjJIul/62/wCCD62/rf8A4BuWvinT7vWJ9Ljg1MXE M3ks76bOIt20
NnzNm0DB6kjPbIIJhsPFtpcajJpt2pgvkuWtyIkllhBHKhpdgRWZcHaSDyMZ yCZ30nU11qW5
tdWjt7G4lSaeAWgaVmVQuFkLbVUhVBGwnrggkEVDoGsGJk/taxydSF7n7A/3 Ac7P9d1yB83/
AI7Qt1f+tV/wQltp/Wj/AFsdLWIfFenC6Nv9m1jfv2Z/sa72Zzj73lbce+cd 81t1iHwb4XN0
bo+G9HNwX8zzfsMW/dnO7O3Oc85o6h0NusuDU7p9fm06awEMAiMkM5mDNLgg H5APlHzcc5OD
kDjOpWE+l623iRNRGqaeLRVMX2c6e5k8skEjzPOxu467ce1C+Jdge2gja/dL qP8AyD4v7KF0
LM3RucS+aTtGItuNm8hc7gc5O3HJvNrmnL4gXQjcY1J7Y3SwbG5i3bd27G3r xjOaotoF22pf
8f0A0o3Quza/ZmMplBDf60vjbvAbGzPbOKuW1tqg169urm+U6cY0jtbNEX5S OWkdsbtxPAAO
ABnqeBbK/wDWn+YPd/11/wAjSooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAKKKKACiiigDktY/wCRmT/rg/8A7TrzPUEy1uNm d8Cj7ud3Vcfd
Ofv4x8/39uPn8q49M1j/AJGZP+uD/wDtOvM9QTLW42Z3wKPu53dVx905+/jH z/f24+fyrjXD
7smpsS6A/wDxUelvv63cR3buuXHOd3fzOu458zq/mZu/brv/AI85/wDrm38q 8R0B/wDio9Lf
f1u4ju3dcuOc7u/mddxz5nV/Mzd+3Xf/AB5z/wDXNv5U6+6FAmooorEsKCQA STgCiigDK/4S
fQPsv2r+3NM+z7/L837XHs34ztznGcc4qaLXNJnv/sEOqWUl4M/6Olwhk4Gf ug56VmN4fnbx
Asu6L+yRP9tMW47zcbdv3cY2/wAfX7w6d6y7jw3r8urw3rzQXDQX/wBpVpdQ nVXj+YBBCFMa
FVI5+YnB5GapJM35KbT1/r+vzOlPiDRhOYDq9gJRN5BjNym7zP7mM/e9utaN c3BoMv8Awl2q
ald2GnzW15FHEsrSFpVVR90oUxgnk/N2HXt0lJ2M5qKfumPB4s8PXWqyaXDr mnPqCSGI2wuU
8zeBkgLnJI746YI6g1sVhfZdbttduXs00/7BdzRzSzzSOZY8IqsixhcNkIMM XGN2dpxg7tLo
Q9zEPjLwuLo2p8SaOLgP5flfbot+7ONuN2c54xW3WIfCmnG6Nx9p1jfv34/t m72Zzn7vm7ce
2MdsVt0dA6lKHWdLuLlbaHUrOS4ZmURJOpYlfvDAOcjv6UjazpS6j/ZzalZi +/59jOvm9M/d
znpz06VzR8Pa0LyaZbfTsvrCX4b7W+7y1Xbt/wBVwcDp0+Y8+tRfBF/DM0Cr b3Nub/7WJ59S
ulwDJ5hzbqQhcHIB3AHAJHUVaSe/9bf18jo9nT11/L+v+HOs/wCEg0X7D9u/ tjT/ALHv8v7R
9pTy9393dnGfatEEEAggg9CK4c+B7o68bv7TD9i+2b/Iy3+o3+eVx03edz/u 9+1dzSaVtDOp
GCfuu5zg8XIL64hm0XU4bW3ufsst8whaJHOMEhZC+07l524GecAHGo2t6Sur LpLapZDUmGVs
zcJ5xGM/czu6c9Olc6+jeILiTVrGa20yPTdSuzI9wt7I0qxbUUgR+UBuIT+/ gbu+OZzo2rB2
08WmmnTmvvtZvPtLifPm+b/q/KwWB+UNv6YPtSWy/rsZ63f9dzam17R7bURp 0+rWMV8QCLZ7
lFlIPT5Sc80q63pLmELqlkxnlaGHFwh8yRfvIvPLDByByMVjHR9VjuJLNNP0 WewkvTeG6uWZ
