| Jar-in-a-jar [message #211403] |
Sun, 20 May 2007 12:55  |
Originally posted by: ZioNemo.hotmail.com
Hi all,
The problem is quite simple:
I have an application that uses some non-standard libraries (freemarker &
grappa) that come as standalone .jar files (freemarker.jar &
grappa1_2.jar).
I put those in a nice subdirectory in my project (lib) and instructed
eclipse to look into that.
All is good.
I can run my application from the IDE.
Now I'm exporting my Application as a .jar file and I selected to export
the lib/*.jar files.
Eclipse dutifully includes my lib subdirectory in the .jar file.
Unfortunately java seems unable to access these "included" jars and I have
to manually extract from the jar lib and all its contents to have them
alongside the main application jar.
Is there some way to avoid this step?
I *think* (I didn't actually try) I could extract the lib/jars content and
include it in my jar, but it seems rather messy. Is there any other
(possibly better) solution? Can I convince eclipse to do this for me?
Other related (possibly harder) issue: I also have an executable I use as
a filter and I launch using ProcessBuilder.start() (I actually have
several executables, obviously, one for each platform I need to run on).
This executable is in the /lib subdirectory in my application jar file. Is
there any way to run it from there without explicitly extracting it?
Thanks in Advance
ZioNemo
| Re: Jar-in-a-jar [message #211498 is a reply to message #211470] |
Mon, 21 May 2007 12:16  |
Eric Rizzo wrote:
> Michael Pellaton wrote:
>> Hi
>> Java does in general - this is not an Eclipse isse - not recursively
>> unpack JAP files. However, there are three solutions for your
>> problem I would consider:
>> 1) deploy the jars separately and write a small script that correctly
>> assembles the classpath and runs your application
>> 2) http://fjep.sourceforge.net/
>> 3) unpack the external jars and repack them in a single jar including
>> your classes too. Some programs (especially some framework
>> components) even rename the packages of their dependencies to avoid
>> problems with different versions of the in the target environment.
> You should be aware that distributing your application with options 2
> and 3 above will violate the license terms of some libraries. Before
> distributing in either of those ways you should review the licenses to
> make sure - or better yet, have an attorney who is experienced with
> software licensing review them.
Thanks to all,
I actually chose option (4) :) ;) :)
I packed all libraries (jars and executables) in the main JAR.
Then I wrote a small initialization script in my main() that checks if the
lib subdirectory exists and, if needed, creates it extracting from the JAR
itself.
It seems to work.
One little quirk: I must explicitly give the JAR name to the
JAR-extraction class. Is there any way to get the name of the JAR
containing a certain class? something like
this.getClass().getContainingJar() or the like?
ZioNemo
FUDForum. Page generated in 0.30073 seconds
