2.2 source using extension points that can't be found [message #213457] |
Tue, 23 January 2007 16:47  |
When I try to build the latest 2.2 Source head I cannot get the
org.eclipse.birt.report.engine plugin to build.
The problem is the plugin.xml uses extension points
"org.eclipse.core.runtime.applications"
"org.eclipse.core.runtime.products"
which aren't resolving for me.
My setup is as follows, I'm using JRE 1.5 and as my target I'm using the
build
birt-report-designer-all-in-one-2.2.0-N20070110.zip
In my target and I just turn off the BIRT specific plug-ins (so I can
run from BIRT source). The BIRT source is from the BIRT HEAD and matches
the set of BIRT plugins that are in the zip file.
any ideas?
FUDForum. Page generated in 0.27399 seconds
