Creating and using xml data sources / sets programmatically [message #213660] |
Wed, 24 January 2007 08:36  |
Originally posted by: firstname.lastname.napa.fi
Hi!
Is there any documentation and/or examples about programmatically =
creating and using xml data sources / sets?
From bits and pieces I found here and there managed to put together =
something like this (I have no idea whether this is correct):
-- clip --
// efactory is an ElementFactory
// design is a ReportDesignHandle
String dsrcName =3D "my_xml_dsource" ;
OdaDataSourceHandle dsource =3D efactory.newOdaDataSource( dsrcName, =
"org.eclipse.birt.report.data.oda.xml" ) ;
design.getDataSources().add( dsource ) ;
String dsName =3D "my_xml_dset" ;
OdaDataSetHandle dset =3D efactory.newOdaDataSet( dsName, =
"org.eclipse.birt.report.data.oda.xml.dataSet" ) ;
dset.setDataSource( dsrcName ) ;
dset.setProperty( "XML_FILE", "d:/temp/foo.xml" ) ;
design.getDataSets().add( dset ) ;
-- clip --
Is this correct?
But now I'm a bit lost. How do I create column mapping using xpath =
expressions?
Also (this is propably not specific to xml data source / set), how do=
I =
programmatically create a filter on a data set?
I could not find any examples, but I would guess classes
org.eclipse.birt.report.model.api.FilterConditionHandle
org.eclipse.birt.report.model.api.elements.structures.Filter Condition
are used in some fashion, possibly setting an instance of one of thos=
e =
classes as a value to data set property "filter". Am I on the right trac=
k?
I would guess the FilterCondition is to be created w/ =
StructureFactory.createFilterCond() ?
After that I need to create a table and bind the data set to that tab=
le, =
but http://wiki.eclipse.org/index.php/Dynamic_Table gives me an idea on =
how to go about that - I suppose there's nothing data source / set type =
specific here.
-Antti-
Re: Creating and using xml data sources / sets programmatically [message #214781 is a reply to message #213660] |
Sat, 27 January 2007 01:36   |
Here is a simple example using the DEAPI to create an xml ds.
Jason
import java.io.File;
import java.io.IOException;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.DesignEngine;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import org.eclipse.birt.report.model.api.command.ContentException;
import org.eclipse.birt.report.model.api.command.NameException;
import org.eclipse.birt.report.model.api.elements.DesignChoiceConst ants;
import org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import org.eclipse.birt.report.model.api.metadata.IMetaDataDictiona ry;
import org.eclipse.birt.report.model.elements.interfaces.IReportIte mModel;
import org.eclipse.birt.report.model.elements.interfaces.IStyleMode l;
import com.ibm.icu.util.ULocale;
public class XMLReport
ReportDesignHandle reportDesignHandle = null;
ElementFactory elementFactory = null;
IMetaDataDictionary dict = null;
ComputedColumn cs1, cs2, cs3 = null;
public static void main( String[] args ) throws SemanticException,
IOException
new XMLReport( ).createReport( );
void createReport( ) throws SemanticException, IOException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
config.setProperty("BIRT_HOME",
"C:/birt-runtime-2_1_1/birt-runtime-2_1_1/ReportEngine");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
// Create a new report
reportDesignHandle = session.createDesign( );
// Element factory is used to create instances of BIRT elements.
elementFactory = reportDesignHandle.getElementFactory( );
dict = new DesignEngine( null ).getMetaData( );
createMasterPages( );
createDataSources( );
createDataSets( );
createBody( );
String outputPath = "output";//$NON-NLS-1$
File outputFolder = new File( outputPath );
if ( !outputFolder.exists( ) && !outputFolder.mkdir( ) )
throw new IOException( "Can not create the output folder" );//$NON-NLS-1$
reportDesignHandle.saveAs( outputPath + "/" +
"XMLReport.rptdesign" );//$NON-NLS-1$//$NON-NLS-2$
System.out.println("finished");
//Scripted Data Set
* private void createDataSources( ) throws SemanticException
ScriptDataSourceHandle dataSourceHandle =
elementFactory.newScriptDataSource( "Data Source" );//$NON-NLS-1$
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
private void createDataSets( ) throws SemanticException
// Data Set
ScriptDataSetHandle dataSetHandle = elementFactory.newScriptDataSet( "Data
Set" );//$NON-NLS-1$
dataSetHandle.setDataSource( "Data Source" );//$NON-NLS-1$
// Set open( ) in code
dataSetHandle.setOpen( "i=0;"//$NON-NLS-1$
+ "sourcedata = new Array( new Array(3), new Array(3), new Array(3),
new Array(3));"//$NON-NLS-1$
+ "sourcedata[0][0] = 10; "//$NON-NLS-1$
+ "sourcedata[0][1] = \"Ice Bella\";"//$NON-NLS-1$
+ "sourcedata[0][2] = 304;"//$NON-NLS-1$
+ "sourcedata[1][0] = 10; "//$NON-NLS-1$
