Home » Language IDEs » ServerTools (WTP) » Problem with the Export Data options from the BIRT - toolbar
Problem with the Export Data options from the BIRT - toolbar [message #210673] |
Thu, 20 March 2008 12:48  |
Originally posted by: seemakhopade.hsbc.co.in
I need help for the following issue as soon as possible, as our appl users
are facing lot many problems.
When I click on the 'Export Data' option from the BIRT-Web Viewer's
toolbar,
It displays some unwanted columns in 'Available Column' list.
Name of the unwanted columns are like.. Total_Column_5, Total_column_6...
Here is the XML Source of My report design:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build <2.2.0.v20070626-1003></property>
<property name="units">in</property>
<text-property name="title"></text-property>
<property name="comments">Copyright (c) 2007 <<Your Company Name
here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<list-property name="cssStyleSheets">
<structure>
<property name="fileName"></property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="ReportFilters" id="1582">
<property name="valueType">static</property>
<property name="dataType">string</property>
<text-property name="promptText">Select Report
Filter</text-property>
<property name="controlType">list-box</property>
<property name="mustMatch">true</property>
<property name="fixedOrder">false</property>
<property name="defaultValue">All Non Zeros</property>
<property name="distinct">false</property>
<property name="sortBy">label</property>
<property name="sortDirection">asc</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
<list-property name="selectionList">
<structure>
<property name="value">Exceptions Only</property>
<property name="label">Exceptions Only</property>
</structure>
<structure>
<property name="value">All Non Zeros</property>
<property name="label">All Records</property>
</structure>
</list-property>
</scalar-parameter>
<cascading-parameter-group name="AsAtDateCurrency" id="2082">
<property name="promptText">Select As At Date and then
Currency</property>
<property name="dataSetMode">multiple</property>
<parameters>
<scalar-parameter name="As At Date" id="2083">
<property name="valueType">dynamic</property>
<text-property name="promptText">Select As At
Date</text-property>
<property name="isRequired">true</property>
<property name="dataSetName">AsAtDate</property>
<expression
name="valueExpr">row["AS_AT_DATE"]</expression>
<expression
name="labelExpr">row["AS_AT_DATE"]</expression>
<property name="defaultValue"></property>
</structure>
</scalar-parameter>
<scalar-parameter name="Currency" id="2084">
Currency</text-property>
<property name="dataSetName">ccy Currency</property>
<expression
name="valueExpr">row["CURRENCY"]</expression>
<expression
name="labelExpr">row["CURRENCY"]</expression>
<property name="defaultValue">All</property>
</structure>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
<cascading-parameter-group name="BusinessAreaPLGrouping" id="250">
<property name="promptText">Select Business Area and PL
Grouping and then Cost Centre</property>
<parameters>
<scalar-parameter name="Business Area" id="251">
<text-property name="promptText">Select Business
Area</text-property>
<property name="dataSetName">business_area</property>
<expression
name="valueExpr">row["BUSINESS_AREA"]</expression>
<expression
name="labelExpr">row["BUSINESS_AREA"]</expression>
</structure>
</scalar-parameter>
<scalar-parameter name="Sophis Business" id="252">
<text-property name="promptText">Select PL
Grouping</text-property>
<property name="dataSetName">PL Grouping</property>
<expression
name="valueExpr">row["SOPHIS_BUSINESS"]</expression>
<expression
name="labelExpr">row["SOPHIS_BUSINESS"]</expression>
</structure>
</scalar-parameter>
<scalar-parameter name="Cost Center" id="1580">
<text-property name="promptText">Select Cost
Centre</text-property>
<property name="dataSetName">Cost Center</property>
<expression
name="valueExpr">row["COST_CENTRE"]</expression>
<expression
name="labelExpr">row["COST_CENTRE"]</expression>
</structure>
</scalar-parameter>
</parameters>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Rec" id="1576">
<property name="odaDriverClass"></property>
<property name="odaURL"></property>
<property name="odaUser"></property>
<encrypted-property name="odaPassword">/encrypted-property>
</oda-data-source>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="RecUAT"
id="2039">