pVYvvyYdmGYfdVvMGMKccYMd1pfiP7a8dpDpTWP9oLeCSW5kWRxkEptEZCkH J3ZbOAMDORK1
t/Xb/g/cD0vb+t/+B95qxeK/Dk7KsWv6VIzOsYCXkZy7Z2r16nBwO+DU667o 76s2kpqti2pL
1sxcIZhxn7md3Tnp0rkZPCutTW7sbHR47p1vBlbpzgyzLKp3eSDyV2njsDz0 Bb+DLyDVI3ls
oru2F99tEj+ILxNjmTzCRbhTGxViccgNgEgZNUul/wCv63CXWx1cXiPQ59SG nQ61p0l8WZRb
JdIZcrncNoOcjBzxxg1FB4s8PXWqyaXDrmnPqCSGI2wuU8zeBkgLnJI746YI 6g1lSaRrn2m7
kjsNK/fatFdhjeOGMSKq5P7n7+EHHI5PPHOh9l1u2125ezTT/sF3NHNLPNI5 ljwiqyLGFw2Q
gwxcY3Z2nGCLVK/9bf8AB+4H1NO51CG1vLO0YM010zKiqBwFUlmPsOBn1Yet FvfRXF5dWgV0
mtiu4OB8ysMhh6g/MPqprPv7aZfFekagqO8IhuLV9oJ2F9jqx9B+6Iz6sKLS 1lk8XajqBjaO
FbaG0UspHmMpdyw9VHmKAfXdS7f1/X/BGaRv7MagNPN3AL0x+aLbzB5hTON2 3OdueM9KsVi2
9pdy+Lru+uNP0+O2it0gtrnygbqXPzP8+fljBIAXGSQT0xnao6C6hRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQByWsf8AIzJ/1wf/ANp15nqCZa3G zO+BR93O7quP
unP38Y+f7+3Hz+Vcemax/wAjMn/XB/8A2nXmeoJlrcbM74FH3c7uq4+6c/fx j5/v7cfP5Vxr
h92TU2JdAf8A4qPS339buI7t3XLjnO7v5nXcc+Z1fzM3ft13/wAec/8A1zb+ VeI6A/8AxUel
vv63cR3buuXHOd3fzOu458zq/mZu/brv/jzn/wCubfyp190KBNRRRWJYUUUE AggjINABRXEN
4Ltjqw04aPaf2H9q/tAt5Ue3ftK+Vt6/ew2cYx8uccVRbQdXi8TQ6qmjuJor 8s7WqWkSPb4Z
RtbiVjjaWDMB1wDgVSin1N/ZQadpf1956LRXFQ+FbSbxrql1eaDJ9mm8t7e4 DxrEsgGWkCq+
4SFsfPtzweRnntaTRnOKi7J3CivOrrwxPf8AjmPVG0S+jljvkl+0zNZtbmNC MEOv+kjIGQmd
obGRtzXotJbXIe9goriW+GGjtqhvzP8AvTN52P7M0/ruz977Nu/Hdn3zzXbU dA6hRXn8Wh31
tqst5b+H50m/trz0lR4Bi3ZcPj58gMQSR1ORnpxT/wCET1RNYa4ntL+5vjf+ at/FLZohiL5G
ZGQzgBPlKcg4wDtNWop9f60/zOj2Mdfe/r7z0yivNT4Gvv7QNiLOH+wTf7vs +U2eXv8AO8zb
j72f3Prt9ua9JAAAAAAHQCk0rXuZ1IRi9HcakscjyIkis0Z2uAclTgHB9OCD +NQ2N/b6jE8t
sZCqSNEwkiaMhlOCMMAfx6HqK5aPQLfT/F9zd23g6zmlublZ01QJAggBRVky f9ZvyGOFUglh
lhkkVP7GkXUX1ceFbk6p/a4dbkyW5lW36FlYy/KhXIKjBJY5XkmpW6/rqv8A MzlotP60Z3tY
lv4s0i51I2CPdrMJmt90thPHH5g6qJGQITxxzz2zXHQeELq28Xfb57TWprn7 eZ/7QtBpyoyF
8hWdgLjYFIVlyeAQMjFX4tL17+1by/a21A2sWqfaF02V7YR3CYwJI2VtwZSA +JGweOAcFSOt
v67f5hLS9v63O585ftHkYffs358ttuM4+9jGfbOakrj4Y57Xx1NfW3hG7iiu I/s897GbRRK2
