Home » Language IDEs » ServerTools (WTP) » Alternate way of packaging projects for deployment
Alternate way of packaging projects for deployment [message #213603] Sun, 11 May 2008 14:35 Go to next message
For Maven integration (in IAM project proposal), we've integrated maven
web projects with wtp so they can be launched on any configured server.
However, WTP is doing the packaging. We would like to let Maven do it
(or achive a jar/war file that's equivalent to what maven would have
generated). This is because in maven build resources can be modified
before packaging.
Could I get some pointers about how this can be done?
Also, if there is an overview of the deployment process available, it
would come handy :-)
Thanks!
Abel Muiño Vizcaino - http://ramblingabout.wordpress.com
Re: Alternate way of packaging projects for deployment [message #213808 is a reply to message #213603] Wed, 14 May 2008 06:54 Go to previous messageGo to next message
Any pointers I could look at?
Test cases or sample code would do.
> before packaging.
> Thanks!
Re: Alternate way of packaging projects for deployment [message #213816 is a reply to message #213808] Wed, 14 May 2008 07:54 Go to previous messageGo to next message
http://maven.apache.org/plugins/maven-war-plugin/
Since you are already using Maven your <packaging> should already be war.
mvn package
will build be package
mvn release:prepare release:perform
will do the full release cycle
Cheers
Philippe
>> maven web projects with wtp so they can be launched on any configured
>> server.
>> before packaging.
>> Thanks!
Re: Alternate way of packaging projects for deployment [message #213848 is a reply to message #213603] Wed, 14 May 2008 11:44 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Abel,
In WTP, server adapters own the publishing logic (which includes getting
the app ready for publishing). There is a publish steps extension
point that lets you add additional logic to the publish operation, but
there is no way to completely replace the packaging. That wouldn't work
anyway, since different server adapters have different requirements for
the form that the app must be in for publishing. Some require a WAR
archive, some require an exploded WAR directory, and some have
proprietary descriptors that tell the server where to find pieces of the
WAR without actually physically assembling it.
- Konstantin
Re: Alternate way of packaging projects for deployment [message #214012 is a reply to message #213848] Mon, 19 May 2008 14:10 Go to previous message
Thanks Konstantin,
So the only way would be to create new server adapters which mimic
existing ones but with a "maven flavour"?
By looking at the Javadoc, it would seem that overriding
ServerBehaviourDelegate.publish() could do the trick (still, new servers
would be required).
Is there any pitfall I'm not seeing?
Konstantin Komissarchik wrote:
> Abel,
> getting the app ready for publishing). There is a publish steps
> extension point that lets you add additional logic to the publish
> operation, but there is no way to completely replace the packaging.
> That wouldn't work anyway, since different server adapters have
> different requirements for the form that the app must be in for
> publishing. Some require a WAR archive, some require an exploded WAR
> directory, and some have proprietary descriptors that tell the server
> where to find pieces of the WAR without actually physically assembling
> it.
> - Konstantin
Previous Topic:Renaming a project does not update org.eclipse.wst.common.component
Next Topic:Tomcat-6
Current Time: Wed Jul 23 02:39:14 EDT 2025
Powered by FUDForum. Page generated in 0.06616 seconds
