Home » Eclipse Projects » Eclipse Platform » is eclipse 2.1.2 compatible with java 1.5.0 beta?
is eclipse 2.1.2 compatible with java 1.5.0 beta? [message #210752] Fri, 12 March 2004 19:08 Go to next message
Originally posted by: eclipse.smith70.plus.com
I am trying out the new Java beta 1.5.0 with eclipse 2.1.2 and I am
getting some unexpected errors against some lines of code see end of
posting for sample code. This code compiles ok against Java 1.4.2
public class StringBufferSample
public static void test1()
StringBuffer sb = new StringBuffer();
sb.append('c');
// unhandled exception type IOException
public static void test2()
StringBuffer sb1 = new StringBuffer();
sb1.append("c").append("c");
// type AbstractStringBuilder is not visible
StringBuffer sb2 = new StringBuffer().append('c');
// Type mismatch: cannot convert from Appendable to StringBuffer
StringBuffer sb3 = new StringBuffer().append("c");
// Type mismatch: cannot convert from AbstractStringBuilder to
StringBuffer
Re: is eclipse 2.1.2 compatible with java 1.5.0 beta? [message #210825 is a reply to message #210752] Sat, 13 March 2004 05:07 Go to previous messageGo to next message
no.
they are working on this in the 3.0 stream.
johan
> sb.append('c');
> StringBuffer
Re: is eclipse 2.1.2 compatible with java 1.5.0 beta? [message #210895 is a reply to message #210752] Sat, 13 March 2004 09:51 Go to previous message
"David Smith" <eclipse@smith70.plus.com> schrieb im Newsbeitrag
news:c2tjdo$gm9$1@eclipse.org...
this is patched in the last integration build but it has some other flaws.
So currently, it's a waste of time to try it. Wait for M8.
Marc
Previous Topic:How can I programmatically get version of my plugin?
Next Topic:Illegal attempt to change read-only plug-in manifest model
Current Time: Sun Nov 02 23:06:40 EST 2025
Powered by FUDForum. Page generated in 0.03384 seconds