8YkbEu9lAHcbsdqz10AW2tXWqW3g+RL06wksd1H9mD+SVAdgfMyFOHyvBO/J GScEdbX/AK1t
/wAEHpf+ul/+AegVBPdwW0tvFLJtkuHMcS4JLMFLHp7KTnpXGtokh1ku3huV 9U+2+auv74Dt
j8zdjcZPNAEfybAu3t0Oa29RVovGWiXMn/Hu0FzbKccCVvLdfzWOT/JoWtgN iG7guJriGJ8y
W7hJVIIKkqGHXqMEcjj8jU1YVmrTeNNUuYj+4jtILaQg8GUM74x6hXX/AL69 qigs47rx9dai
2itHJaWaWqam87jzdx3mNI8bSo4Jf1OOxwLoN9ToqKKKBBRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQByWsf8jMn/AFwf/wBp15nqCZa3GzO+BR93 O7quPunP38Y+
f7+3Hz+Vcemax/yMyf8AXB//AGnXmeoJlrcbM74FH3c7uq4+6c/fxj5/v7cf P5Vxrh92TU2J
dAf/AIqPS339buI7t3XLjnO7v5nXcc+Z1fzM3ft13/x5z/8AXNv5V4joD/8A FR6W+/rdxHdu
65cc53d/M67jnzOr+Zm79uu/+POf/rm38qdfdCgCXdtLdTWsdxE9xCFaWFXB dA2dpYdRnBxn
rg1NWAsgl8eSJBNGTBp6i5T7xG52KDgjYeGPOcjpjGTv1gtVf+t7Fve39bBR RRTAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigAooooAKKKKAOS1j/kZk/64P/7TrzPUEy1u Nmd8Cj7ud3Vc
fdOfv4x8/wB/bj5/KuPTNY/5GZP+uD/+068z1BMtbjZnfAo+7nd1XH3Tn7+M fP8Af24+fyrj
XD7smpsP0SQrr+nShuftUTbt3XLDnO7v5nXcc+Z1fzM3fsU97I9vKpVMFCOn tXjejP8A8TzT
339bmM7t3XLDnO7v5nXcc+Z1fzM3frcv+pf/AHTWlVCgbtFebSeMbqDxysLa 1aR2L35tHsLm
7i82IAFd3lLCGQM4BVmlwQ68ZYCtOLV/Ctp8R5lg1HRob64tvJnEc0SyyziQ AI2Dkv2wea5l
rbz/AMrly92/l/nY7aivM4PEeu/8Jd5F1r2i2p+3mE6Xd6lGj+Tv2rth+ziQ uyYZT5pBJB6H
aNSPWBd+NLzS4fHVsnlyI0ViPszStJlt8XTJQBeVxvBOd46ULWz7g9LncUVx UF6lh4yvLW+8
W3/nSXaG20plgbzUaNcbUEXmbAd2WUgDYSx4Y1zksWjNePN9v8Mrpv8AwkiM YRap53nhgc+b
5m3d1/gzjI96Fq0u/wDml+oS0Tf9bN/oesUV5nB4j13/AIS7yLrXtFtT9vMJ 0u71KNH8nftX
bD9nEhdkwynzSCSD0O0a0Wr+FbT4jzLBqOjQ31xbeTOI5olllnEgARsHJftg 80LW3n/lcHpf
y/zO2oriYtX8K2nxHmWDUdGhvri28mcRzRLLLOJAAjYOS/bB5pja8/8AbJU+ J4k1IXvkDQP3
A3R+ZtztI80kp+83BtvfG0EULVJ9/wDOwPRtdv8AI7miiuJbTfHP9qGQan/o fnbgn9oQf6vd
02/YM9O2/P8Atd6Otg6XO2oorziSHRNW+JF7HqGvW87QLbi3t5/ssnz75N0S hkJBGFztIbnk
9MVFXZpTp8yb7Ho9Fee3Ov3Wnam8Nz4klWaLVo4PssqQDdbNt+dgIwwX5iA2 QOg5NOi8UTQ6
rKZPEMEsMetfYRbuYRmNl7kKDlTkDB/hOc9hRbt/Xb/Mt4eSV/8AP+uh6BRX Bz61ePdzCTxL
Hp2oJqAiTSnjjO+ESADC7GlYunzAqcc9gCalSaLS/HGpm+8RXMBna3aC0YQk 3CncAqr5e8gH
