Home » Eclipse Projects » GEF » DirectedGraph - tuning the vertical vs horizontal
DirectedGraph - tuning the vertical vs horizontal [message #215406] Tue, 02 May 2006 10:53 Go to next message
Originally posted by: pbeagan.yahoo_dontspamme_.com
I'm using auto layout based on DirectedGraph. It works well, but lays out
my objects more vertically than horizontally. What should I be looking at
to add more horizontal weighting? Thanks
Re: DirectedGraph - tuning the vertical vs horizontal [message #215470 is a reply to message #215406] Wed, 03 May 2006 15:11 Go to previous messageGo to next message
There's an API -->
DirectGraph.setDirection(int direction) that takes a PositionConstant define
as a parameter.
I'm guessing you'd want to use PositionConstants.WEST;
-Steve
"Patrick" <pbeagan@yahoo_dontspamme_.com> wrote in message
news:e37u97$1di$1@utils.eclipse.org...
out
Re: DirectedGraph - tuning the vertical vs horizontal [message #215485 is a reply to message #215470] Thu, 04 May 2006 00:24 Go to previous messageGo to next message
Originally posted by: stephen.tom.com
Hello Steven, Do you mean DirectedGraph.setDirection(int direction) ?
But I can find this API in Draw2d and others .What I only find is that
there is a interface Orientable.setDirection(int direction) and its
implemented class.
Can you tell us more about this DirectGraph.setDirection(int
direction) ?
what the package is this class DirectGraph in ? And if possible,can you
give us a sample ?
Thank you Steven very much!
Best Regards to you!
Re: DirectedGraph - tuning the vertical vs horizontal [message #215519 is a reply to message #215470] Thu, 04 May 2006 12:07 Go to previous messageGo to next message
That method DirectedGraph.setDirection() is not available in the Draw2d 3.1
API. AND, when I browse the API, most things are 'for internal use only'.
So I am not sure what I can do to 'tune' my layout to have more horizontal
than vertical. Seems like a limitation, unless I am missing something.
Steven Shaw wrote:
> There's an API -->
> define as a parameter.
> -Steve
> out
>> at
Re: DirectedGraph - tuning the vertical vs horizontal [message #215534 is a reply to message #215519] Thu, 04 May 2006 14:20 Go to previous message
It is new API. For 3.1, you will have to:
1) transpose your input
2) invoke DGL
3) transpose the results
news:e3dbam$ujg$1@utils.eclipse.org...
> 3.1
> only'.
> Steven Shaw wrote:
>> There's an API -->
>> -Steve
>> out
>>> at
Previous Topic:GEF editor with tree
Next Topic:RC2 GEF available...
Current Time: Sat Jul 26 07:46:26 EDT 2025
Powered by FUDForum. Page generated in 0.05523 seconds
