Home » Language IDEs » ServerTools (WTP) » Missing Sun facelet DTD URL
Missing Sun facelet DTD URL [message #215265] Fri, 13 June 2008 09:08 Go to next message
<!DOCTYPE facelet-taglib PUBLIC
"-//Sun Microsystems, Inc.//DTD Facelet Taglib 1.0//EN"
"http://java.sun.com/dtd/facelet-taglib_1_0.dtd">
If I have the above header in foo.taglib.xml and on the third line, I
get a warning to the effect that
The file cannot be validated as the XML Schema
"http://java.sun.com/dtd/facelet-taglib_1_0.dtd" that is specified as
describing the syntax of the file cannot be located
where do I get the DTD and how do I stick Eclipse's nose into it so that
it recognizes it? Have I misspelled this DTD's name subtly and can't see
what's wrong? I know this URL doesn't exist, but neither can Sun find
anything that might help me based on the key words it fabricates from my
bad URL.
I got this URL out of a tutorial and suspect that its incorrectness is
at the root of other problems I have in this facelet exercise.
Russ Bateman
Re: Missing Sun facelet DTD URL [message #215272 is a reply to message #215265] Fri, 13 June 2008 09:20 Go to previous messageGo to next message
Russ,
A quick google search turned up
http://www.mojavelinux.com/blog/archives/2006/01/eclipse_dtd _trick/
> that it recognizes it? Have I misspelled this DTD's name subtly and
> can't see what's wrong? I know this URL doesn't exist, but neither can
> Sun find anything that might help me based on the key words it
> fabricates from my bad URL.
> Russ Bateman
Re: Missing Sun facelet DTD URL [message #215280 is a reply to message #215272] Fri, 13 June 2008 09:23 Go to previous messageGo to next message
Ed Merks wrote:
> Russ,
>> Thanks,
>> Russ Bateman
Hmmmm, yes, pretty helpful. I'll have to then see if I can find this
particular DTD given this useful information. I wonder if also, assuming
I can ever find this DTD, if there's not a place I could just simply
stick it in my project so it would always be there?
Best,
Russ
Re: Missing Sun facelet DTD URL [message #215296 is a reply to message #215280] Fri, 13 June 2008 09:36 Go to previous messageGo to next message
Windofkeltia,
I suspect the XML catalog will be useful for that...
Windofkeltia wrote:
> Ed Merks wrote:
>> Russ,
>>> I get a warning to the effect that
>>> as describing the syntax of the file cannot be located
>>> can Sun find anything that might help me based on the key words it
>>> is at the root of other problems I have in this facelet exercise.
>>> Thanks,
>>> Russ Bateman
> assuming I can ever find this DTD, if there's not a place I could just
> simply stick it in my project so it would always be there?
> Best,
> Russ
Re: Missing Sun facelet DTD URL [message #215312 is a reply to message #215296] Fri, 13 June 2008 10:43 Go to previous messageGo to next message
I found a tutorial for Exclipe's XML catalog--I didn't know of such a
thing.
Russ
Re: Missing Sun facelet DTD URL [message #215385 is a reply to message #215272] Fri, 13 June 2008 21:51 Go to previous message
Ed Merks wrote:
> Russ,
Wow, I ended up just using the trick and it worked like a charm. You had
to know the answer. Go figure that this little problem still exists in 2008!
Russ
Previous Topic:tomcat 6 with eclipse 3.2.2 ?
Next Topic:Trouble with facelet
Current Time: Sun Jul 27 03:48:31 EDT 2025
Powered by FUDForum. Page generated in 0.06973 seconds