j5efUnrQoidBq+v5nb0VysWoWsHxImsn1SCSaayGIH8kSIwbIQEKHI2kttYn qTWa3iK/W951
QDVDqP2ddC8pOYfM278Y8z/V/vPM3bPbFCi3bzD2Mvy/H+t9jvKK8/i8UTQ6 rKZPEMEsMetf
YRbuYRmNl7kKDlTkDB/hOc9ui1Fml8ZaJbSf8e6wXNyozwZV8tF/JZJP8ilb bz/yuTOm4OzN
6isKzZofGmqW0Q/cSWkFzIAOBKWdM59SqL/3z71u0jN6OwUViCIS+MzJPBEW gsv9Gf7zAM3z
nkfJ0UcE5HXGMVt0LVX/AK3DrYKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigDktY/wCRmT/rg/8A7TrzPUEy1uNmd8Cj7ud3VcfdOfv4x8/3 9uPn8q49M1j/
AJGZP+uD/wDtOvM9QTLW42Z3wKPu53dVx905+/jHz/f24+fyrjXD7smpsLoz /wDE8099/W5j
O7d1yw5zu7+Z13HPmdX8zN363L/qX/3TXkmjP/xPNPff1uYzu3dcsOc7u/md dxz5nV/Mzd+t
y/6l/wDdNaVRQN2iiiuYsKKKKACiuLHirVv+ErigW2jk0Se9ayjmMKRneoYN hjOWch0YYEIG
BnOBk60MH2bxvN5c90UuLIyvFJcyPGGDgAqjMVTj+6BQtbef+Vwel7/1rY3q K4ex8SeK77W2
aHQ/M0kXr2zfJErIiuUMhkNzuyMbtvkg9s/xHU+0+JpfEN3ZwTaT9jtzHKHe CTzGRif3eA+A
cAnzPw2d6F0B6HSUVy9peazHr2ofbtb0pNNgvUhSF7JkkIdEKIJDNjJZwOVO TnGMgC9f3Mze
K9I09XdITDcXT7SRvKbEVT6j96Tj1UU7f1+IG1RWb9hu/wDhJv7Q+1N9j+x+ R9m3tt8zfu37
emccZ61j2k+rWV7MRPA+mjUfIEUvmSzEORyJC+FAZuF2twOozgbxoKS92XT+ l6g3bX+trnVU
VyFpr3iS81djDo+/TVvGt2+WJSiK5QuXM+cjG7b5QPb/AGjqxxeR4vfZNcFZ 7QyPG9w7oGDq
AVUkqvH90CnPDODtJq9r6a/J9gen9fI2qKxY4vI8XvsmuCs9oZHje4d0DB1A KqSVXj+6BVc6
pqpdr9XsRp6Xf2Y2piYzEeZ5efM3YBzyF2HjAzzkSqDez7fe+n9fgHV/15nR UVm/Ybv/AISb
+0PtTfY/sfkfZt7bfM37t+3pnHGetV7S6lj8Xajp5kaSFraG7UMxPlsxdCo9 FPlqQPXdWUop
Ws73DubVFY/2+9bxeLBLvSjYrZebJb+YftgcvgNt6eXjjPXNbFSAVBPaQXMt vLLHukt3MkTZ
IKsVKnp7MRjpU9FAEMNpBbzXE0SYkuHDysSSWIUKOvQYA4HH5mpqKKAIXtLa S6iunt4muIVZ
Y5WQF0DY3AHqAcDPripqKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooA5LWP8AkZk/64P/AO068z1BMtbjZnfAo+7nd1XH3Tn7+MfP9/bj 5/KuPTNY/wCR
mT/rg/8A7TrzPUEy1uNmd8Cj7ud3VcfdOfv4x8/39uPn8q41w+7JqbC6M/8A xPNPff1uYzu3
dcsOc7u/mddxz5nV/Mzd+ty/6l/9015Joz/8TzT339bmM7t3XLDnO7v5nXcc +Z1fzM3frcv+
pf8A3TWlUUDdorGF3PD4vezknkkt57RZYovLBETKxDHKjKggj755I+XoRWzX MtVf+uxfWwUU
UUAZUnhnQJr976XQ9NkvJGDPcNaRmRiCCCWxkkEA/gKYfCfhw6h/aB8P6Ub3 zfO+0/Y4/M8z
Od27Gd2ec9a2KKNgMufw3oV1qY1O40XTpdQVlcXUlqjShlxtO8jORgY54xSR +GdAi1P+049D
