PermGen space [message #209991] |
Sat, 08 March 2008 07:09  |
Originally posted by: salamlinux.free.fr
I had eclipse packaged with my FC8 which I deleted it because of some
update issues regarding RCP patch and I as recommended to have a fresh new
install.
I downloaded the latest version of eclipse, done all necessary updates
through update manager DTP, webtools, gem, EMF.....and managed to run
servlet and jsp pages developed in the old version.
Whenever I try to rerun an example for a 2nd time, I get eclipse hanged
with error messages mainly the following :
Exception in thread "Thread-16" java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
Exception in thread "RMI RenewClean-[192.168.1.11:51243]"
Error while logging event loop exception:
I did some googling and discovered that it is something related to
garabage collecting but didn't find any article on a remedy.
I am not doing complex things, just trying to follow a small tutorial for
doing one servlet, one wsdl nothing big deal.
My question, is there any fix or patch for this problem? what is annoying
me is that during doing an operation for example transforming a class into
web service, eclipse get stuck on a dialog page called "web service java
bean identity", clicking on "next" continues to genertae variuos errors,
clicking on cancel it doesnt close anything, I should kill eclipse from
within a terminal session.
Thanks for your help
Re: PermGen space [message #210002 is a reply to message #209991] |
Sat, 08 March 2008 07:40   |
--------------080008030505020003030005
This permgen issues has come up hundreds of times on various
newsgroups. Just google for "eclipse permgen space error" and you'll
find plenty of help. Here's one:
http://alblue.blogspot.com/2007/10/headless-eclipse-on-linux -and.html
To summarize, you'll need a larger, e.g., |-XX:MaxPermSize=256m|, which
you can specify in the eclipse.ini or directly on the command line when
you run.
> new install.
> hanged with error messages mainly the following :
> for doing one servlet, one wsdl nothing big deal.
> annoying me is that during doing an operation for example transforming
> a class into web service, eclipse get stuck on a dialog page called
> "web service java bean identity", clicking on "next" continues to
> genertae variuos errors, clicking on cancel it doesnt close anything,
> I should kill eclipse from within a terminal session.
<html>
<head>
http-equiv="Content-Type">
</head>
newsgroups.
Re: PermGen space [message #210017 is a reply to message #210009] |
Sat, 08 March 2008 19:22   |
eliassal wrote:
> So many thanks for this hint, once I added the key in the ini file, I
> managed to go through in eclipse wizard.
> However, now I can run/debug jsp pages but whenever I call or try to
> debug a servlet, I get the following error
> HTTP Status 404 - /web1/HelloServlet
> type Status report
> message /web1/HelloServlet
> description The requested resource (/web1/HelloServlet) is not available.
> Apache Tomcat/5.5.26
> HelloServlet is there in my source folder, no errors declared and can
> not understand wht resource is not available.
> As I said, I am new to eclipse and java at the same time and following
> the iterations in the quick start in a book I purchased called "Eclipse
> Web tools platform by Naci Dai and his collegues.
> In the book nothing is mentioned about troubleshooting or possible
> errros and how to fix them
> Thanks again
Also note that there are bugs in this book's examples and places on the
web where you can get fixes for them. I wish I remembered where those
were as I've ordered this book too. I figured I'd find them again when I
needed them.
Note on your problem that there are solutions in the server.xml file
(look near the bottom of this file--it's under Server in the Project
Explorer). Also, as you begin to work with obfuscating paths that bear
no resemblance to the actual deployment because you've specified
otherwise in your web.xml (deployment) file, there are things Eclipse
isn't doing for you possibly as the result of a bug (or so another
poster here suggested). You might find yourself having to disassociate
then readd the project to the server and/or Clean then re-Publish.
Anyway, that's what I've had to do.
I'm sorry to say this without being able to give specifics right now. I
am in the process of putting together a tutorial explaining it and am
just about to write the servlet part at which point I'll be tackling
this and I'll try to nail down and write up just what's amiss. I'm
answering you in hopes of giving you a little bit more leg up on this
precisely because you say you're new to Eclipse (as am I).
The temporary home for my emerging tutorial is
http://www.windofkeltia.com/j2ee/wtp-tutorial.html. I've only just
finished the JSP level; next comes the servlet.
Russ Bateman
Re: PermGen space [message #210056 is a reply to message #210017] |
Sun, 09 March 2008 10:45  |
let me ask 1 last small question : it is indicated in the book that once
you install all WTP components, you should have in views a tab for Data
which contains 2 branches 1 - DataBase explorer 2- Data output which is
not the case in my IDE, I dont have Data in my "other views".
Also, it indicates that we can use SQL Scrapbook editor which I dont have
neither
FUDForum. Page generated in 0.12209 seconds
