Home » Language IDEs » ServerTools (WTP) » Error in log when trying JavaScript code completion
Error in log when trying JavaScript code completion [message #216137] Thu, 26 June 2008 04:02 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello!
I imported a project from an Eclipse 3.3 workspace to my brand new
Eclipse 3.4 workspace, copying the contents.
Then, I opened a JSP in one of the projects I imported (it's a dynamic
web project) and I wanted to try the new JavaScript editing features.
When trying to invoke code completion after "document.", nothing happens
and I get the following exception in the log file:
!ENTRY org.eclipse.wst.jsdt.ui 4 10001 2008-06-26 09:57:53.421
!MESSAGE Internal Error
!STACK 1
JavaScript Model Exception: Java Model Status [XXX does not exist]
at
org.eclipse.wst.jsdt.internal.core.JavaElement.newNotPresent Exception(JavaElement.java:518)
at
org.eclipse.wst.jsdt.internal.core.JavaModelManager.getPerPr ojectInfoCheckExistence(JavaModelManager.java:1879)
at
org.eclipse.wst.jsdt.internal.core.JavaProject.getPerProject Info(JavaProject.java:1869)
at
org.eclipse.wst.jsdt.internal.core.search.JavaSearchScope.ad d(JavaSearchScope.java:120)
at
org.eclipse.wst.jsdt.internal.core.search.JavaSearchScope.ad d(JavaSearchScope.java:97)
at
org.eclipse.wst.jsdt.internal.core.DocumentContextFragmentRo ot.newSearchableNameEnvironment(DocumentContextFragmentRoot. java:550)
at
org.eclipse.wst.jsdt.internal.core.JavaElement.newSearchable NameEnvironment(JavaElement.java:872)
at
at
org.eclipse.wst.jsdt.internal.core.CompilationUnit.newSearch ableNameEnvironment(CompilationUnit.java:1412)
at
org.eclipse.wst.jsdt.internal.core.Openable.codeComplete(Ope nable.java:128)
at
org.eclipse.wst.jsdt.internal.core.CompilationUnit.codeCompl ete(CompilationUnit.java:306)
at
org.eclipse.wst.jsdt.internal.core.CompilationUnit.codeCompl ete(CompilationUnit.java:299)
at
org.eclipse.wst.jsdt.ui.text.java.JavaContentAssistInvocatio nContext.computeKeywordsAndContext(JavaContentAssistInvocati onContext.java:292)
at
org.eclipse.wst.jsdt.ui.text.java.JavaContentAssistInvocatio nContext.getKeywordProposals(JavaContentAssistInvocationCont ext.java:125)
at
org.eclipse.wst.jsdt.internal.ui.text.java.TemplateCompletio nProposalComputer.computeCompletionProposals(TemplateComplet ionProposalComputer.java:96)
at
org.eclipse.wst.jsdt.web.ui.internal.contentassist.JSDTTempl ateAssistProcessor.computeCompletionProposals(JSDTTemplateAs sistProcessor.java:42)
at
org.eclipse.wst.jsdt.web.ui.internal.contentassist.JSDTConte ntAssistant.computeCompletionProposals(JSDTContentAssistant. java:59)
at
org.eclipse.wst.sse.ui.internal.contentassist.CompoundConten tAssistProcessor.computeCompletionProposals(CompoundContentA ssistProcessor.java:300)
at
at
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1836)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:553)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(CompletionProposalPopup.java:550)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(CompletionProposalPopup.java:485)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:479)
at
org.eclipse.jface.text.contentassist.ContentAssistant.showPo ssibleCompletions(ContentAssistant.java:1664)
at
org.eclipse.wst.sse.ui.internal.StructuredTextViewer.doOpera tion(StructuredTextViewer.java:437)
at
org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOper ationAction.java:131)
at
org.eclipse.ui.texteditor.TextOperationAction.run(TextOperat ionAction.java:129)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler. java:185)
at
org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execut e(LegacyHandlerWrapper.java:109)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeComman d(WorkbenchKeyboard.java:471)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(Workben chKeyboard.java:822)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEve nt(WorkbenchKeyboard.java:880)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.filterKeySequ enceBindings(WorkbenchKeyboard.java:569)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard.access$3(Work benchKeyboard.java:511)
at
org.eclipse.ui.internal.keys.WorkbenchKeyboard$KeyDownFilter .handleEvent(WorkbenchKeyboard.java:126)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:118 4)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1040 )
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1036 )
at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1352)
at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:3894)
at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:341)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3787 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:23 70)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3420)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
!SUBENTRY 1 org.eclipse.wst.jsdt.core 4 969 2008-06-26 09:57:53.421
!MESSAGE XXX does not exist
!ENTRY org.eclipse.wst.jsdt.ui 4 10001 2008-06-26 09:57:53.437
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.wst.jsdt.core 4 969 2008-06-26 09:57:53.437
!ENTRY org.eclipse.wst.jsdt.ui 4 10001 2008-06-26 09:57:53.453
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.wst.jsdt.core 4 969 2008-06-26 09:57:53.453
Please note that XXX is the name of the project I'm working in.
What's wrong?
Thanks in advance.
Mauro.
Re: Error in log when trying JavaScript code completion [message #216168 is a reply to message #216137] Thu, 26 June 2008 08:53 Go to previous message
Maybe I found the problem: if I understood it well, I need to add the
JavaScript Toolkit facet to my project in order to make JavaScript code
completion work, don't I?
Mauro.
Previous Topic:Send by HttpClient, receive by IE ?
Next Topic:ganymede: xml editor: clear all blank lines?
Current Time: Fri Jul 18 12:51:17 EDT 2025
Powered by FUDForum. Page generated in 0.06786 seconds
