J2EE Module Dependencies and build problems [message #215644] |
Tue, 17 June 2008 15:39  |
WTP 2.0.1
Windows XP
Dynamic Web Project
Hello:
I am having two problems in WTP.
1) First, when I check off jars in J2EE Module Dependencies it never
sticks. The next time I go there, all my choices are cleared (all
unchecked). This is very aggravating.
2) My JSPs which import classes in jars on the build path will not
resolve. For instance,
<%@ page import="org.apache.struts.Globals" %>
will not resolve even though struts-core.jar is in my build path. The JSP
is in WebContent.
Any help would be appreciated
Re: J2EE Module Dependencies and build problems [message #219081 is a reply to message #215695] |
Fri, 08 August 2008 06:25   |
Wolfgang Knauf wrote:
> Problem 1 sounds like
I am hit by the same problem. Just to recap:
I have a dynamic Web Project and two Java projects A and B,
and B depends on A.
I can successfully add one of the java projects "A" as
JEE module dependency, but If I add the second java project "B"
as JEE module dependency, hit "apply", it is silently dropped the next time
I open the JEE module dependency configuration.
Similarly, if I manually edit
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/org.metware.bigmet/org.metware.bigmet ">
<dependency-type>uses</dependency-type>
</dependent-module>
and change the handle to match the second java project,
the entry is deleted again.
To me the most annoying "feature" is that without a message
even in the error log I have no clue what's going wrong.
I saw quite a few bug reports on JEE module dependency configuration,
and I am somewhat lost in which category mine falls.
What are the requirements for a java project to be a valid JEE dependency ?
What do I have (and not have) to export from the projects A and B ?
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=205004 (fixed in 2.0.2)
I have WTP 3.0.0, and supposedly the above bug was fixed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205004#c7
The eclipse installation seems to be current,
there are no available updates shown.
Any hints appreciated,
Yours,
Steffen
*** System properties:
Linux x86_64 on Ubuntu hardy
eclipse.buildId=I20080617-2000
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_15-b04
*** Features:
org.eclipse.jst (3.0.0.v200806111800-7U-8Y9LIrwYBUV7sHGjhtz0LTrMd) "J2EE Standard Tools (JST)"
org.eclipse.wst (3.0.0.v200806092130-7A-8Y8QqN2lf4VSWrI2ek5Pf4k7s) "Web Standard Tools (WST)"
Re: J2EE Module Dependencies and build problems [Solved for me] [message #219854 is a reply to message #219081] |
Sun, 31 August 2008 15:45  |
The following changes in the .project of the project to be included
solved the problem for me, YMMV.
Yours,
Steffen
--- .project 2008-08-27 22:53:45 UTC (rev 834)
+++ .project 2008-08-27 23:09:37 UTC (rev 835)
@@ -6,6 +6,11 @@
</projects>
<buildSpec>
<buildCommand>
+ <name>org.eclipse.wst.common.project.facet.core.builder</name >
+ <arguments>
+ </arguments>
+ </buildCommand>
+ <buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
@@ -20,9 +25,17 @@
<arguments>
</arguments>
</buildCommand>
+ <buildCommand>
+ <name>org.eclipse.wst.validation.validationbuilder</name>
+ <arguments>
+ </arguments>
+ </buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.jdt.core.javanature</nature>
<nature>org.eclipse.pde.PluginNature</nature>
+ <nature>org.eclipse.wst.common.project.facet.core.nature</nature >
+ <nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature >
+ <nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
</natures>
</projectDescription>
FUDForum. Page generated in 0.28617 seconds
