Home » Language IDEs » ServerTools (WTP) » No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source
No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215505] Mon, 16 June 2008 15:11 Go to next message
In Version: 3.4.0
Build id: I20080523-0100
I get a popup error message and several stack traces in Error Log when
I click on index.html in my project. Any ideas?
John
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215513 is a reply to message #215505] Mon, 16 June 2008 16:00 Go to previous messageGo to next message
John J Barton wrote:
> In Version: 3.4.0
Is this a new installation with all of the right prerequisites? Are
you at least using Java5?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215529 is a reply to message #215513] Mon, 16 June 2008 16:41 Go to previous messageGo to next message
>> In Version: 3.4.0
>> when I click on index.html in my project. Any ideas?
I'm not sure which day I installed, maybe 5/28/2008.
Sorry, prerequistes for what? I installed eclipse-SDK-3.4RC2-win32 and
added j2ee 3.0.0 and wst 3.0.0
Are you
yes, 5.0
> Nitin Dahyabhai
> IBM Rational
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215537 is a reply to message #215529] Mon, 16 June 2008 16:42 Go to previous messageGo to next message
>>> In Version: 3.4.0
> Are you
> yes, 5.0
The download page should have a section labeled "Required
Prerequisites and Handy Extras" that links to the additional
downloads you'll need.
Nitin Dahyabhai
IBM Rational
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215545 is a reply to message #215529] Mon, 16 June 2008 16:44 Go to previous messageGo to next message
Alternately you can just grab a pre-assembled Java EE package (the "
Eclipse IDE for Java EE Developers") from
http://www.eclipse.org/downloads/packages/ .
Nitin Dahyabhai
IBM Rational
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215553 is a reply to message #215537] Mon, 16 June 2008 17:09 Go to previous messageGo to next message
>>>> In Version: 3.4.0
>> Are you
>> yes, 5.0
> The download page should have a section labeled "Required Prerequisites
> and Handy Extras" that links to the additional downloads you'll need.
Thanks, but what download page are you referring to?
(Seems odd to have all of this fancy version information and then the
installer doesn't use it ?)
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215561 is a reply to message #215545] Mon, 16 June 2008 17:10 Go to previous messageGo to next message
Thanks, but I tried that first, but it does not have source or PDE so I
can't use it.
John.
> Nitin Dahyabhai
> IBM Rational
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215599 is a reply to message #215561] Tue, 17 June 2008 10:31 Go to previous messageGo to next message
>> " Eclipse IDE for Java EE Developers") from
> can't use it.
John, you should be able to use the latest Eclipse 3.4 RC4 SDK, and
install the J2EE component as well as the Web Tools 3.0 components. I
believe there were some issues with the earlier Eclipse 3.4 RC2 and RC3
builds that didn't resolve all the required dependencies. In addition,
you can also select from the Ganymede update site to install, GMF, EMF,
and XSD Runtimes from the Modeling Project.
But I would try with a newer build, and as for the J2EE Developer
Version, you should be able to add the PDE package from Ganymede.
Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215615 is a reply to message #215599] Tue, 17 June 2008 13:26 Go to previous messageGo to next message
>> I can't use it.
Thanks David...are you suggesting that 3.4 RC2 will not upgrade to RC4?
But this would still not have the source correct? Using PDE without the
source isn't fun.
> Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215639 is a reply to message #215615] Tue, 17 June 2008 15:31 Go to previous messageGo to next message
>>> I can't use it.
I personally still just install a clean version. Old habits die hard,
but I think you have to have a special update site included in order for
it to detect that it needs to upgrade from RC 2 to RC 4.
> source isn't fun.
You can always get the source from the PDE website, and extract the ZIP
file into your dropins folder. Some distributions are including the SDK
as an update site as well.
Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215662 is a reply to message #215639] Tue, 17 June 2008 17:57 Go to previous messageGo to next message
>>>> so I can't use it.
Hmm...seems like a curious update site that does not support updates.
Ok, so I'll go for your approach and reinstall everything. But can you
tell me the exact package to use? From the link
I can get the package eclipse-SDK-3.4RC4 (curiously called "Eclipse
Classic 3.4RC4" I guess they can't decide what to call it). But then I
need to add the j2ee and web tools 3.0 things. Can you recommend the url
for those guys?
>> the source isn't fun.
I tried that with eclipse-jee-ganymede-M6 and wasted a lot of time,
thanks anyway.
> Dave
Re: No editor descriptor for id org.eclipse.wst.html.core.htmlsource.source [message #215670 is a reply to message #215662] Tue, 17 June 2008 20:28 Go to previous message
You can get the Eclipse JEE developers edition, and then from within the
Ganymede update site, under Java Tools, add the Eclipse Plugin
Development Environment.
or
Download the Eclipse for Plugin / RCP Developers and then through the
ganymede update site, under Web Tools and Java EE install the select the
Eclipse XML Editors, Java EE Developers, Java Persistence, JavaScript
Developer Tools, Web Developer Tools and Web Page Editor.
That should get you everything in one environment.
Dave
Previous Topic:Re: ant projectSetImport in Eclipse 3.2 available?
Next Topic:Adding the RichFaces into the palette of the WTP JSP Editor
Current Time: Thu Jul 24 21:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.27862 seconds
