Home » Language IDEs » ServerTools (WTP) » 3.0M6
3.0M6 [message #212287] Fri, 11 April 2008 09:28 Go to next message
Originally posted by: jmordax.terra.es
At http://download.eclipse.org/webtools/downloads/ I have seen 3.0M6
available. Is possible to update from M5 to M6 using Update Manager?
Which update site should I use?
Chemi.
Re: 3.0M6 [message #212402 is a reply to message #212287] Tue, 15 April 2008 13:56 Go to previous messageGo to next message
> Chemi.
I wouldnt' recommend it, but it might work. The base platform added a new update manager in
M6a, so not sure how they'd interact. In fact, not even sure how good the new one works yet!.
But, I'd recommend starting with the new Eclispe SDK M6a in a fresh install, or one of the
all-in-one packages.
Just today, the Ganymede Coordinated Milestone is available.
You can get some "all-in-one" packages, from
http://phoenix.eclipse.org/packages/
And, the ganymede update site is
http://download.eclipse.org/releases/ganymede/
Though, honestly, I've been having some trouble with it working as expected today.
I think you may have to basically select everything that's needed "by hand"?
The WTP specific update for milestones is
http://download.eclipse.org/webtools/milestones/
That can be useful site if you need the "source" or SDK version from update mangaer.
Also, the incubating XSL Feature is available from there.
Re: 3.0M6 [message #212421 is a reply to message #212402] Wed, 16 April 2008 15:45 Go to previous message
>> Thanks,
>> Chemi.
Thanks David.
I tried the new updater and it seems it worked. I just had to add:
as update site and I have it working...
Chemi.
Previous Topic:Problem installing Geronimo server adapter to Eclipse R3.4M6/WTP 3.0M6
Next Topic:Validation of JSP
Current Time: Thu Jul 24 23:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.05294 seconds