+ "sourcedata[1][1] = \"Nola Dicci\";"//$NON-NLS-1$
+ "sourcedata[1][2] = 258;"//$NON-NLS-1$
+ "sourcedata[2][0] = 11; "//$NON-NLS-1$
+ "sourcedata[2][1] = \"Ice Bella\";"//$NON-NLS-1$
+ "sourcedata[2][2] = 202;"//$NON-NLS-1$
+ "sourcedata[3][0] = 11; "//$NON-NLS-1$
+ "sourcedata[3][1] = \"Nola Dicci\";"//$NON-NLS-1$
+ "sourcedata[3][2] = 181;" );//$NON-NLS-1$
// Set fetch( ) in code
dataSetHandle.setFetch( "if ( i < 4 ){"//$NON-NLS-1$
+ "row[\"Month\"] = sourcedata[i][0];"//$NON-NLS-1$
+ "row[\"Product\"] = sourcedata[i][1];"//$NON-NLS-1$
+ "row[\"Amount\"] = sourcedata[i][2];"//$NON-NLS-1$
+ "i++;"//$NON-NLS-1$
+ "return true;}" + "else return false;" );//$NON-NLS-1$//$NON-NLS-2$
// Set computed columns
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "Month" );//$NON-NLS-1$
cs1.setExpression( "row[\"Month\"]" );//$NON-NLS-1$
cs1.setDataType( "integer" );//$NON-NLS-1$
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "Product" );//$NON-NLS-1$
cs2.setExpression( "row[\"Product\"]" );//$NON-NLS-1$
cs2.setDataType( "string" );//$NON-NLS-1$
cs3 = StructureFactory.createComputedColumn( );
cs3.setName( "Amount" );//$NON-NLS-1$
cs3.setExpression( "row[\"Amount\"]" );//$NON-NLS-1$
cs3.setDataType( "integer" );//$NON-NLS-1$
PropertyHandle computedSet = dataSetHandle.getPropertyHandle(
ScriptDataSetHandle.COMPUTED_COLUMNS_PROP );
computedSet.addItem( cs1 );
computedSet.addItem( cs2 );
computedSet.addItem( cs3 );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
OdaDataSourceHandle dataSourceHandle =
elementFactory.newOdaDataSource("Data Source",
"org.eclipse.birt.report.data.oda.xml");
dataSourceHandle.setProperty("FILELIST", "C:/xmltest/test.xml");
// Data Set
OdaDataSetHandle dsHandle = elementFactory.newOdaDataSet( "Data Set",
"org.eclipse.birt.report.data.oda.xml.dataSet" );
dsHandle.setDataSource( "Data Source" );
dsHandle.setQueryText(
" table0#-TNAME-#table0#:#[/people/person/name]#:#{name;String ;} " );
reportDesignHandle.getDataSets( ).add( dsHandle );
private void createMasterPages( ) throws ContentException, NameException
DesignElementHandle simpleMasterPage =
elementFactory.newSimpleMasterPage( "Master Page" );//$NON-NLS-1$
reportDesignHandle.getMasterPages( ).add( simpleMasterPage );
private void createBody( ) throws SemanticException
TableHandle table = elementFactory.newTableItem( null, 3, 1, 1, 1 );
table.setProperty( IStyleModel.TEXT_ALIGN_PROP,
DesignChoiceConstants.TEXT_ALIGN_CENTER );
table.setWidth( "80%" );//$NON-NLS-1$
table.setProperty( IReportItemModel.DATA_SET_PROP, "Data
PropertyHandle computedSet = table.getColumnBindings( );
cs1.setName("Name");
cs1.setExpression( "dataSetRow[\"name\"]" );//$NON-NLS-1$
// Header
RowHandle header = (RowHandle) table.getHeader( ).get( 0 );
CellHandle tcell = (CellHandle) header.getCells( ).get( 0 );
LabelHandle label = elementFactory.newLabel( null );
label.setText( "Name" );//$NON-NLS-1$
tcell.getContent( ).add( label );
DataItemHandle data = null;
// Detail
RowHandle detail = (RowHandle) table.getDetail( ).get( 0 );
tcell = (CellHandle) detail.getCells( ).get( 0 );
data = elementFactory.newDataItem( null );
data.setResultSetColumn( cs1.getName( ) );
tcell.getContent( ).add( data );
reportDesignHandle.getBody( ).add( table );
"Antti Karanta" <firstname.lastname@napa.fi> wrote in message
news:op.tmnurdp163e0vv@nw17.napa.fi...
Hi!
-- clip --
String dsrcName = "my_xml_dsource" ;
OdaDataSourceHandle dsource = efactory.newOdaDataSource( dsrcName,
String dsName = "my_xml_dset" ;
OdaDataSetHandle dset = efactory.newOdaDataSet( dsName,
-- clip --
Is this correct?
expressions?
Also (this is propably not specific to xml data source / set), how do I
are used in some fashion, possibly setting an instance of one of those
classes as a value to data set property "filter". Am I on the right track?
After that I need to create a table and bind the data set to that table,
specific here.
-Antti-
Re: Creating and using xml data sources / sets programmatically [message #215741 is a reply to message #215628] |
Wed, 31 January 2007 10:50  |
The second design engine is a bug. It does not need to be there.
The table.setDataset call requires a dataset handle. Which the code has but
the variable
was not global.
Jason
news:op.tm0kyd0r63e0vv@nw17.napa.fi...
> try{
What is the reason for creating a new DesignEngine just to get the
IMetaDataDictionary? Why not use the engine previously created (via the
factory), i.e.
dict = engine.getMetaData( ) ;
And besides that, the "dict" instance variable is never referenced after
this, i.e. the IMetaDataDictionary created here is never used. Is getting
the IMetaDataDictionary instance still necessary for some reason?
> et" );//$NON-NLS-1$
Why not
table.setDataSet( "Data Set" ) ;
? Or are they equivalent?
-Antti-
FUDForum. Page generated in 0.27519 seconds
