Home » Modeling » GMF (Graphical Modeling Framework) » modification of ElementInitializers generation
modification of ElementInitializers generation [message #216014] Wed, 21 January 2009 05:27 Go to next message
I try to modify code generation, so I use dynalic template. I try to modify
ElementInitilizers. To do that I have copied from the CVS
xpt::providers::ElementInitializers. But it does not run, I have the
following error message.
I try to prefix by "gmfgen::" but the mistake is the same.
eclipse.buildId=unknown
java.version=1.6.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data
E:\experiment -dev
file:C:/Tessier/papyrus-experiment/.metadata/.plugins/org.ec lipse.pde.core/New_configuration/dev.properties -
debug
C:\Tessier\papyrus-experiment\.metadata\.plugins\org.eclipse .pde.core\New_configuration/.options
-os win32 -ws win32 -arch x86
Error
Wed Jan 21 11:04:01 CET 2009
Exception (Couldn't find enum literal or type 'GenLanguage::literal':in
xpt::providers::ElementInitializers on line 82 'GenLanguage::literal') while
generating code
org.eclipse.gmf.internal.xpand.expression.EvaluationExceptio n: Couldn't find
at
org.eclipse.gmf.internal.xpand.expression.ast.FeatureCall.ev aluateInternal(FeatureCall.java:133)
at
org.eclipse.gmf.internal.xpand.expression.ast.Expression.eva luate(Expression.java:44)
at
org.eclipse.gmf.internal.xpand.expression.ast.OperationCall. evaluateInternal(OperationCall.java:58)
at
at
org.eclipse.gmf.internal.xpand.ast.IfStatement.evaluateInter nal(IfStatement.java:82)
at org.eclipse.gmf.internal.xpand.ast.Statement.evaluate(Statem ent.java:30)
at
org.eclipse.gmf.internal.xpand.ast.AbstractDefinition.evalua te(AbstractDefinition.java:94)
at
org.eclipse.gmf.internal.xpand.ast.ExpandStatement.invokeDef inition(ExpandStatement.java:190)
at
org.eclipse.gmf.internal.xpand.ast.ExpandStatement.evaluateI nternal(ExpandStatement.java:161)
at
org.eclipse.gmf.internal.xpand.ast.ForEachStatement.evaluate Internal(ForEachStatement.java:123)
at
at
at
at
at
at
at
at
at
org.eclipse.gmf.internal.xpand.ast.ExpandStatement.evaluateI nternal(ExpandStatement.java:147)
at
at
at
at
at org.eclipse.gmf.internal.xpand.XpandFacade.evaluate(XpandFac ade.java:60)
at
org.eclipse.gmf.internal.common.codegen.XpandTextEmitter.gen erate(XpandTextEmitter.java:64)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doGene rateJavaClass(GeneratorBase.java:335)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doGene rateJavaClass(GeneratorBase.java:322)
at
org.eclipse.gmf.codegen.util.Generator.generateElementInitia lizers(Generator.java:575)
at org.eclipse.gmf.codegen.util.Generator.customRun(Generator.j ava:166)
at
org.eclipse.papyrus.codegen.PapyrusGenerator.customRun(Papyr usGenerator.java:53)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase$1.run( GeneratorBase.java:474)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doRun( GeneratorBase.java:471)
at
org.eclipse.gmf.internal.common.codegen.GeneratorBase.run(Ge neratorBase.java:90)
at
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesOperation.run(ExecuteTemplatesOperation.java:182)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: modification of ElementInitializers generation [message #216833 is a reply to message #216014] Fri, 30 January 2009 07:06 Go to previous message
Hello Patrick,
Do you have an exact copy of the template, or did you copy only this very
definition («DEFINE performInit(GenCommonBase diagramElement, String instanceVar,
GenClass instanceClass, List[int] counters) FOR GenFeatureValueSpec-»)? This
error says: due to some reasons corresponding enumeration (or it’s literal)
was not found.
So, if you have whole GMF in a target platform (gmfgen model available in
default Ecore package registry) + import «IMPORT "http://www.eclipse.org/gmf/2008/GenModel
specified in corresponding custom template this error can be produces only
if you are using old gmfgen model (AFAIKSee from the CVS history “literal”
was added to the GenLanguage enumeration after GMF 2.1 release)…
I suggest you to better use xpt/providers/ElementInitilizers.xpt from org.eclipse.gmf.codegen
plugin of your current target platform – CVS version sometimes is “too fresh”.
Alex Shatalin
P.S. Recently we modified xpand templates engine in GMF (using ImperativeOCL
as a query language instead of xtend one) so I suggest you to base your development
on latest GMF integration/stable builds to avoid custom templates migration
in future.
Previous Topic:Global Actions in Multipage Editor with a Diagram Editor
Next Topic:Association Link problem
Current Time: Fri Jul 18 02:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.07689 seconds
