Home » Archived » Maven Integration (M2E) » pluginManagement, extensions versioning issue
pluginManagement, extensions versioning issue [message #21123] Mon, 19 January 2009 11:21 Go to next message
Jetty uses the o.a.felix:maven-bundle-plugin for getting the osgi
manifests in order but lately with the m2e plugin I am getting the
following error for about 20 or so sub-projects (each module declaring
the plugin).
Project build error:Cannot resolve pre-scanned plugin artifact (for use
as an extension): org.apache.felix:maven-bundle-plugin: Failed to
resolve extension plugin:
org.apache.felix:maven-bundle-plugin:maven-plugin:RELEASE pom.xml jetty
line 1 Maven Problem
The top level project file declares the version (1.4.0) in the
pluginManagement section but that doesn't seem to matter. There are
some relativePath statements that might be a factor, and then the plugin
declaration also includes <extension>true</extension>
thoughts?
jesse
Re: pluginManagement, extensions versioning issue [message #21140 is a reply to message #21123] Mon, 19 January 2009 11:58 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
What jetty version are you building (svn url)? I want try it locally to
see what is going on.
Igor
> the plugin).
> jetty line 1 Maven Problem
> thoughts?
> jesse
Re: pluginManagement, extensions versioning issue [message #21155 is a reply to message #21140] Mon, 19 January 2009 16:34 Go to previous messageGo to next message
Igor, just pull down the 7.0.x one from your plugin dropdown, most of
the modules will be red after materialization.
jesse
> Regards,
> Igor
>> the plugin).
>> use as an extension): org.apache.felix:maven-bundle-plugin: Failed to
>> pom.xml jetty line 1 Maven Problem
>> plugin declaration also includes <extension>true</extension>
>> thoughts?
>> jesse
Re: pluginManagement, extensions versioning issue [message #21173 is a reply to message #21123] Fri, 23 January 2009 01:47 Go to previous messageGo to next message
Originally posted by: lists.remove-me.varnes.remove-me.net
* Jesse McConnell wrote, On 20/01/09 03:21:
> the plugin).
> thoughts?
> jesse
I can confirm this as well. If the version of the bundle plugin is
inherited from a parent <pluginManagement>, this problem occurs.
Specifying the version locally is a (unpalatable) work-around.
I have been thinking it is because the bundle plugin is declared
as an extension ?
thanks
davidv
Re: pluginManagement, extensions versioning issue [message #21186 is a reply to message #21173] Fri, 23 January 2009 15:10 Go to previous messageGo to next message
> as an extension ?
Agreed, that was my suspicion..
> thanks
> davidv
Re: pluginManagement, extensions versioning issue [message #21699 is a reply to message #21186] Sat, 07 February 2009 23:23 Go to previous message
* Jesse McConnell wrote, On 24/01/09 07:10:
>> as an extension ?
>> thanks
>> davidv
A search of JIRA brings up quite a few issues with extension related
origins. I am sure the response will be to see if the issues go away
with the merge of an updated 3.x embedder.
In the meantime, responding to Jason's call for voting on issues,
the following issue seems to match our case, you may consider
voting:
http://jira.codehaus.org/browse/MNGECLIPSE-487
regards
davidv
Previous Topic:[tycho-0.3.0-DEV-1983] Issues with product export
Next Topic:[tycho-dev-1819] error while building jar
Current Time: Fri Sep 19 13:33:49 EDT 2025
Powered by FUDForum. Page generated in 0.04557 seconds
