Home » Language IDEs » ServerTools (WTP) » Missing Wizard - Create Dynamic Web Project
Missing Wizard - Create Dynamic Web Project [message #213511] Fri, 09 May 2008 12:07 Go to next message
I've been selected by my team to be the first to move from Eclipse 3.3
to 3.4.
After installing 3.4 and some other stuff (See 'Installed Features'
below), I launch the new wizard (Ctrl-N), and start looking for the
Dynamic Web Project, but it's not there.
Can anyone help me figure out what I am missing in my installation that
is causing this wizard to not be available?
OBTW my Plug-in Registry view shows no errors. It seems that all of my
plug-ins are installed properly and their dependencies are resolved.
Trace
Installed Features:
I got this list from the Configuration Details Dialog.
*** Features:
org.eclipse.cvs (1.1.0.v20080408-7C79E8M9EI99l_LFR) "Eclipse CVS Client"
org.eclipse.datatools.doc.user (1.6.0.v200804021-34-8w95BIAIDJ5) "Data
Tools Platform User Guide"
org.eclipse.datatools.intro (1.6.0.v200804021-1--311817182) "Eclipse
Data Tools Platform Intro Plug-in"
org.eclipse.datatools.sdk.feature.source (1.6.0.v200804021) "Eclipse
Datatools Source"
org.eclipse.draw2d (3.4.0.v20080115-33-7w31191512) "Graphical Editing
Framework Draw2d"
org.eclipse.emf.common (2.4.0.v200804012208) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200804012208) "EMF Common UI"
org.eclipse.emf.ecore (2.4.0.v200804012208) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.0.v200804012208) "EMF Ecore Edit Support"
org.eclipse.emf.edit (2.4.0.v200804012208) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.0.v200804012208) "EMF Edit UI"
org.eclipse.gef (3.4.0.v20080115-677-8082A5684C2623) "Graphical Editing
Framework GEF"
org.eclipse.help (1.0.0.v20080407a-7r7wEIqEJkXu6mI9_7rPB5trz00j) "Help
System Core"
org.eclipse.jdt (3.4.0.v20080407-34m6a-7o7sEC6EFpPqmeZEz03FkQQgb)
"Eclipse Java Development Tools"
org.eclipse.jst (3.0.0.v200804020555-7K-8Y8pUUqZVMG_Yz0vB25SwI4Qb) "J2EE
Standard Tools (JST)"
org.eclipse.pde (3.4.0.v20080324a-7R7V-E_EkMNqMuiJAW4IGb) "PDE"
org.eclipse.platform
(3.4.0.v20080407a-9F94EjREj_sBIPliz-q3jhtr1QcUunY6usz011k) "Eclipse
Platform"
org.eclipse.rcp (3.4.0.v20080407a-969KEWNEjMvdgqqz-iNmVtQp) "Eclipse RCP"
org.eclipse.sdk
(3.4.0.v20080407a-7M7S-BI5lqaYZ_jz09lyqy6ADz0OqUJkh4cZGPZSDp wMF)
"Eclipse Project SDK"
org.eclipse.wst (3.0.0.v200712121937-7K788Z8qMfmB34dKEnQdJXwiNU-H) "Web
Standard Tools (WST)"
org.eclipse.xsd (2.4.0.v200804012208) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.4.0.v200804012208) "XML Schema Edit Framework"
Re: Missing Wizard - Create Dynamic Web Project [message #213527 is a reply to message #213511] Fri, 09 May 2008 12:53 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Make sure you are running with at least a Java 5 JRE.
Dave
> to 3.4.
> Trace
> Installed Features:
> *** Features:
> Datatools Source"
> Framework Draw2d"
> Framework GEF"
> System Core"
> Platform"
> org.eclipse.sdk
Re: Missing Wizard - Create Dynamic Web Project [message #213536 is a reply to message #213527] Fri, 09 May 2008 14:11 Go to previous messageGo to next message
I'm using JDK 1.6.0_03
> Dave
>> to 3.4.
>> that is causing this wizard to not be available?
>> Thanks,
>> Trace
>> Installed Features:
>> *** Features:
>> Datatools Source"
>> Framework Draw2d"
>> Editing Framework GEF"
>> System Core"
>> "J2EE Standard Tools (JST)"
>> Platform"
>> org.eclipse.sdk
>> "Web Standard Tools (WST)"
Re: Missing Wizard - Create Dynamic Web Project [message #213544 is a reply to message #213536] Fri, 09 May 2008 14:33 Go to previous messageGo to next message
>> Dave
Dynamic Web Project, should be under New->Project->Web->Dynamic Web Project.