01NQLmT7UtpGJdx6tvxnJyec961aKAKUmj6ZLqkeqSadaPqMS7I7toFMqLzw HxkDk9+5p9zp
8N1eWd2xZZrVmZGUjkMpDKfY8HHqo9KtUUAFZp8PaIVKnR9PKmb7QQbZMGX+ /wBPve/WtKiq
jOUfhdgM6bQNGudQGoT6TYS3oZWFw9sjSArjadxGcjAx6Yph8NaC199uOiaa bvzPN882qeZv
znduxnOec1qUVarVFtJ9twMs+GtBa++3HRNNN35nm+ebVPM35zu3YznPOalb RNJbUhqTaXZG
/Bz9qNunm5xj7+M9OOtX6KXtqn8z7b9ACqtvYxW95dXYZ3muSu4uR8qqMBR6 AfMfqxq1RWYF
WDTbO2v7u+hgVbq72efLkln2jCjnoAOw4ySepNWqKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA5LWP8AkZk/64P/ AO068z1BMtbj
ZnfAo+7nd1XH3Tn7+MfP9/bj5/KuPTNY/wCRmT/rg/8A7TrzPUEy1uNmd8Cj 7ud3VcfdOfv4
x8/39uPn8q41w+7JqbDtFJbXtOIbJa5jIbd1yw5zu7+Z13HPmdX8zN37BNaz LBIxTgKSeR6V
5FoD/wDFR6W+/rdxHdu65cc53d/M67jnzOr+Zm79uu/+POf/AK5t/KqrOwoF GOwmXWJ9S3M0
k0KRLG7LsiRSTgYGcsTySSB26fNpqSVBIKkjoeopaK5Yw5etzRu4UUUVYgoo ooAKKKKACiii
gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAK
KKKACiiigAooooAKKKKACiiigAooooA5LWP+RmT/AK4P/wC068z1BMtbjZnf Ao+7nd1XH3Tn
7+MfP9/bj5/KuPTNY/5GZP8Arg//ALTrzPUEy1uNmd8Cj7ud3VcfdOfv4x8/ 39uPn8q41w+7
JqbEmguB4i0yQvx9ribfu9XHOd3fzOu458zq/mZu/bLqWM2kwEiEmNu/tXiG jP8A8TzT339b
mM7t3XLDnO7v5nXcc+Z1fzM3frcv+pf/AHTV1lcUDb3p/fX86N6f31/OsD+3 rAasdNZrhLjd
sDSWsqxM2N21ZSuxjjnAYnr6U2HUbs+IJtNuLSBIRD50E0dwXZxkAhlKAKcn szVmoJg5WOh3
p/fX86N6f31/OqVFHIHMXd6f31/Ojen99fzqlRRyBzF3en99fzo3p/fX86pU Ucgcxd3p/fX8
6N6f31/OqVFHIHMXd6f31/Ojen99fzqlRRyBzF3en99fzo3p/fX86pUUcgcx d3p/fX86N6f3
1/OqVFHIHMXd6f31/Ojen99fzqlRRyBzF3en99fzo3p/fX86pUUcgcxd3p/f X86N6f31/OqV
FHIHMXd6f31/Ojen99fzqlRRyBzF3en99fzo3p/fX86pUUcgcxd3p/fX86N6 f31/OqVFHIHM
Xd6f31/Ojen99fzqlRRyBzF3en99fzo3p/fX86pUUcgcxd3p/fX86N6f31/O qVFHIHMXd6f3
1/Ojen99fzqlRRyBzF3en99fzo3p/fX86pUUcgcxd3p/fX86N6f31/OqVFHI HMXd6f31/Oje
n99fzqlRRyBzF3en99fzo3p/fX86pUUcgcxd3p/fX86N6f31/OqVFHIHMXd6 f31/OiqVFHIH
MYOsf8jMn/XB/wD2nXmeoJlrcbM74FH3c7uq4+6c/fxj5/v7cfP5Vx6ZrH/I zJ/1wf8A9p15
nqCZa3GzO+BR93O7quPunP38Y+f7+3Hz+VcPD7sdTYXRn/4nmnvv63MZ3buu WHOd3fzOu458
zq/mZu/W5f8AUv8A7pryTRn/AOJ5p77+tzGd27rlhznd38zruOfM6v5mbv1u X/Uv/umtKooH
