Home » Eclipse Projects » Buckminster dev » Problems materialising & building Buckminster
Problems materialising & building Buckminster [message #21175] Tue, 15 July 2008 11:10 Go to next message
Hi There,
Trying to build Buckminster in eclipse 3.4 on Vista and hit a problem.
I followed the cquery [1] listed on the Buckminster committer wiki page
[2] and have run into the error below. Is there anything else I need to
do with my eclipse env in order to correctly materialise the source
tree? Not sure why it's trying to bring in a Linux x86_64 bit version of SWT
Many Thanks,
Adrian.
[1]
http://www.eclipse.org/buckminster/samples/queries/buckminst er-dev.cquery
[2]
http://wiki.eclipse.org/Committer_access_(Buckminster)#Working_and_merging.
ERROR [0007] : No suitable provider for component
org.eclipse.swt.gtk.linux.x86_64:osgi.bundle(&(target.os =linux)(target.ws=gtk)(target.arch=x86_64))
was found in searchPath org.eclipse.platform
ERROR [0007] : Resolution attempt ended with exception: Exception
connecting to
http://download.eclipse.org/eclipse/updates/3.4/plugins/org. eclipse.swt.gtk.linux.x86_64_3.4.0.v3448f.jar.
Re: Problems materialising & building Buckminster [message #21194 is a reply to message #21175] Tue, 15 July 2008 11:52 Go to previous messageGo to next message
Adrian Skehill wrote:
> Hi There,
> SWT
Unless you have the delta-pack installed, the buckminster-dev cquery
will import fragments for all platforms into your workspace. It needs
them in order to build the complete update site.
> connecting to
Not sure why you get an error when connecting to this URL. It seems to
work fine, at least from my end. Could it be some intermittent network
problem?
Thomas Hallgren
Re: Problems materialising & building Buckminster [message #21208 is a reply to message #21194] Tue, 15 July 2008 12:41 Go to previous messageGo to next message
Thanks Thomas,
>> page [2] and have run into the error below. Is there anything else I
>> need to do with my eclipse env in order to correctly materialise the
>> source tree? Not sure why it's trying to bring in a Linux x86_64 bit
>> version of SWT
>> connecting to
> problem?
Tried the materialisation again and it failed later on in the process.
Tried it again and it got as far as putting stuff into the workspace but
ran into issues with files being locked. Finally switched to a new
workspace and started again, this time it succeeded. Now the only thing
is, should Buckminster deal with transient network problems a little
more gracefully?
Thanks for your help.
Adrian.
Re: Problems materialising & building Buckminster [message #21224 is a reply to message #21208] Wed, 16 July 2008 02:54 Go to previous messageGo to next message
> ...Now the only thing
> more gracefully?
Indeed. We should have some preferences for a connection retry count and
retry delay or something. Could you please enter a bugzilla for that?
Thomas
Re: Problems materialising & building Buckminster [message #21240 is a reply to message #21224] Wed, 16 July 2008 04:14 Go to previous message
Bug 241048 submitted.
A.
Previous Topic:[buckminster-dev] Buckminster feature export does not match eclipse pde feature export
Next Topic:Question on SVN materialisation when svn+ssh (and subclipse)
Current Time: Fri Nov 07 06:53:16 EST 2025
Powered by FUDForum. Page generated in 0.04630 seconds
