Home » Language IDEs » Java Development Tools (JDT) » The selected stack frame must be associated with a Java project in the workspace
The selected stack frame must be associated with a Java project in the workspace [message #210094] |
Tue, 19 July 2005 06:52  |
Originally posted by: hemalpandya.gmail.com
I am still quite new to Eclipse so my apologies in advance if this is a
dumb quesion or the wrong newsgroup.
I am quite confused by the above message that I sometimes get when I
display/inspect some expression. A variable whose value is displayed in
the Variables window and also displayed in tool-tip on mouse hover cannot
be displayed in the Display/Inspect/Watch windows.
I am using Eclipse 3.0.1. This is a project that has been built using ant
and deployed in tomcat that I am remote-debugging.
I will appreciate if someone can point out what I am doing wrong and how I
can fix it.
hemal
Re: The selected stack frame must be associated with a Java project in the workspace [message #210237 is a reply to message #210145] |
Wed, 20 July 2005 00:08   |
Thanks you Darin. While this explains why the error would occur usually, I
do not think it applies in this case. The first few frames in stack are as
follows:
Thread [HttpProcessor[4040][4]] (Suspended (breakpoint at line 4182 in
XXWindowsApp))
XXWindowsApp.CreateAppData(XXDataAccess, XXRequest, XXResponse,
XXDataSource, int) line: 4182
XXWindowsApp.access$1400(XXWindowsApp, XXDataAccess, XXRequest, XXResponse,
XXDataSource, int) line: 124
XXWindowsApp$39.Execute(XXDataAccess, XXRequest, XXResponse, XXDataSource,
Map) line: 901
XXWindowsApp(XXApplication).HandleRequest(XXDataAccess, XXRequest,
XXResponse, XXDataSource, Map) line: 490
Among these, I am able to use the display window in HandleRequest but not in
CreateAppData, both of which belong to the same class. CreateAppData has
been called by a generated method access$1400, which in turn has been called
by Execute method of the anonymous class WindowsApp$39. Is it possible one
of these is confusing Eclipse?
It is very important that I be able to remote-debug this in eclipse. The
ant-build is not a very clean process. I am hoping I will be able to find
the solution in this forum. Thanks in advance for help.
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:dbivoj$l2v$1@news.eclipse.org...
> To perform an evaluation in the debugger, the expression must be compiled.
> To compile the expression, the Java debugger attempts to resolve a Java
> project associated with the stack frame of the selected variable. It is
> possible you have set up a remote debug session with source 'external' to
> the workspace (i.e. not contained in Java projects with build paths). In
> this case, the expression cannot be compiled in order to be evaluated.
> Darin
> "Hemal Pandya" <hemalpandya@gmail.com> wrote in message
> news:86759a8f43aee057ede37a85c1205e0e$1@www.eclipse.org...
>> I can fix it.
>> hemal
Re: The selected stack frame must be associated with a Java project in the workspace [message #210290 is a reply to message #210237] |
Wed, 20 July 2005 09:08   |
This does sound suspicious - i.e. being able to evaluate in one frame, but
not another from the same declaring type. Filing a bug would be helpful, if
you had a test case you could provide to reproduce the problem.
Darin
news:dbkinf$djq$1@news.eclipse.org...
> follows:
> XXWindowsApp))
> XXResponse, XXDataSource, int) line: 124
> Map) line: 901
> in CreateAppData, both of which belong to the same class. CreateAppData
> has been called by a generated method access$1400, which in turn has been
> called by Execute method of the anonymous class WindowsApp$39. Is it
> possible one of these is confusing Eclipse?
>> compiled. To compile the expression, the Java debugger attempts to
>> resolve a Java project associated with the stack frame of the selected
>> variable. It is possible you have set up a remote debug session with
>> source 'external' to the workspace (i.e. not contained in Java projects
>> with build paths). In this case, the expression cannot be compiled in
>> Darin
>>> cannot be displayed in the Display/Inspect/Watch windows.
>>> ant and deployed in tomcat that I am remote-debugging.
>>> I can fix it.
>>> hemal
Re: The selected stack frame must be associated with a Java project in the works [message #210446 is a reply to message #210290] |
Thu, 21 July 2005 04:02  |
A simple test does not reproduce the problem. This is a large code-base
that I am just starting to work with. Producing a test case on its basis
is not going to be easy, but I will try.
Meanwhile, is there is any information I can produce on my install that
will help identify the problem?
Thanks.
> Darin
>> follows:
>> XXWindowsApp))
>> Map) line: 901
>>> Darin
>>>> I can fix it.
>>>> hemal
Current Time: Sun Jun 08 19:16:18 EDT 2025
Powered by FUDForum. Page generated in 0.03201 seconds