EPocZ8QLqtvPavKt2buGY6MZbqeMk7sTeZlo1BKjaFOBGBuDKH0zNqbeIhqU epW0luV2RQJp
MjNLb7tzOribBxjG7bz8uFO9N3oNFZKaVrLb/hjobpO94v7/APgf191s6ORJ oklidXjdQyup
yGB6EHuKdUdpaRzRZOFwFHEaH+BT3B9afNa2lvGZJ5kiQdWdY1H5laXtPIwc ELRTXtYPsjzx
SK4CFlISMg4H+7WJLfeTE8srW8caAszvGgCj1JxSdS3QOQ3aKxftL/3Yv+/S /wCFH2mT+7F/
36X/AAo9r5B7M2qKxftMn92L/v0v+FQy6nHBIkcstrG7/dV0QFuQOBjnkgfU j1o9r5B7M6Ci
sX7TJ/di/wC/S/4UfaZP7sX/AH6X/Cj2vkHszaorF+0yf3Yv+/S/4UfaZP7s X/fpf8KPa+Qe
zNqisX7TJ/di/wC/S/4UfaZP7sX/AH6X/Cj2vkHszaorF+0yf3Yv+/S/4Ufa ZP7sX/fpf8KP
a+QezNqiiCxjlt45GIyyhjiNO4/3af8A2dF6/wDkNP8A4mn7TyDkGUU/+zov X/yGn/xNH9nR
ev8A5DT/AOJo9p5ByDKKf/Z0Xr/5DT/4mj+zovX/AMhp/wDE0e08g5BlFP8A 7Oi9f/Iaf/E0
f2dF6/8AkNP/AImj2nkHIMop/wDZ0Xr/AOQ0/wDiaP7Oi9f/ACGn/wATR7Ty DkGUU/8As6L1
/wDIaf8AxNH9nRev/kNP/iaPaeQcgyin/wBnRev/AJDT/wCJo/s6L1/8hp/8 TR7TyDkGUU/+
zovX/wAhp/8AE0f2dF6/+Q0/+Jo9p5ByDKK5v4hQC08Eak8TYLR7CQijg9eQ Aa7Ojn8hchQo
q/RT5w5ShRV+ijnDlKFFX6KOcOUoUVfoo5w5ShRV+ijnDlKFFX6KOcOU5LWP +RmT/rg//tOv
M9QTLW42Z3wKPu53dVx905+/jHz/AH9uPn8q49M1j/kZk/64P/7Trm9L0bS9 RsIpr3TbO5lC
hQ88CuQMA4yR05P50qU1G7ZUlfQ5jRn/AOJ5p77+tzGd27rlhznd38zruOfM 6v5mbv1uX/Uv
/umsCw8N6FDqNrLFounJIkqMrraoCpBGCDjg12d1FGLSYiNARG3b2qp1VLYU YtFmio5Z4oFV
ppUjVmCAuwALE4A57k0y4ukt5II2DM877EVRz0JJPsADWQ20iLTv9Qf+Af8A oC1ieI5HttVt
7m4O2w+zyIJGUskUmDgtjOM/Lzjsa29O/wBQf+Af+gLVyhDOW8PLcnT9TlcE Wz58nIIDEAhm
APODx2HSvMNa8QXc17qVsl8jWsiXMD2ck8bSxFY3IYxrEGQEpwWkOQenPHus sfmwvHnG9Suf
TNZf9h/9PP8A45/
Re: JSDT not parsing alternative fn syntax [message #216761 is a reply to message #216424] Thu, 03 July 2008 15:47 Go to previous messageGo to next message
I can reproduce the correct behavior when I add the function to an .html
file, but the alternative fn syntax does not seem to be recognized in a
js file. That would explain my problem and the problem that Bob reports
below.
Chris
> <html>
> <head>
> <title></title>
> </head>
> <br>
> <br>
> <br>
> Bob Shields<br>
