The example in the example of ibm Red book [message #215078] |
Wed, 26 April 2006 09:53  |
Exactly, how to change the old code to match eclipse 3.1.2 platform?
For the workflow example, I have got the project compiled but with a bit of
deprecated warnings. What's more, when I launched the project, no wizard
entries appear in the File-new-example folder.
Can anyone give me some help?
Re: The example in the example of ibm Red book [message #215094 is a reply to message #215078] |
Wed, 26 April 2006 12:12   |
Originally posted by: eclipse.chris-lott.org
I tried the cleanup also, and suspect I did this in the slowest, most
difficult way possible. Here's what I tried so far; it does not yet run.
1. Create simple project
2. Import entire contents of SAL330RWorkflowModel into it.
3. Right click the project, pick PDE Tools, then Convert Projects to
Plug-in Projects
That gets me to a state where eclipse reports these problems:
Illegal attribute 'availableAsShortcut'. plugin.xml
The method openEditor(IEditorInput, String) in the type IWorkbenchPage is
not applicable for the arguments (IFile) WorkflowModelWizard.java
I confess that I punted on these and simply removed the attribute in
plugin.xml, and commented out the entire try/catch in the java file. This
was enough to get the plugin to contribute to the New -> Examples wizard,
but it doesn't work right (doesn't launch) on a foo.flow file.
Next I right-clicked the project again, PDE Tools, then picked "Migrate to
3.0". This adds the runtime compatability dependency. That is not
enough either to make it run!
Maybe I have to create a MANIFEST.MF file using the plugin.xml manifest
editor.
chris...
Re: The example in the example of ibm Red book [message #215125 is a reply to message #215094] |
Wed, 26 April 2006 21:31   |
IDE.openEditor(page,modelFile,true);
I think the open editor can be replaced as above. But I have not yet tested.
"Chris Lott" <eclipse@chris-lott.org>
??????:ac53681be41d1a80a6b66a63036261a0$1@www.eclipse.org...
> Plug-in Projects
> editor.
> chris...
Re: The example in the example of ibm Red book [message #215315 is a reply to message #215125] |
Fri, 28 April 2006 20:47  |
That gets it working for me. The thing throws an EOFException when it
first starts up on an empty file, but it otherwise appears to run.
Paul Allen
FUDForum. Page generated in 0.06808 seconds
