Home » Eclipse Projects » GEF » How to change the width of connection?
How to change the width of connection? [message #211838] Wed, 15 March 2006 21:22 Go to next message
Originally posted by: brandonchen.realtek.com.tw
Can I change the width of the conection line? I want to
let user set the line width while connecting from different
nodes. Appreciated for any reply.
Brandon
Re: How to change the width of connection? [message #211927 is a reply to message #211838] Thu, 16 March 2006 10:04 Go to previous messageGo to next message
If you are using the standard PolylineConnection in your connection edit
part, you can override the createFigure() method of the
AbstractConnectionEditPart like the following:
protected IFigure createFigure() {
PolylineConnection conn =
(PolylineConnection) super.createFigure();
conn.setLineWidth(10);
return conn;
Hope this helps.
> Brandon
Re: How to change the width of XYAnchor connection? [message #211978 is a reply to message #211927] Thu, 16 March 2006 21:49 Go to previous messageGo to next message
Appreciated for reply.
But if I use XYAnchor to set up a line, how to change the width of XYAnchor
Connection?
I can not find the method that draws the connection from XYAnchor. Where is
the method?
It would be great if I can override that method. Appreciated for any reply.
Brandon
"Scott Hathaway" <scott_hathaway@iwaysoftware.com> ???
news:dvbuut$ksa$1@utils.eclipse.org ???...
> return conn;
> Hope this helps.
> > Brandon
Re: How to change the width of XYAnchor connection? [message #212010 is a reply to message #211978] Fri, 17 March 2006 02:17 Go to previous message
Thanks Scott. Your idea just gave me some clues and solved
the problem. Because it helps me to think that the XYAnchor
connection might be also drawn from a PolylinConnection, I
find it is refreshed in AbstractConnectionEditPart # refreshTargetAnchor()
Thus All I have to let myLineEditPart inherits AbstractConnectionEditPart
and overwrites the method like this:
protected void refreshTargetAnchor() {
int width = 5;
if(connection instanceof PolylineConnection){
((PolylineConnection)connection).setLineWidth(width);
Then the line width is set.
Brandon
> > return conn;
> > Hope this helps.
> > > Brandon
Previous Topic:Serial Version InvalidClassException
Next Topic:How to draw a line?
Current Time: Sat Jul 19 02:35:10 EDT 2025
Powered by FUDForum. Page generated in 0.03024 seconds
