IDE hang: "Copying resources to the output folder" [message #210657] |
Fri, 22 July 2005 12:53  |
Originally posted by: ken.williams.thomson.com
My Eclipse installation has unfortunately become unusable. When I start
it up, it starts trying to clean & compile my java project, and then
consumes all the CPU resources on my machine. When I look at the progress
monitor, I see that it is "Copying resources to the output folder". If I
leave it alone, it will stay this way for several hours or overnight,
until I kill the process.
I can close the main Eclipse application, but it doesn't fully exit,
giving me a "Progress Information" window saying that it's waiting for
"Building workspace" and "Copying resources to the output folder". That
will wait around indefinitely until I kill it.
There's at least one other person in my office with the same problem.
I could use some help figuring out the problem and restoring things back
to working order. Unfortunately I'm behind a firewall and can't read the
newsgroups through NNTP, nor can I find a searchable archive of this list
(does one exist?), so if this issue is already discussed somewhere, or if
there's a standard litany of things to try, I'd be happy to be pointed to
a URL.
My setup:
Eclipse 3.1.0 on Windows XP
P4Eclipse 0.2.24 plugin installed
Not using CVS at all
-Ken
Re: IDE hang: "Copying resources to the output folder" [message #210813 is a reply to message #210657] |
Mon, 25 July 2005 15:37  |
Originally posted by: eclipse3.rizzoweb.com
Ken Williams wrote:
> progress monitor, I see that it is "Copying resources to the output
> folder". If I leave it alone, it will stay this way for several hours
> or overnight, until I kill the process.
It is possible that there is one particular file in your source tree
that, for some reason I would have no idea about, is corrupted or
somehow giving Eclipse fits. Can you try temporarily removing all
non-Java files from your source directory(ies) and see if that makes it
go away. If so, try adding the files back one at a time until you find
which one is causing the problem.
IF that leads you to a "bad" file, please enter a bug and include the
content of that file and your config details: http://bugs.eclipse.org/bugs
> the newsgroups through NNTP, nor can I find a searchable archive of this
> list (does one exist?), so if this issue is already discussed somewhere,
> or if there's a standard litany of things to try, I'd be happy to be
> pointed to a URL.
Google (not Google Groups) indexes the archives of these groups. Also,
Eclipse.org hosts a somewhat limited search feature; go to
www.eclipse.org and click the Search link in the left gutter.
HTH,
Eric
FUDForum. Page generated in 0.03665 seconds
