Home » Modeling » GMF (Graphical Modeling Framework) » Feature or Bug? Empty properties with multiplicities of n are created as attribute in the correspond
Feature or Bug? Empty properties with multiplicities of n are created as attribute in the correspond [message #211125] Thu, 13 November 2008 07:16 Go to next message
Originally posted by: ralf.buschermoehle.informatik.uni-oldenburg.de
See <Topic> ... when an element is e.g. moved in the GMF editor, *unsed*
properties are stored in the corresponding domain model xml file as
attributes even if they have been modeled with upper multiplicities of
"-1" in the ecore. They should be stored as
<featureX>
<featureX/>
but they are stored as
<... featureX="">
Then the generated EMF editor says ...
"org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'FeatureX'
not found."
.... when I try to open the domain file.
It is totally correct stored inside tags when I *set* the values in the
GMF editor.
1.) Why are features stored at all when I did not set them?
1.a.) Can this be avoided (the storage) and how?
2.) If not (1.a.) can I tell GMF to store tags instead of attributes in
the domain model file?
Greetings,
Ralf
P.S. I tried GMF gmf 2.1.2 and 2.2.0M3 (with corresponding emf versions).
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211136 is a reply to message #211125] Thu, 13 November 2008 08:23 Go to previous messageGo to next message
Ralf,
Comments below.
Ralf Buschermoehle wrote:
> Hello,
> *unsed* properties are stored in the corresponding domain model xml
> file as attributes even if they have been modeled with upper
> multiplicities of "-1" in the ecore. They should be stored as
> <featureX>
> <featureX/>
> <... featureX="">
I'd expect this only if featureX is an unsettable feature. In that
case, the feature can be considered set even if the list is empty, and
what you show above is how this "set empty list" is represented in XMI.
It can't be represented at all in an XML (non-XMI) serialization.
> 'FeatureX' not found."
Are you using the same resource implementation with the same options in
each case?
> the GMF editor.
> in the domain model file?
Extended metadata annotations can be used to direct the serialization
style, but it should always be possible to read in what was written out
assuming the same configured implementations are used in each case.
> Greetings,
> Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211144 is a reply to message #211136] Thu, 13 November 2008 09:06 Go to previous messageGo to next message
Hi Ed,
thanks (as always) for the fast reply! Comments below.
Ed Merks wrote:
> Ralf,
> Comments below.
>> Hello,
>> <featureX>
>> <featureX/>
>> <... featureX="">
Hm, no ... featureX is defined in the ecore as
<eStructuralFeatures xsi:type="ecore:EAttribute" name="featureX"
unique="false"
upperBound="-1" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String"
defaultValueLiteral="">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
<details key="name" value="featureX"/>
</eAnnotations>
</eStructuralFeatures>
> In that
Yes, if I delete the attributes everything is fine (or set value(s)).
> each case?
Yes. If you are interested I can send you the model files (emf/gmf/example)?
>> the GMF editor.
I assumed/hoped - but then it's even stranger ... ? Hmm..
Greetings,
Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211150 is a reply to message #211144] Thu, 13 November 2008 09:27 Go to previous messageGo to next message
--------------010103020302010808080805
Ralf,
Comments below.
> Hi Ed,
> Ed Merks wrote:
>> Ralf,
>> Comments below.
>>> Hello,
>>> <featureX>
>>> <featureX/>
>>> <... featureX="">
> unique="false"
> <eAnnotations
> </eAnnotations>
It really looks to me like XMLSaveImpl.saveManyEmpty is being called.
Which happens for unsettable features. Oh and I see, it will happen for
things with a default value as well.
protected boolean shouldSaveFeature(EObject o, EStructuralFeature f)
return o.eIsSet(f) || keepDefaults && f.getDefaultValueLiteral()
!= null;
Probably this default value is kind of bogus?
>> In that case, the feature can be considered set even if the list is
>> empty, and what you show above is how this "set empty list" is
>> represented in XMI. It can't be represented at all in an XML
>> in each case?
> (emf/gmf/example)?
>>> the GMF editor.
>> out assuming the same configured implementations are used in each case.
Maybe you've just hit a case I've not seen before. Not sure how you
ended up with this model. Did it start as a schema? The default value
of "" seems odd for a repeating element...
