Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215599 is a reply to message #215561] |
Tue, 17 June 2008 10:31   |
Originally posted by: dcarver.starstandard.org
John J Barton wrote:
> Nitin Dahyabhai wrote:
>> Alternately you can just grab a pre-assembled Java EE package (the
>> " Eclipse IDE for Java EE Developers") from
>> http://www.eclipse.org/downloads/packages/ .
> Thanks, but I tried that first, but it does not have source or PDE so I
> can't use it.
John, you should be able to use the latest Eclipse 3.4 RC4 SDK, and
install the J2EE component as well as the Web Tools 3.0 components. I
believe there were some issues with the earlier Eclipse 3.4 RC2 and RC3
builds that didn't resolve all the required dependencies. In addition,
you can also select from the Ganymede update site to install, GMF, EMF,
and XSD Runtimes from the Modeling Project.
But I would try with a newer build, and as for the J2EE Developer
Version, you should be able to add the PDE package from Ganymede.
Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215615 is a reply to message #215599] |
Tue, 17 June 2008 13:26   |
>> I can't use it.
Thanks David...are you suggesting that 3.4 RC2 will not upgrade to RC4?
But this would still not have the source correct? Using PDE without the
source isn't fun.
> Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215670 is a reply to message #215662] |
Tue, 17 June 2008 20:28  |
You can get the Eclipse JEE developers edition, and then from within the
Ganymede update site, under Java Tools, add the Eclipse Plugin
Development Environment.
or
Download the Eclipse for Plugin / RCP Developers and then through the
ganymede update site, under Web Tools and Java EE install the select the
Eclipse XML Editors, Java EE Developers, Java Persistence, JavaScript
Developer Tools, Web Developer Tools and Web Page Editor.
That should get you everything in one environment.
Dave
FUDForum. Page generated in 0.09462 seconds
