Home » Modeling » GMF (Graphical Modeling Framework) » CVS examples
CVS examples [message #210945] Wed, 12 November 2008 04:41 Go to next message
Hi, is a week that I can't download from CVS all gmf examples, it is work?
or is only my problem? Thanks Matteo
Re: CVS examples [message #210960 is a reply to message #210945] Wed, 12 November 2008 05:54 Go to previous messageGo to next message
Hello Matteo,
I've just checked - pserver access to GMF CVS is working for me.
Try using following command: cvs -d :pserver:anonymous@dev.eclipse.org:/cvsroot/modeling
co org.eclipse.gmf/examples
Alex Shatalin
Re: CVS examples [message #210976 is a reply to message #210960] Wed, 12 November 2008 06:20 Go to previous messageGo to next message
Thanks a lot, but, i'm sorry, i don't know where put the command... i have
seen the procedure that is explained in GMF tutorial. Please help me, i
need taipan project! THANKS
Re: CVS examples [message #210983 is a reply to message #210976] Wed, 12 November 2008 06:43 Go to previous messageGo to next message
Hello Matteo,
Well, the way to get sources from CVs via eclipse CVS integration described
here (http://wiki.eclipse.org/index.php/GMF_Tutorial#Quick_Start) is working
as well.
Alex Shatalin
Re: CVS examples [message #210991 is a reply to message #210983] Wed, 12 November 2008 07:14 Go to previous messageGo to next message
Thanks but I already have followed this procedure... and the error is ever
the same:
An error occurred checking out
org.eclipse.gmf/examples/org.eclipse.gmf.examples.taipan: Problem writing
resource
'/org.eclipse.gmf.examples.taipan/src/org/eclipse/gmf/exampl es/taipan/impl/TaiPanFactoryImpl.java'.
Timeout while reading from input stream
Problem writing resource
Could not read from source when writing file
'D:\EclipseWwrks\org.eclipse.gmf.examples.taipan\src\org\ecl ipse\gmf\examples\taipan\impl\TaiPanFactoryImpl.java'
Please help or send me an email with taipan project to
m.battista@eaisoftware.it
THANKS
MAtteo
Re: CVS examples SOLVED [message #211023 is a reply to message #210945] Wed, 12 November 2008 09:43 Go to previous message
I've solved! It was just timeout connection setting too low, I have set it
to 6000 sec.
MAtteo
Previous Topic:How to change the parent of an edit part
Next Topic:Integrate snap to geometry into diagram/context menu - patch
Current Time: Fri Jul 18 10:16:04 EDT 2025
Powered by FUDForum. Page generated in 0.09287 seconds
