Home » Eclipse Projects » GEF » how to add widget to a composite after the composite is displayed ?
how to add widget to a composite after the composite is displayed ? [message #211108] Wed, 08 March 2006 04:11 Go to next message
Originally posted by: tmxk2008.gmail.com
if a composite is showed in runtime ,and I click a button to create a Text to be put in this composite .
but the added Text couldn't be show even I redraw the composite.
Could someone tell the cause.
Re: how to add widget to a composite after the composite is displayed ? [message #211196 is a reply to message #211108] Wed, 08 March 2006 16:46 Go to previous messageGo to next message
Originally posted by: kwpeck.mersoft.com
Seems like more of a SWT question to me but I will see if I can help.
In general you need to build your full layout then hide the widgets you
don't want to see. When they press the button you make widgets visible.
I don't believe, and I could be wrong, that you can add a widget to a
composite later. They all must be there from the start and you can show
and hide them as needed from there.
Re: how to add widget to a composite after the composite is displayed ? [message #211211 is a reply to message #211196] Wed, 08 March 2006 19:51 Go to previous messageGo to next message
you are right.
but i can't certain the how much the widgets to be put in Composite in Compile Time,just can be certained in running time.
Re: how to add widget to a composite after the composite is displayed ? [message #211791 is a reply to message #211211] Wed, 15 March 2006 17:05 Go to previous messageGo to next message
Originally posted by: micah.whitacre.cerner.com
heima2008 wrote:
> you are right.
If you call composite.layout(true), it should make the widget appear.
Re: how to add widget to a composite after the composite is displayed ? [message #211831 is a reply to message #211791] Wed, 15 March 2006 19:42 Go to previous message
Yes,you are right
I had found this methor yesterday.
it really works !
thanks!
Previous Topic:RTF Editor using GEF
Next Topic:Contacting rlemaigr
Current Time: Sat Jul 19 09:02:05 EDT 2025
Powered by FUDForum. Page generated in 0.04436 seconds