<encrypted-property name="odaPassword"></encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="FO_BO_GL" id="1481">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">COST_CENTRE</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CCY</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">ACCOUNT</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">ACCOUNT_NAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">FO_MTM_SUM</property>
<property name="dataType">decimal</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">BO_MTM_SUM</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">GL_MTM_SUM</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">FOBO_MTM_DIFF</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">BOGL_MTM_DIFF</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">FOGL_MTM_DIFF</property>
</structure>
</list-property>
</structure>
<property name="dataSource">RecUAT</property>
<method name="beforeOpen"><![CDATA[this.queryText =
this.queryText + " where AS_AT_DATE = '"+params['As At Date']+"' ";
if(params['Currency'] != 'All'){
this.queryText = this.queryText + " and CCY = '"+params['Currency'] +
//user wanna see all the cost centers present in STATIC_BOOK_MAPPING
if(params['Cost Center'] == "All"){
" and COST_CENTRE in ( "+
" (select COST_CENTRE "+
" from STATIC_BOOK_MAPPING "+
" where BUSINESS_AREA = '"+params['Business Area'] + "' ";
//if user want to see cost center irrespective of pl grouping
//then do not include PL grouping in where clause else need to
//include pl grouping in where clause
if(params['Sophis Business'] != "All"){
this.queryText = this.queryText + " and SOPHIS_BUSINESS =
'"+params['Sophis Business'] + "' ";
this.queryText = this.queryText + " ) UNION (SELECT distinct TREATS_CC
as COST_CENTRE "+
" FROM STATIC_BOOK_MAPPING where business_area = '"+params['Business
Area'] + "' ";
this.queryText = this.queryText + " )) ";//end of in
} else {//user has selected only one cost code
this.queryText = this.queryText + " and COST_CENTRE = '"+params['Cost
Center'] + "' ";
if(params['ReportFilters'] == "Exceptions Only"){
//report fliter = exceptions only
" AND (round(FOBO_MTM_DIFF,2) != 0"+
" OR round(BOGL_MTM_DIFF,2) != 0"+
" OR round(FOGL_MTM_DIFF,2) != 0 )";
} else if(params['ReportFilters'] == "All Non Zeros"){
//all records = all non zeros change on 19Mar2008
//report fliter = All Non Zeros
" AND (round(FO_MTM_SUM,2) != 0"+
" OR round(BO_MTM_SUM,2) != 0"+
" OR round(GL_MTM_SUM,2) != 0 )";
}]]></method>
<structure>
<property name="nativeName">COST_CENTRE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CCY</property>
</structure>
<structure>
<property name="nativeName">ACCOUNT</property>
</structure>
<structure>
<property name="nativeName">ACCOUNT_NAME</property>
</structure>
<structure>
<property name="nativeName">FO_MTM_SUM</property>
<property name="nativeDataType">2</property>
</structure>
<structure>
<property name="nativeName">BO_MTM_SUM</property>
</structure>
<structure>
<property name="nativeName">GL_MTM_SUM</property>
</structure>
<structure>
<property name="nativeName">FOBO_MTM_DIFF</property>
</structure>
<structure>
<property name="nativeName">BOGL_MTM_DIFF</property>
</structure>
<structure>
<property name="nativeName">FOGL_MTM_DIFF</property>
</structure>
</list-property>
<property name="queryText">select
COST_CENTRE,
CCY,
ACCOUNT,
ACCOUNT_NAME,
round(FO_MTM_SUM,2) FO_MTM_SUM,
round(BO_MTM_SUM,2) BO_MTM_SUM,
round(GL_MTM_SUM,2) GL_MTM_SUM,
round(FOBO_MTM_DIFF,2) FOBO_MTM_DIFF,
round(BOGL_MTM_DIFF,2) BOGL_MTM_DIFF,
round(FOGL_MTM_DIFF,2) FOGL_MTM_DIFF
from REC_FO_BO_GL </property>
</oda-data-set>
<oda-data-set
name="business_area" id="237">
<structure>
<property name="name">BUSINESS_AREA</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Rec</property>
<structure>
<property name="nativeName">BUSINESS_AREA</property>
</structure>
</list-property>
<property name="queryText">select distinct
PLR.STATIC_BOOK_MAPPING.BUSINESS_AREA
from PLR.STATIC_BOOK_MAPPING
order by PLR.STATIC_BOOK_MAPPING.BUSINESS_AREA</property>
</oda-data-set>
<oda-data-set
name="PL Grouping" id="243">
<structure>
<property name="name">SOPHIS_BUSINESS</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[if(params['Business Area']
this.queryText = this.queryText + " where BUSINESS_AREA =
this.queryText = this.queryText + " order by SOPHIS_BUSINESS";]]></method>
<structure>
<property name="nativeName">SOPHIS_BUSINESS</property>
</structure>
