Home » Language IDEs » ServerTools (WTP) » Attaching standard XML outline view to custom editor
Attaching standard XML outline view to custom editor [message #211010] Tue, 25 March 2008 19:16 Go to next message
Hi, everyone.
I would like to attach the standard XML outline view of the WST project to
a graphical custom editor for XML files.
How can I return an XML outline page in getAdapter() without subclassing
or using XMLMultiPageEditorPart or the embedded StructuredTextEditor? The
actual outline pages that are created seem to be of the type
ConfigurableContentOutlinePage (configured with
StructuredTextViewerConfigurationXML) which have restricted access. Can I
somehow use these without the SSE editors?
I found the thread "hooking up xml outline view to custom xml
contentType", but the given examples all use or subclass
XMLMultiPageEditorPart. Apart from that, I couldn't find much information
about SSE customization on the newsgroups. If there is more general
documentation available, please point me to it.
Gerrit
Re: Attaching standard XML outline view to custom editor [message #211186 is a reply to message #211010] Thu, 27 March 2008 11:23 Go to previous messageGo to next message
> to a graphical custom editor for XML files.
> The actual outline pages that are created seem to be of the type
> I somehow use these without the SSE editors?
Yes, the page class, while in an internal, non-API,
we-could-change-this-at-any-time package, is public, and the
XMLContentOutlineConfiguration class we use is itself API. The
StructuredTextEditor.getAdapter(Class) method shows how the page is
constructed, and as long as the model going in is an IDOMModel, the
outline page doesn't care what editor is using it (or, for the most
part, if an editor is using it). If you mean to use it with another
W3C XML DOM implementation, that's not supported.
> information about SSE customization on the newsgroups. If there is more
> general documentation available, please point me to it.
The general documentation exists at
http://www.eclipse.org/webtools/sse/ and in EclipseCon presentations
such as at http://www.eclipsecon.org/2008/?page=sub/&id=280 .
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Attaching standard XML outline view to custom editor [message #211217 is a reply to message #211186] Thu, 27 March 2008 22:30 Go to previous messageGo to next message
Originally posted by: david_whiteman.us.ibm.com
Nitin Dahyabhai wrote:
>> project to a graphical custom editor for XML files.
>> subclassing or using XMLMultiPageEditorPart or the embedded
>> StructuredTextEditor? The actual outline pages that are created seem
>> to be of the type ConfigurableContentOutlinePage (configured with
>> Can I somehow use these without the SSE editors?
> part, if an editor is using it). If you mean to use it with another W3C
>> more general documentation available, please point me to it.
> The general documentation exists at http://www.eclipse.org/webtools/sse/
> and in EclipseCon presentations such as at
> Nitin Dahyabhai
> IBM Rational
I tried the approach of switching the source tab of my multi-page editor
from a TextEditor to a StructuredTextEditor, and the outline view didn't
show initially, until I clicked on it and then clicked away from it. Is
there a reason that would happen, and is there a way I can force the
outline to display as soon as the editor opens?
My apologies if this is discussed somewhere in the doc, but I suspect
that it describes a more complex approach, and I'm trying to fit it into
my current design.
David
Re: Attaching standard XML outline view to custom editor [message #211300 is a reply to message #211217] Fri, 28 March 2008 14:34 Go to previous messageGo to next message
> my current design.
Do you mean the view wasn't open or that it was visible but empty
initially?
Nitin Dahyabhai
IBM Rational
Re: Attaching standard XML outline view to custom editor [message #211324 is a reply to message #211300] Sat, 29 March 2008 08:06 Go to previous messageGo to next message
>> editor from a TextEditor to a StructuredTextEditor, and the outline
>> view didn't show initially, until I clicked on it and then clicked
>> away from it. Is there a reason that would happen, and is there a way
>> I can force the outline to display as soon as the editor opens?
>> into my current design.
> initially?
Sorry, the latter. The view was visible but empty.
Re: Attaching standard XML outline view to custom editor [message #211399 is a reply to message #211324] Tue, 01 April 2008 09:13 Go to previous messageGo to next message
>> initially?
Could you post the code you're using to create and set the input on
the outline page? I've never seen that behavior before.
Nitin Dahyabhai
IBM Rational
Re: Attaching standard XML outline view to custom editor [message #211434 is a reply to message #211399] Tue, 01 April 2008 10:17 Go to previous messageGo to next message
>>> initially?
> Could you post the code you're using to create and set the input on the
I actually don't have any code for that. I have a subclass of
StructuredTextEditor, and am relying on the inherited behavior from the
adapter retrival method.
David
Re: Attaching standard XML outline view to custom editor [message #211517 is a reply to message #211434] Tue, 01 April 2008 23:41 Go to previous messageGo to next message
>>>> initially?
Were you returning that adapter regardless of which editor page you
were showing when opening your editor?
Nitin Dahyabhai
IBM Rational
Re: Attaching standard XML outline view to custom editor [message #211812 is a reply to message #211517] Fri, 04 April 2008 12:35 Go to previous messageGo to next message
> Were you returning that adapter regardless of which editor page you were
I guess. It depends on when that gets called. Since the structured
text editor is just on one page, I had assumed (without checking) that
the adapter gets called when the editor page is activated.
Re: Attaching standard XML outline view to custom editor [message #211861 is a reply to message #211812] Sat, 05 April 2008 19:21 Go to previous message
No, none of the other parts know about the internals of a multi-page
editor--your editor is effectively asked once. If you want to show
different outlines for each of your pages, you need to manage them
yourself somehow.
Nitin Dahyabhai
IBM Rational
Previous Topic:JBoss and WTP
Next Topic:Re: dreamwaver
Current Time: Sat Jul 26 21:10:04 EDT 2025
Powered by FUDForum. Page generated in 0.95020 seconds