> Greetings,
> Ralf
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Ralf,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gfhc9u$ert$1@build.eclipse.org" type="cite">Hi
Ed,
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Ralf,
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<blockquote type="cite">Hello,
<br>
<br>
See &lt;Topic&gt; ... when an element is e.g. moved in the GMF editor,
<br>
<br>
&lt;featureX&gt;
<br>
<br>
&lt;featureX/&gt;
<br>
<br>
<br>
<br>
&lt;... featureX=""&gt;
<br>
</blockquote>
I'd expect this only if featureX is an unsettable feature. </blockquote>
<br>
<br>
<br>
&lt;eStructuralFeatures xsi:type="ecore:EAttribute" name="featureX"
unique="false"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; upperBound="-1" eType="ecore:EDataType
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2003/XMLType#//String">http://www.eclipse.org/emf/2003/XMLType#//String</a>"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; defaultValueLiteral=""&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;eAnnotations
source=<a class="moz-txt-link-rfc2396E" href="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">"http:///org/eclipse/emf/ecore/util/ExtendedMetaData"</a>&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;details key="kind" value="element"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;details key="name" value="featureX"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/eAnnotations&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;/eStructuralFeatures&gt;
<br>
</blockquote>
It really looks to me like XMLSaveImpl.saveManyEmpty is being called.&nbsp;
Which happens for unsettable features.&nbsp; Oh and I see, it will happen
for things with a default value as well.<br>
<blockquote>&nbsp; protected boolean shouldSaveFeature(EObject o,
EStructuralFeature f)<br>
&nbsp; {<br>
&nbsp;&nbsp;&nbsp; return o.eIsSet(f) || keepDefaults &amp;&amp;
f.getDefaultValueLiteral() != null;<br>
&nbsp; }<br>
</blockquote>
Probably this default value is kind of bogus?<br>
<blockquote cite="mid:gfhc9u$ert$1@build.eclipse.org" type="cite"><br>
<blockquote type="cite">In that case, the feature can be considered
set even if the list is empty, and what you show above is how this "set
empty list" is represented in XMI.&nbsp; It can't be represented at all in
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite"><br>
<br>
<br>
not found."
<br>
<br>
<br>
</blockquote>
each case?
<br>
</blockquote>
<br>
(emf/gmf/example)?
<br>
<br>
<blockquote type="cite">It is totally correct stored inside tags
when I *set* the values in the GMF editor.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
I assumed/hoped&nbsp; - but then it's even stranger ... ? Hmm..
<br>
</blockquote>
Maybe you've just hit a case I've not seen before.&nbsp; Not sure how you
ended up with this model.&nbsp; Did it start as a schema? The default value
of "" seems odd for a repeating element...<br>
Greetings,
<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;Ralf
<br>
</blockquote>
</body>
</html>
--------------010103020302010808080805--
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211166 is a reply to message #211150] Thu, 13 November 2008 11:25 Go to previous messageGo to next message
Hi Ed,
Comments below.
Ed Merks wrote:
> Ralf,
> Comments below.
>> Hi Ed,
>> Ed Merks wrote:
>>> Ralf,
>>> Comments below.
>>>> Hello,
>>>> <featureX>
>>>> <featureX/>
>>>> <... featureX="">
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
> != null;
Sounds resonable ... I deleted default value in the ecore ...
unique="false"
<eAnnotations
<details key="name" value="FeatureX"/>
</eAnnotations>
But unfortunately the error persisted. Then I tried to remove the
EAnnotations because I did not use them in my ecore models (that work
fine). And viola the error is gone ... Unfortunately I cannot exactly
reproduce if it's only one detail/both/or all eAnnotations of the
elements. At least the last case works ...
Hm, I don't know (see later comments) why they use a featureX and write
it with an uppercase letter (FeatureX) in the XML file ... ? Well,...
>>> in each case?
>> (emf/gmf/example)?
>>>> the GMF editor.
Guess you're right - I use directly the ecore from the EPF project - and
IMHO I also found some schema files when I browsed through their project.
Greetings,
Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211174 is a reply to message #211166] Thu, 13 November 2008 11:45 Go to previous messageGo to next message
Ralf,
Comments below.
> Hi Ed,
> Comments below.
> Ed Merks wrote:
>> Ralf,
>> Comments below.
>>> Hi Ed,
>>> Ed Merks wrote:
>>>> Ralf,
>>>> Comments below.
>>>>> Hello,
>>>>> xml file as attributes even if they have been modeled with upper
>>>>> <featureX>
>>>>> <featureX/>
>>>>> <... featureX="">
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>> called. Which happens for unsettable features. Oh and I see, it
>> will happen for things with a default value as well.
>> != null;
> unique="false"
> <eAnnotations
> </eAnnotations>
Did you try setting a breakpoint in saveManyEmpty? Something is making
it get there...
> Then I tried to remove the EAnnotations because I did not use them in
> my ecore models (that work fine). And viola the error is gone ...
Because then it doesn't insist it must be an element such that an
attribute is invalid.
> Unfortunately I cannot exactly reproduce if it's only one
> detail/both/or all eAnnotations of the elements. At least the last
> case works ...