</list-property>
SOPHIS_BUSINESS
from STATIC_BOOK_MAPPING</property>
</oda-data-set>
<oda-data-set
name="Cost Center" id="254">
<structure>
</structure>
</list-property>
</structure>
//cost centres are retrieved from the table static_book_mapping
//and its depends on the busines area and pl grouping selected
//business area is a mandatory whereas use may select all from the pl
grouping
//in that case we need to ignore pl grouping in where clause
this.queryText = this.queryText + " union SELECT distinct TREATS_CC as
COST_CENTRE "+
"FROM STATIC_BOOK_MAPPING ";
if(params['Business Area'] != ""){
grouping
//this.queryText = this.queryText + " order by COST_CENTRE";]]></method>
<structure>
</structure>
</list-property>
<property name="queryText">select distinct COST_CENTRE
from
STATIC_BOOK_MAPPING
</property>
</oda-data-set>
<oda-data-set
name="AsAtDate" id="1641">
<structure>
<property name="name">AS_AT_DATE</property>
</structure>
<structure>
<property name="name">AS_AT_DATE1</property>
<property name="dataType">date-time</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">AS_AT_DATE</property>
</structure>
<structure>
<property name="nativeName">AS_AT_DATE1</property>
<property name="nativeDataType">93</property>
</structure>
</list-property>
(TO_CHAR(as_at_date , 'dd MON yyyy') )
as_at_date, as_at_date as_at_date1
from REC_FO_BO_GL
order by as_at_date1 desc</property>
</oda-data-set>
<oda-data-set
name="ccy Currency" id="2041">
<structure>
<property name="name">CURRENCY</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[if(params['As At Date'] !=
this.queryText = this.queryText + " where AS_AT_DATE = '"+params['As At
Date'] + "' ";
this.queryText = this.queryText + " order by CCY";]]></method>
<structure>
<property name="nativeName">CURRENCY</property>
</structure>
</list-property>
<property name="queryText">select distinct( CCY) as currency
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="type">custom</property>
<property name="height">20cm</property>
<property name="width">40cm</property>
<page-footer>
<text id="3">
<property name="fontSize">8pt</property>
<property name="textAlign">left</property>
<property name="contentType">html</property>
<text-property name="content"><![CDATA[Print Date :
<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="1003">
<property name="style">REPORT-TITLE</property>
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
<property name="fontWeight">bold</property>
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">thin</property>
<property name="marginTop">0pt</property>
<property name="marginBottom">10pt</property>
<property name="textIndent">0em</property>
<property name="verticalAlign">top</property>
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[FO-BO-GL Reconciliation
Market Value Report]]></text-property>
</text>
<table id="974">
<property name="backgroundColor">#FFFFFF</property>
<property name="marginTop">10pt</property>
<property name="marginLeft">0pt</property>
<property name="marginBottom">0pt</property>
<property name="marginRight">0pt</property>
<property name="paddingTop">0pt</property>
<property name="paddingLeft">0pt</property>
<property name="paddingBottom">0pt</property>
<property name="paddingRight">0pt</property>
<property name="textAlign">center</property>
<property name="showIfBlank">true</property>
<property name="canShrink">true</property>
<property name="width">65%</property>
<column id="1063">
<property name="width">1.2395833333in</property>
<property name="color">#008080</property>
<property name="paddingLeft">2pt</property>
</column>
<column id="1064">
<property name="width">1.448in</property>
<property name="style">DATA-ROW1</property>
<property name="paddingLeft">2px</property>
</column>
<column id="1065">
<property name="width">0.5%</property>
</column>
<column id="1066">
<property name="width">1.24in</property>
</column>
<column id="1067">
</column>
<detail>
<row id="975">
<cell id="976">
<property name="style">DARK-BACKGROUND</property>
<label id="1354">
<property
<property name="color">#000000</property>
<text-property name="text">As At Date
:</text-property>
</label>
</cell>
<cell id="978">
<data id="1501">
<list-property name="boundDataColumns">
<structure>
<property name="name">As At
Date</property>
<expression
name="expression">params["As At Date"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">As At
Date</property>
</data>
</cell>
<cell id="1053"/>
<cell id="1054">
<label id="1055">
