Home » Language IDEs » ServerTools (WTP) » There is no Action mapped for namespace / and action name Hello.
There is no Action mapped for namespace / and action name Hello. [message #214565] Fri, 30 May 2008 03:50 Go to next message
Originally posted by: sadhika06.gmail.com
i am new to struts2. i created web-dynami project. Added the 4
jars(freemarker,ognl,struts2-core,xwork) in WEB-INF/lib. and added in the
web.xml
<filter>
<filter-name>struts2</filter-name>
<filter-class>org.apache.struts2.dispatcher.FilterDispatcher </filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
in srtuts.xml
<constant name="struts.enable.DynamicMethodInvocation" value="false" />
<constant name="struts.devMode" value="false" />
<package name="tutorial" namespace="/tutorial"
extends="struts-default">
<action name="Hello" class="tutorial.Hello">
<result>/hello.jsp</result>
</action>
<!-- Add more actions here -->
</package>
created a tutorial package under the src.
created a Hello.java file under tutorial.
created hello.jsp file under webcontent.
when i run the project i am getting the foll error.
There is no Action mapped for namespace / and action name Hello. -
[unknown location]
can anybody help me in finding the prob.
thanks in advance
bye
Re: There is no Action mapped for namespace / and action name Hello. [message #214579 is a reply to message #214565] Fri, 30 May 2008 08:27 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
I think you need to specify the package for your actions in web.xml as a init
param of the struts2 filter:
<filter>
<filter-name>struts</filter-name>
<filter-class>
</filter-class>
<init-param>
<param-name>actionPackages</param-name>
<param-value>com.package.of.my.actions</param-value>
</init-param>
</filter>
The rest of your config seems OK (though I think you don't need the
namespace="/tutorial" attribute in your struts.xml).
Hope this helps
Wolfgang
Re: There is no Action mapped for namespace / and action name Hello. [message #214616 is a reply to message #214579] Fri, 30 May 2008 19:48 Go to previous messageGo to next message
Originally posted by: abc.gmail.com
Hi WolfGanag,
Thanks for ur reply.
i tried adding init-param but no luck, still same error.
i also tried the zero-configuration like renaming the action class Hello
to HelloAction,but no luck
bye
Re: There is no Action mapped for namespace / and action name Hello. [message #214708 is a reply to message #214616] Mon, 02 June 2008 05:12 Go to previous messageGo to next message
I don't have any further ideas. If your code is not too large, you could export
it as a WAR file and post it here, maybe I can help.
Wolfgang
kannalu schrieb:
> Hi WolfGanag,
> bye
Re: There is no Action mapped for namespace / and action name Hello. [message #214762 is a reply to message #214708] Tue, 03 June 2008 02:16 Go to previous messageGo to next message
Originally posted by: abc.mail.com
where can i upload the war file
thank you
Re: There is no Action mapped for namespace / and action name Hello. [message #214769 is a reply to message #214762] Tue, 03 June 2008 05:00 Go to previous message
I don't know how you could do it through the forum website, I use a NNTP client
for this.
You could mail it to me: wolfgang DOT knauf AT gmx DOT de
Best regards
Wolfgang
kannalu schrieb:
> thank you
Previous Topic:Reusing WTP Server definitions for deploying artifacts
Next Topic:Setting TCP/IP Monitor max message size
Current Time: Sun Jul 27 11:47:48 EDT 2025
Powered by FUDForum. Page generated in 0.05156 seconds