It would be good to understand why it's saving this way. You can see it
ought to do that only if the feature is considered set or you're keeping
defaults and their is a default...
> write it with an uppercase letter (FeatureX) in the XML file ... ?
> Well,...
>>>> options in each case?
>>> (emf/gmf/example)?
>>>>> in the GMF editor.
>>>>> attributes in the domain model file?
>>>> serialization style, but it should always be possible to read in
>>>> what was written out assuming the same configured implementations
>> value of "" seems odd for a repeating element...
> and IMHO I also found some schema files when I browsed through their
> project.
What did this schema look like? Maybe I'm doing something not so good
in the XSD to Ecore Mapping...
> Greetings,
> Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211270 is a reply to message #211174] Fri, 14 November 2008 07:44 Go to previous messageGo to next message
Hi Ed,
Comments below.
Ed Merks wrote:
> Ralf,
> Comments below.
>> Hi Ed,
>> Comments below.
>> Ed Merks wrote:
>>> Ralf,
>>> Comments below.
>>>> Hi Ed,
>>>> Ed Merks wrote:
>>>>> Ralf,
>>>>> Comments below.
>>>>>> Hello,
>>>>>> <featureX>
>>>>>> <featureX/>
>>>>>> <... featureX="">
>>>> unique="false"
>>>> <eAnnotations
>>>> </eAnnotations>
>>> != null;
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
> it get there...
Yes, and according to the implementation (and my understanding) this is
correct ... (meaning it should invoke saveManyEmpty)? The feature value
is set (because of the default value), so sIsSet(f) == true implying the
invocation.
>> case works ...
It seams that "toDOM" == false in ...
if (!toDOM)
saveManyEmpty(f);
else
helper.populateNameInfo(nameInfo, f);
Attr attr =
document.createAttributeNS(nameInfo.getNamespaceURI(),
nameInfo.getQualifiedName());
((Element)currentNode).setAttributeNodeNS(attr);
handler.recordValues(attr, o, f, null);
But why? toDOM is initially (XMLSaveImpl) set to true. Where set to false?
>> Well,...
>>>> (emf/gmf/example)?
>>>>>> in the GMF editor.
>> project.
You can find the files in the epf project sources.
cvs://dev.eclipse.org/cvsroot/technology/org.eclipse.epf/com poser/1.5/plugins/org.eclipse.xml.uma/src/model/UMA.ecore
cvs://dev.eclipse.org/cvsroot/technology/org.eclipse.epf/com poser/1.5/plugins/org.eclipse.xml.uma/src/model/UMA.xsd
Unfortunately a simple full text search "fulfilled" (which is
"featureX") in DescribableElement failed in the XSD file - but I have no
Idea if/how they used the schema file in the project.
Greetings,
Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211281 is a reply to message #211270] Fri, 14 November 2008 07:55 Go to previous messageGo to next message
Appendix added ...
> Hi Ed,
> Comments below.
> Ed Merks wrote:
>> Ralf,
>> Comments below.
>>> Hi Ed,
>>> Comments below.
>>> Ed Merks wrote:
>>>> Ralf,
>>>> Comments below.
>>>>> Hi Ed,
>>>>> Ed Merks wrote:
>>>>>> Ralf,
>>>>>> Comments below.
>>>>>>> Hello,
>>>>>>> <featureX>
>>>>>>> <featureX/>
>>>>>>> <... featureX="">
>>>>> unique="false"
>>>>> <eAnnotations
>>>>> </eAnnotations>
>>>> != null;
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>> making it get there...
> invocation.
>>> case works ...
>> it ought to do that only if the feature is considered set or you're
>> keeping defaults and their is a default...
> if (!toDOM)
> saveManyEmpty(f);
> else
> Attr attr = document.createAttributeNS(nameInfo.getNamespaceURI(),
Initially is not correct ... I found only one assignment for toDOM
public Document save(XMLResource resource, Document doc, Map<?, ?>
options, DOMHandler handler)
toDOM = true;
and thought this would be called - but it is not ... ?
>>> Well,...
>>>>>> is empty, and what you show above is how this "set empty list" is
>>>>> (emf/gmf/example)?
>>>>>>> in the GMF editor.
>>> project.
> Greetings,
> Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211288 is a reply to message #211281] Fri, 14 November 2008 08:52 Go to previous messageGo to next message
Ralf,
The toDOM thing is a red herring. That's just whether we're creating a
org.w3c.dom.Document instance (much slower) or using an XMLString (fast
and small)...
> Appendix added ...
>> Hi Ed,
>> Comments below.
>> Ed Merks wrote:
>>> Ralf,
>>> Comments below.
>>>> Hi Ed,
>>>> Comments below.