<property
<text-property name="text">Business Area
:</text-property>
</label>
</cell>
<cell id="1056">
<data id="1484">
<structure>
<property name="name">Business
Area</property>
<expression
name="expression">params["Business Area"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">Business
Area</property>
</data>
</cell>
</row>
<row id="1057">
<cell id="1058">
</cell>
<cell id="1059">
</cell>
<cell id="1060">
</cell>
<cell id="1061">
</cell>
<cell id="1062">
</cell>
</row>
<row id="1039">
<property name="style">LIGHT-BACKGROUND</property>
<cell id="1040">
<label id="1045">
<property
<text-property name="text">PL Grouping
:</text-property>
</label>
</cell>
<cell id="1041">
<data id="1618">
<structure>
<property name="name">Sophis
Business</property>
<expression
name="expression">params["Sophis Business"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">Sophis
Business</property>
</data>
</cell>
<cell id="1042"/>
<cell id="1043">
<label id="1046">
<property
<text-property name="text">Cost centre
:</text-property>
</label>
</cell>
<cell id="1044">
<data id="1581">
<structure>
<property name="name">Cost
Center</property>
<expression
name="expression">params["Cost Center"]</expression>
</structure>
</list-property>
<property name="resultSetColumn">Cost
Center</property>
</data>
</cell>
</row>
<row id="1619">
<cell id="1620"/>
<cell id="1621"/>
<cell id="1622"/>
<cell id="1623"/>
<cell id="1624"/>
</row>
<row id="1625">
<cell id="1626">
<label id="1588">
<property
<text-property name="text">Report Filter
:</text-property>
</label>
</cell>
<cell id="1627">
<data id="1617">
<structure>
<property
name="name">ReportFilters</property>
<expression
name="expression">if(params["ReportFilters"]=='All Non Zeros'){
'All Records'
} else {
}</expression>
<property
name="dataType">any</property>
</structure>
</list-property>
<property
name="resultSetColumn">ReportFilters</property>
</data>
</cell>
<cell id="1628"/>
<cell id="1629">
<label id="2059">
<text-property name="text">Currency
:</text-property>
</label>
</cell>
<cell id="1630">
<data id="2072">
<structure>
<property
name="name">Currency</property>
<expression
name="expression">params["Currency"]</expression>
</structure>
</list-property>
<property
name="resultSetColumn">Currency</property>
</data>
</cell>
</row>
</detail>
</table>
<table id="1359">
<property name="borderBottomColor">#F7F7F7</property>
<property name="borderLeftColor">#F7F7F7</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#F7F7F7</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#F7F7F7</property>
<property name="borderTopWidth">thin</property>
<property name="marginTop">20pt</property>
<property name="height">1.2604166667in</property>
<property name="width">95%</property>
<property name="dataSet">FO_BO_GL</property>
<structure>
<expression
name="expression">if(dataSetRow["COST_CENTRE"] == ' ' ||
dataSetRow["COST_CENTRE"] == null){
'No Cost Centre';
} else {
dataSetRow["COST_CENTRE"] ;
}</expression>
</structure>
<structure>
<expression name="expression">if(dataSetRow["CCY"] ==
' ' || dataSetRow["CCY"] == null){
'No Currency';
} else {
dataSetRow["CCY"]
}</expression>
</structure>
<structure>
<expression name="expression">if(dataSetRow["ACCOUNT"]
== ' ' || dataSetRow["ACCOUNT"] == null){
'No Account';
} else {
dataSetRow["ACCOUNT"] ;
}</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["FO_MTM_SUM"]</expression>
<property name="dataType">float</property>
</structure>
<structure>
<expression
name="expression">dataSetRow["BO_MTM_SUM"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["GL_MTM_SUM"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["FOBO_MTM_DIFF"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["BOGL_MTM_DIFF"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["FOGL_MTM_DIFF"]</expression >
</structure>
<structure>
<property name="name">Aggregation</property>
<expression
<property name="dataType">any</property>
<simple-property-list name="aggregateOn">
<value>CCY</value>
</simple-property-list>
<property name="aggregateFunction">sum</property>
</structure>
<structure>
<property name="name">Aggregation_1</property>
<expression
<value>CCY</value>
</structure
Re: Problem with the Export Data options from the BIRT - toolbar [message #210692 is a reply to message #210673] |
Thu, 20 March 2008 13:34   |
Seema, I think this is best asked in the BIRT newsgroup.
Seema wrote:
> Hello,
> users are facing lot many problems.
