Home » Language IDEs » Java Development Tools (JDT) » Iterator<E> - Iterator cannot be resolved to a type
Iterator<E> - Iterator cannot be resolved to a type [message #215391] Wed, 21 September 2005 11:50 Go to next message
I'm trying to determine if the following is an Eclipse bug, or something
I'm not understanding about generics. Here's the code fragment:
import java.util.LinkedList;
import java.util.List;
public class GenericsInteger {
* @param args
List<Integer> list = new LinkedList<Integer>();
list.add(1);
list.add(4);
list.add(-4);
for (Iterator<Integer> i = list.iterator(); i.hasNext();) {
Integer in = i.next();
System.out.println(in);
In the for loop, the error, " Iterator cannot be resolved to a type",
occurs on the Iterator<Integer> loop init part.
I'm running Eclipse3.1, with jdk1.5.0_05. (I see this is jdk1.5.0_03
also.) I've tried looking at the bug reports, and this forum, but I've
only seen issues with auto-assist templates, ot refactoring.
Thanks for the help,
Frank
Re: Iterator<E> - Iterator cannot be resolved to a type [message #215399 is a reply to message #215391] Wed, 21 September 2005 12:59 Go to previous messageGo to next message
> * @param args
> public static void main(String[] args) {
> list.add(1);
> list.add(4);
> list.add(-4);
Is it a typo or you missed the import for java.util.Iterator?
Olivier
Re: Iterator<E> - Iterator cannot be resolved to a type [message #215405 is a reply to message #215399] Wed, 21 September 2005 14:39 Go to previous messageGo to next message
Hi Olivier,
Hmmm... I overlooked the obvious! Missed import. Very sorry to have
taken up your time, but thanks for the help.
It works now!
Thanks, frank
>> * @param args
>> list.add(1);
>> list.add(4);
>> list.add(-4);
> Olivier
Re: Iterator<E> - Iterator cannot be resolved to a type [message #215413 is a reply to message #215405] Wed, 21 September 2005 15:17 Go to previous message
> It works now!
No problem.
Note that you don't need to import Iterator if you use the new for loop.
could be written like this:
for (Integer i : list) {
System.out.println(i);
You let the compiler taking care of the iteration over the list.
Olivier
Previous Topic:Problems with java.util.List assignments using JDK 1.5
Next Topic:migrate a jbuilder J2EE project (EJB-based) to eclipse?
Current Time: Sun Nov 09 09:27:20 EST 2025
Powered by FUDForum. Page generated in 0.03921 seconds