>>>> Ed Merks wrote:
>>>>> Ralf,
>>>>> Comments below.
>>>>>> Hi Ed,
>>>>>> Ed Merks wrote:
>>>>>>> Ralf,
>>>>>>> Comments below.
>>>>>>>> Hello,
>>>>>>>> editor, *unsed* properties are stored in the corresponding
>>>>>>>> domain model xml file as attributes even if they have been
>>>>>>>> modeled with upper multiplicities of "-1" in the ecore. They
>>>>>>>> should be stored as
>>>>>>>> <featureX>
>>>>>>>> <featureX/>
>>>>>>>> <... featureX="">
>>>>>> unique="false"
>>>>>> <eAnnotations
>>>>>> </eAnnotations>
>>>>> != null;
>>>> unique="false"
>>>> <eAnnotations
>>>> </eAnnotations>
>> is correct ... (meaning it should invoke saveManyEmpty)? The feature
>> value is set (because of the default value), so sIsSet(f) == true
>> implying the invocation.
>>>> in my ecore models (that work fine). And viola the error is gone ...
>>>> case works ...
>>> see it ought to do that only if the feature is considered set or
>>> you're keeping defaults and their is a default...
>> if (!toDOM)
>> saveManyEmpty(f);
>> else
>> Attr attr =
>> false?
> toDOM = true;
>>>> Well,...
>>>>>>> is represented in XMI. It can't be represented at all in an XML
>>>>>> value(s)).
>>>>>> (emf/gmf/example)?
>>>>> you ended up with this model. Did it start as a schema? The
>>>>> default value of "" seems odd for a repeating element...
>>>> - and IMHO I also found some schema files when I browsed through
>>>> their project.
>>> good in the XSD to Ecore Mapping...
>> no Idea if/how they used the schema file in the project.
>> Greetings,
>> Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211295 is a reply to message #211174] Fri, 14 November 2008 08:54 Go to previous messageGo to next message
Hi Ed,
if the defaultValue is empty, then shouldSaveFeature(o, f) calls
o.sIsSet(f) which is a CDO (1.0.3) Implementation (CDOObjectImpl)
public boolean eIsSet(EStructuralFeature feature)
if (FSMUtil.isTransient(this)) // == true
// TODO What about defaultValues != null?
if (eSettings == null) // == false
return false;
return eSettings[eDynamicFeatureID(feature)] != null; // returned
// Delegate to CDOStore
return super.eIsSet(feature);
eSettings[eDynamicFeatureID(feature)] is not "null". As far as I
understand the variable space of the debug run it should check if the
value (called data?) of the feature is set and not if there exists a
feature? Well, seems not to be EMF related.
Greetings,
Ralf
P.S. The "error" persists in CDO 2.0.v200811031537.
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211302 is a reply to message #211270] Fri, 14 November 2008 08:54 Go to previous messageGo to next message
Ralf,
Comments below.
> Hi Ed,
> Comments below.
> Ed Merks wrote:
>> Ralf,
>> Comments below.
>>> Hi Ed,
>>> Comments below.
>>> Ed Merks wrote:
>>>> Ralf,
>>>> Comments below.
>>>>> Hi Ed,
>>>>> Ed Merks wrote:
>>>>>> Ralf,
>>>>>> Comments below.
>>>>>>> Hello,
>>>>>>> <featureX>
>>>>>>> <featureX/>
>>>>>>> <... featureX="">
>>>>> unique="false"
>>>>> <eAnnotations
>>>>> </eAnnotations>
>>>> != null;
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
You said you got rid of the default value though. So what's making the
empty list be set?
>>> case works ...
> if (!toDOM)
> saveManyEmpty(f);
> else
> Attr attr =
> false?
>>> Well,...
>>>>> (emf/gmf/example)?
>>>>>>> in the GMF editor.
>>> project.
I might have time to look at it later, but I need to travel this weekend
so have lots to prepare...
> Greetings,
> Ralf
Re: Feature or Bug? Empty properties with multiplicities of n are created as attribute in the corres [message #211311 is a reply to message #211295] Fri, 14 November 2008 09:03 Go to previous message
Ralph,
That looks bad to me it probably should be delegating to this method.
protected boolean eDynamicIsSet(int dynamicFeatureID,
EStructuralFeature eFeature)
return
dynamicFeatureID < 0 ?
eOpenIsSet(eFeature) :
eSettingDelegate(eFeature).dynamicIsSet(this, eSettings(),
dynamicFeatureID);
Eike tells me this is fixed in 2.0...
> Hi Ed,
> @Override
> return false;
> Greetings,
> Ralf
Previous Topic:CreationWizard could not be started
Next Topic:button look'n feel like in rcp
Current Time: Sun Jul 27 11:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.06074 seconds