> toolbar,
> id="1">
> Name here>></property>
> <structure>
> </structure>
> </list-property>
> <parameters>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </scalar-parameter>
> Currency</property>
> <parameters>
> <expression
> <expression
> </structure>
> </scalar-parameter>
> <expression
> <expression
> </structure>
> </scalar-parameter>
> </parameters>
> <parameters>
> <expression
> <expression
> </structure>
> </scalar-parameter>
> <expression
> <expression
> </structure>
> </scalar-parameter>
> <expression
> <expression
> </structure>
> </scalar-parameter>
> </parameters>
> </parameters>
> <data-sources>
> <oda-data-source
> </oda-data-source>
> <oda-data-source
> id="2039">
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> '"+params['Currency'] + "' ";
> in ( "+
> TREATS_CC as COST_CENTRE "+
> '"+params['Cost Center'] + "' ";
> this.queryText = this.queryText + " AND
> //report fliter = All Non Zeros this.queryText =
> this.queryText + " AND (round(FO_MTM_SUM,2) != 0"+
> }]]></method>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property name="queryText">select COST_CENTRE,
> CCY,
> ACCOUNT,
> ACCOUNT_NAME,
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property name="queryText">select distinct SOPHIS_BUSINESS
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> grouping
> COST_CENTRE "+
> grouping
> <structure>
> </structure>
> </list-property>
> <property name="queryText">select distinct COST_CENTRE from
> STATIC_BOOK_MAPPING
> </property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from REC_FO_BO_GL
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> </list-property>
> </structure>
> At Date'] + "' ";
> <structure>
> </structure>
> </list-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <text id="1003">
> Reconciliation Market Value Report]]></text-property>
> </text>
> <table id="974">
> <column id="1063">
> </column>
> <column id="1064">
> </column>
> <column id="1065">
> </column>
> <column id="1066">
> </column>
> <column id="1067">
> </column>
> <detail>
> <row id="975">
> <cell id="976">
> <label id="1354">
> <property
> :</text-property>
> </label>
> </cell>
> <cell id="978">
> <data id="1501">
> <structure>
> Date</property>
> <expression
> </structure>
> </list-property>
> Date</property>
> </data>
> </cell>
> <cell id="1053"/>
> <cell id="1054">
> <label id="1055">
> <property
> :</text-property>
> </label>
> </cell>
> <cell id="1056">
> <data id="1484">
> <structure>
> Area</property>
> <expression
> </structure>
> </list-property>
> Area</property>
> </data>
> </cell>
> </row>
> <row id="1057">
> <cell id="1058">
> </cell>
> <cell id="1059">
> </cell>
> <cell id="1060">
> </cell>
> <cell id="1061">
> </cell>
> <cell id="1062">
> </cell>
> </row>
> <row id="1039">
> <cell id="1040">
> <label id="1045">
> <property
> :</text-property>
> </label>
> </cell>
> <cell id="1041">
> <data id="1618">
> <structure>
> Business</property>
> <expression
> </structure>
> </list-property>
> Business</property>
> </data>
> </cell>
> <cell id="1042"/>
> <cell id="1043">
> <label id="1046">
> <property
> :</text-property>
> </label>
> </cell>
> <cell id="1044">
> <data id="1581">
> <structure>
> Center</property>
> <expression
> </structure>
> </list-property>
> Center</property>
> </data>
> </cell>
> </row>
> <row id="1619">
> <cell id="1620"/>
> <cell id="1621"/>
> <cell id="1622"/>
> <cell id="1623"/>
> <cell id="1624"/>
> </row>
> <row id="1625">
> <cell id="1626">
> <label id="1588">
> <property
> :</text-property>
> </label>
> </cell>
> <cell id="1627">
> <data id="1617">
> <structure>
> <property
> <expression
> 'All Records'
> } else {
> }</expression>
> </structure>
> </list-property>
> <property
> </data>
> </cell>
> <cell id="1628"/>
> <cell id="1629">
> <label id="2059">
> :</text-property>
> </label>
> </cell>
> <cell id="1630">
> <data id="2072">
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <property
> </data>
> </cell>
> </row>
> </detail>
> </table>
> <table id="1359">
> <structure>
> <expression
> 'No Cost Centre';
> } else {
> }</expression>
> </structure>
> <structure>
> 'No Currency';
> } else {
> dataSetRow["CCY"] }</expression>
> </structure>
> <structure>
> <expression
> name="expression">if(dataSetRow["ACCOUNT"] =
Re: Problem with the Export Data options from the BIRT - toolbar [message #210790 is a reply to message #210692] |
Mon, 24 March 2008 12:17   |
Originally posted by: jasonweathersby.alltel.net
The columns shown in the export list are all the columns listed under
the binding tab. If the columns are not used, remove them from the
binding and they will not show up in the export.