Re: JSDT not parsing alternative fn syntax [message #217161 is a reply to message #216761] Tue, 08 July 2008 23:45 Go to previous messageGo to next message
Bradley, can you reproduce the problem now? Shall I file a bug on this
issue?
Re: JSDT not parsing alternative fn syntax [message #217241 is a reply to message #217161] Wed, 09 July 2008 13:37 Go to previous messageGo to next message
I have opened bug #240106.
Bob Shields
> issue?
Re: JSDT not parsing alternative fn syntax [message #217336 is a reply to message #217241] Thu, 10 July 2008 16:34 Go to previous messageGo to next message
Thanks, Bob!
Re: JSDT not parsing alternative fn syntax [message #217343 is a reply to message #217336] Thu, 10 July 2008 16:49 Go to previous messageGo to next message
Hmmm. Bug #240106 seems to be about inferencing with JsDoc. My concerns is
around parsing the alternative fn syntax. I'll file my own bug.
Re: JSDT not parsing alternative fn syntax [message #217351 is a reply to message #217343] Thu, 10 July 2008 17:00 Go to previous messageGo to next message
240410 is the relevant bug to track:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240410
Re: JSDT not parsing alternative fn syntax [message #217365 is a reply to message #217343] Thu, 10 July 2008 18:51 Go to previous messageGo to next message
Sorry, my bad... I posted to the wrong thread. The #240106 bug report
is in reference to the "JSDT - jsDoc not used for code completion?"
thread...
Bob Shields
> concerns is around parsing the alternative fn syntax. I'll file my own
> bug.
Re: JSDT not parsing alternative fn syntax [message #217423 is a reply to message #217336] Fri, 11 July 2008 10:06 Go to previous message
> Thanks, Bob!
No problem, Doug! ;-) Wait a minute, I'm Doug.
Previous Topic:Extends Eclipse XML Editor
Next Topic:Facet constraint based on runtime composition as well as runtime version
Current Time: Wed Jul 23 15:32:55 EDT 2025
Powered by FUDForum. Page generated in 0.04602 seconds
