CreationWizard could not be started [message #211205] |
Fri, 14 November 2008 04:34  |
Hi every body,
I want to start my editor but I recieve an error:
Probem opening wizard: The selected wizard coud not be started
Reason: Plug-In AOMEditor.diagram was unable to load class
AOMEditorCreationWizard.
What's the problem?
The .log file is below.
Thanks in advance.
Pev.
!ENTRY org.eclipse.osgi 4 0 2008-11-14 10:21:02.140
!MESSAGE An error occurred while automatically activating bundle
AOMEditor.diagram (1531).
!STACK 0
org.osgi.framework.BundleException: Exception in
AOMEditor.diagram.part.AOMEditorDiagramEditorPlugin.start() of bundle
AOMEditor.diagram.
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExtension(WorkbenchWizardElement.java:117)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(WorkbenchWizardElement.java:261)
at
org.eclipse.ui.internal.dialogs.NewWizardNewPage$5.createWiz ard(NewWizardNewPage.java:728)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNode.java:151)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNode.java:135)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizardNode.java:132)
at
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:104)
at
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:100)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:813)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:253)
at
org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
at
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.ExceptionInInitializerError
at AOMEditor.util.AOMEditorSwitch.<init>(AOMEditorSwitch.java:46)
at
AOMEditor.util.AOMEditorAdapterFactory$1.<init>(AOMEditorAdapterFactory.java:73)
at
AOMEditor.util.AOMEditorAdapterFactory.<init>(AOMEditorAdapterFactory.java:73)
at
AOMEditor.provider.AOMEditorItemProviderAdapterFactory.<init >(AOMEditorItemProviderAdapterFactory.java:70)
at
AOMEditor.diagram.part.AOMEditorDiagramEditorPlugin.fillItem ProviderFactories(AOMEditorDiagramEditorPlugin.java:102)
at
AOMEditor.diagram.part.AOMEditorDiagramEditorPlugin.createAd apterFactory(AOMEditorDiagramEditorPlugin.java:93)
at
AOMEditor.diagram.part.AOMEditorDiagramEditorPlugin.start(AO MEditorDiagramEditorPlugin.java:68)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
... 79 more
Caused by: org.eclipse.emf.common.util.WrappedException:
java.lang.ClassNotFoundException: Model.ModelPackage
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:260)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
at AOMEditor.impl.AOMEditorPackageImpl.init(AOMEditorPackageImp l.java:151)
at AOMEditor.AOMEditorPackage.<clinit>(AOMEditorPackage.java:61)
... 89 more
Caused by: java.lang.ClassNotFoundException: Model.ModelPackage
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
at
at
at
at
at
at
org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:253)
... 92 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 89 more
at
at
at
at
at
at
at
at
... 92 more
FUDForum. Page generated in 0.07148 seconds