Jason
> Seema wrote:
>> Hello,
>> toolbar,
>> <?xml version="1.0" encoding="UTF-8"?>
>> version="3.2.14" id="1">
>> <structure>
>> </structure>
>> </list-property>
>> <parameters>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </scalar-parameter>
>> Currency</property>
>> <parameters>
>> <expression
>> <expression
>> </structure>
>> </scalar-parameter>
>> <expression
>> <expression
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> <parameters>
>> <expression
>> <expression
>> </structure>
>> </scalar-parameter>
>> <expression
>> <expression
>> </structure>
>> </scalar-parameter>
>> <expression
>> <expression
>> </structure>
>> </scalar-parameter>
>> </parameters>
>> </parameters>
>> <data-sources>
>> <oda-data-source
>> </oda-data-source>
>> <oda-data-source
>> id="2039">
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> STATIC_BOOK_MAPPING if(params['Cost Center'] == "All"){
>> COST_CENTRE in ( "+
>> distinct TREATS_CC as COST_CENTRE "+
>> of in
>> }]]></method>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> CCY,
>> ACCOUNT,
>> ACCOUNT_NAME,
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> Area'] != ""){
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> Area'] != ""){
>> grouping
>> COST_CENTRE "+
>> grouping
>> <structure>
>> </structure>
>> </list-property>
>> STATIC_BOOK_MAPPING
>> </property>
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> from REC_FO_BO_GL
>> </oda-data-set>
>> <oda-data-set
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> '"+params['As At Date'] + "' ";
>> <structure>
>> </structure>
>> </list-property>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <text id="1003">
>> </text>
>> <table id="974">
>> <column id="1063">
>> </column>
>> <column id="1064">
>> </column>
>> <column id="1065">
>> </column>
>> <column id="1066">
>> </column>
>> <column id="1067">
>> </column>
>> <detail>
>> <row id="975">
>> <cell id="976">
>> <label id="1354">
>> <property
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="978">
>> <data id="1501">
>> <structure>
>> Date</property>
>> <expression
>> </structure>
>> </list-property>
>> Date</property>
>> </data>
>> </cell>
>> <cell id="1053"/>
>> <cell id="1054">
>> <label id="1055">
>> <property
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="1056">
>> <data id="1484">
>> <structure>
>> Area</property>
>> <expression
>> </structure>
>> </list-property>
>> Area</property>
>> </data>
>> </cell>
>> </row>
>> <row id="1057">
>> <cell id="1058">
>> <property
>> </cell>
>> <cell id="1059">
>> <property
>> </cell>
>> <cell id="1060">
>> <property
>> </cell>
>> <cell id="1061">
>> <property
>> </cell>
>> <cell id="1062">
>> <property
>> </cell>
>> </row>
>> <row id="1039">
>> <cell id="1040">
>> <label id="1045">
>> <property
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="1041">
>> <data id="1618">
>> <structure>
>> Business</property>
>> <expression
>> </structure>
>> </list-property>
>> Business</property>
>> </data>
>> </cell>
>> <cell id="1042"/>
>> <cell id="1043">
>> <label id="1046">
>> <property
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="1044">
>> <data id="1581">
>> <structure>
>> Center</property>
>> <expression
>> </structure>
>> </list-property>
>> Center</property>
>> </data>
>> </cell>
>> </row>
>> <row id="1619">
>> <cell id="1620"/>
>> <cell id="1621"/>
>> <cell id="1622"/>
>> <cell id="1623"/>
>> <cell id="1624"/>
>> </row>
>> <row id="1625">
>> <cell id="1626">
>> <label id="1588">
>> <property
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="1627">
>> <data id="1617">
>> <structure>
>> <property
>> <expression
>> 'All Records'
>> } else {
>> }</expression>
>> <property
>> </structure>
>> </list-property>
>> <property
>> </data>
>> </cell>
>> <cell id="1628"/>
>> <cell id="1629">
>> <label id="2059">
>> :</text-property>
>> </label>
>> </cell>
>> <cell id="1630">
>> <data id="2072">
>> <structure>
>> <property
>> name=&qu
Current Time: Fri Jul 25 11:13:41 EDT 2025
Powered by FUDForum. Page generated in 0.07523 seconds
