Home » Language IDEs » ServerTools (WTP) » WSDL Editor
WSDL Editor [message #213146] Thu, 01 May 2008 06:09 Go to next message
Originally posted by: massimoarra.gmail.com
Hi, could anybody help me finding the source code of the WSDL Editor?
Massimo
Re: WSDL Editor [message #213170 is a reply to message #213146] Thu, 01 May 2008 07:19 Go to previous messageGo to next message
Massimo,
See my answer in the preceding note chain. If you have the full WTP
SDK installed, you can use Window->Show View->Other...->PDE->Plug-ins,
select all the plugins in that view and use the popup to "Add to Java
Search". Then you should be able to use Ctrl-Shift-T, type in any class
name in any plugins, and the source view for that class should open...
> Massimo
Re: WSDL Editor [message #213185 is a reply to message #213170] Thu, 01 May 2008 10:29 Go to previous message
Massimo,
If you're talking about source from CVS, it's found in:
dev.eclipse.org:/cvsroot/webtools
For latest code:
HEAD
|- org.eclipse.wst.wsdl.ui
Ed Merks wrote:
> Massimo,
>> Thanks,
>> Massimo
Previous Topic:JSP validator with scriptlet tag files
Next Topic:Re: Can't get XSD graphical editor working...
Current Time: Thu Jul 24 23:07:09 EDT 2025
Powered by FUDForum. Page generated in 0.05874 seconds
