Home » Language IDEs » Java Development Tools (JDT) » Format-Keys on Linux are not working
Format-Keys on Linux are not working [message #214635] Tue, 13 September 2005 08:23 Go to next message
Originally posted by: torsten.tkunkel.de
I've a strange problem. The shortkey for format code does not work
correctly, everytime I press Control-Shift-F (like on Windows) at the
cursors position a underlined F is displayed, when releasing the keys,
it dissapears.
I think the X-Server catches the keycombination, but Control-Shift-S for
organize imports works fine.
In order to get format code I've to hit escape and then press Control F
together.
The keymapping shows:
Category: Source
Command: Format
Key Sequence: Shift+Ctrl+F
When: Editing Java Source
and
Category: Source
Command: Format
Key Sequence: Esc Ctrl+F
I'm nearly shure the problem isn't eclipse, but I don't know where to
edit this behavior, so I hope someone has solved this already :)
Does anyone know something about this?
Greetings
Torsten
Re: Format-Keys on Linux are not working [message #214686 is a reply to message #214635] Wed, 14 September 2005 03:48 Go to previous messageGo to next message
This is a known GTK feature that happens for Ctrl+Shift+[A-F]
-tom
> it dissapears.
> together.
> Category: Source
> Command: Format
> and
> Category: Source
> Command: Format
> Greetings
> Torsten
Re: Format-Keys on Linux are not working [message #214722 is a reply to message #214686] Wed, 14 September 2005 11:00 Go to previous messageGo to next message
Then why does CRTL-SHIFT-F work for the MyEclipseIDE XML editor?
Re: Format-Keys on Linux are not working [message #214738 is a reply to message #214722] Wed, 14 September 2005 12:56 Go to previous messageGo to next message
I think the keybinding infrastructure supports that type of bindings
when they are declared via the plug-in XML, but you cannot create the
binding via the key binding preference page.
-tom
Re: Format-Keys on Linux are not working [message #214803 is a reply to message #214686] Thu, 15 September 2005 08:07 Go to previous messageGo to next message
Originally posted by: news.tkunkel.de
Hi Tom,
thankss for your information. Do you know if this is fix or if the keys
can be "cleared" in GTK's configs?
Torsten
Re: Format-Keys on Linux are not working [message #214810 is a reply to message #214803] Thu, 15 September 2005 08:41 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=42009
and https://bugs.eclipse.org/bugs/show_bug.cgi?id=46580
Markus
Torsten Kunkel wrote:
> Hi Tom,
> Torsten
Re: Format-Keys on Linux are not working [message #214824 is a reply to message #214738] Thu, 15 September 2005 09:41 Go to previous messageGo to next message
> -tom
I guess I am dense. If the keys work, why won't the binding preference
page let me select the key?
Re: Format-Keys on Linux are not working [message #214844 is a reply to message #214810] Thu, 15 September 2005 14:21 Go to previous message
Nice, really nice.
Now it seems I understand the problem and it looks like gtk will be
"fixed" or better improved.
So lets wait :)
Previous Topic:Adding your own ANT files as builders
Next Topic:How to recreate JDT indices?
Current Time: Sat Nov 08 10:43:40 EST 2025
Powered by FUDForum. Page generated in 0.03480 seconds
