Trouble with facelet [message #215287] |
Fri, 13 June 2008 09:25  |
I've got these warnings or errors from Eclipse for some elements in an
XHTML I'm using that I don't know where to begin to resolve. I'm
following a facelets tutorial. I've included a good chunk of context
here without pasting in too much and I've numbered the error lines. In
particular, I have trouble with
1. "jsfc" in the first span tag: whence is this definition anyway? Is
is supposed to be something in one of the xmlns paths in the header?
2. Eclipse says the div tag is in an invalid location (a cascaded error
from #1?)
3. Due probably to the same cause as #1, value, action and action are
undefined on the line of the first anchor tag.
<!DOCTYPE html PUBLIC
"-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"
xmlns:f="http://java.sun.com/jsf/core"
xmlns:h="http://java.sun.com/jsf/html"
xmlns:ui="http://java.sun.com/jsf/facelets"
xmlns:rich="http://richfaces.org/rich"
xmlns:a4j="http://richfaces.org/a4j">
<body>
<!-- This is the whole qa tag; sort of like a C preprocessor macro
in JSF -->
*1 <span jsfc="ui:component">
*2 <div>
<form jsfc="h:form">
*3 <a jsfc="h:commandLink" value="#{q.questionText}"
action="#{q.toggle}" />
</form>
</div>
Thanks for your help in demystifying this topic. I am a very green
beginner (and, as the comment indicates, a very naive refugee from C).
Russ Bateman
Re: Trouble with facelet [message #215416 is a reply to message #215287] |
Sat, 14 June 2008 23:30  |
> from #1?)
> <body>
> <!-- This is the whole qa tag; sort of like a C preprocessor macro in
> JSF -->
> *2 <div>
> </form>
> </div>
> Russ Bateman
So, it appears there's no answer to this. I saw someone else ask this
question in another forum and there was no answer there, either, and the
forum seemed to reject my attempts to register in order to contact that
person (a Maarten D from Netherlands).
My answer, if it is one, was to turn off validation as jsfc isn't in any
namespace. Right-click on project, Preferences...->Validation->Override
Validation Preferences, unclick HTML Syntax Validator.
Ultimately, the code worked, but it's somewhat uncomfortable for me as
in my day job, I write low-level C code that is ported across 20-odd
*nix platforms, so if there's the slightest peep out of a compiler or
other tool, we consider it a national disaster that requires our full
attention.
Russ Bateman
FUDForum. Page generated in 0.25685 seconds