I've verified this with Eclipse 3.4M7 and Web Tools 3.0M7.
Dave
Re: Missing Wizard - Create Dynamic Web Project [message #213553 is a reply to message #213511] Fri, 09 May 2008 14:49 Go to previous messageGo to next message
> to 3.4.
Perhaps if you also listed which files you downloaded, or whether
you installed them using the Update Manager?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Missing Wizard - Create Dynamic Web Project [message #213566 is a reply to message #213553] Fri, 09 May 2008 15:45 Go to previous messageGo to next message
First I downloaded Eclipse 3.4M6 labeled (Eclipse for RCP/Plug-in
Developers) from this URL http://phoenix.eclipse.org/packages/
I chose this one since RCP application development is my main focus.
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/M6/eclipse-rcp-ganymede-M6 -win32.zip
Then I went to http://download.eclipse.org/webtools/downloads/ and chose
the 3.0M7 version which took me to here
http://download.eclipse.org/webtools/downloads/drops/R3.0/S- 3.0M7-20080506040630/
I unzipped and put the resulting plug-in folder and feature folder in
the dropin folder of my new Eclipse install.
Then I went to http://www.eclipse.org/datatools/downloads.php and chose
the DTP 1.6M7 link which is
http://www.eclipse.org/downloads/download.php?file=/datatool s/downloads/1.6/dtp-sdk-1.6M7.zip
I unzipped that file and put the resulting plugin and feature folder in
the Eclipse dropins folder.
When I launch this Eclipse, I don't see the Dynamic Web Project wizard
anywhere.
On a positive note: I have just found a wonderful dialog called the
'Product Configuration' dialog. I call this wonderful because it shows
me that some of my features are not configured properly by placing a
little red x beside them and then reporting which plug-ins that it
thinks are missing. There are a lot of little red x's
I will now try a different strategy. My next step is going to be to go
to here: http://phoenix.eclipse.org/packages/ and chose the link labeled
'...for Java EE Developers' which leads to here:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/M6/eclipse-jee-ganymede-M6 -win32.zip
My theory is that the pre packaged eclipse install for J2EE developers
will have the WTP working properly.
If that package gives me the Create Dynamic Web Project that I am
looking for, then I will use that Eclipse install and try to add the
features I need for RCP development to it.
Trace
>> to 3.4.
> Perhaps if you also listed which files you downloaded, or whether you
Re: Missing Wizard - Create Dynamic Web Project [message #213586 is a reply to message #213566] Fri, 09 May 2008 21:56 Go to previous messageGo to next message
You also, need the EMF, XSD, and GEF plugins as well available on the
same page.
Dave
> anywhere.
> Trace
>>> 3.3 to 3.4.
>>> my plug-ins are installed properly and their dependencies are resolved.
Re: Missing Wizard - Create Dynamic Web Project [message #213677 is a reply to message #213586] Tue, 13 May 2008 11:14 Go to previous message
Thanks for the help David,
I finally gave up on the Plug-In Developers package and took the easy
way out by downloading the Eclipse IDE for Java EE Developers.
( http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/ganymede/M6/eclipse-jee-ganymede-M6 -win32.zip)
When I use this packaged version of Eclipse 3.4M6, the wizard that
creates a Dynamic Web Project is available right where it should be.
Thanks again,
Trace
> same page.
> Dave
>> chose the 3.0M7 version which took me to here
>> chose the DTP 1.6M7 link which is
>> in the Eclipse dropins folder.
>> anywhere.
>> shows me that some of my features are not configured properly by
>> placing a little red x beside them and then reporting which plug-ins
>> that it thinks are missing. There are a lot of little red x's
>> go to here: http://phoenix.eclipse.org/packages/ and chose the link
>> labeled '...for Java EE Developers' which leads to here:
>> Thanks,
>> Trace
>>>> 3.3 to 3.4.
Previous Topic:Use WTP XML model for programatically modifying a file
Next Topic:eclipse support for struts2 and hibernate
Current Time: Thu Jul 24 22:54:17 EDT 2025
Powered by FUDForum. Page generated in 0.04384 seconds
