Home » Modeling » GMF (Graphical Modeling Framework) » how to use java( or ocl if is possible) for a link constraint in gmfmap
how to use java( or ocl if is possible) for a link constraint in gmfmap [message #209532] Sun, 26 October 2008 12:05 Go to next message
Originally posted by: mattia.lambertini.studio.unibo.it
I have an Element TProcessor and an element that rappresent a link
TEdge. TProcessor have an attribute type and depending on the value of
type the number of outgoing and ingoing edge( of type TEdge) is different.
How can i write a link constraint that solve my problem?
Re: how to use java( or ocl if is possible) for a link constraint ingmfmap [message #209595 is a reply to message #209532] Mon, 27 October 2008 07:52 Go to previous messageGo to next message
Hello Mattia,
Try link source(/target) constraint (OCL) like:
self.outgoing->size() < (if self.type = <desiredType1> then <x> else if self.type
= <desiredType2> then <y> else <z> endif)
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraint ingmfmap [message #209652 is a reply to message #209595] Mon, 27 October 2008 17:27 Go to previous messageGo to next message
Thank a lot Alex! That's what I need! But know I have another problem.
The TProcessor's type is not a simple type but a complex TProcessorType
type. How can I specify the desiredType?
I don't understand how I can do something like self.type =
TProcessorType.Start
I tried: self.type = 'Start' and self.type = 0 but they don't work.
If help I post two little piece of my ecore.
This is the attribute type of TProcessor in the ecore file:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
eType="#//TProcessorType"
unsettable="true">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="attribute"/>
<details key="name" value="type"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
And this is the TProcessorType in the ecore:
<eClassifiers xsi:type="ecore:EEnum" name="TProcessorType">
<eAnnotations
<details key="name" value="TProcessorType"/>
</eAnnotations>
<eLiterals name="Start"/>
<eLiterals name="Simple" value="1"/>
<eLiterals name="Par" value="2"/>
<eLiterals name="Join" value="3"/>
<eLiterals name="JoinWT" value="4"/>
<eLiterals name="And" value="5"/>
<eLiterals name="JoinPar" value="6"/>
<eLiterals name="JoinWTPar" value="7"/>
<eLiterals name="AndPar" value="8"/>
<eLiterals name="SimplePar" value="9"/>
<eLiterals name="JoinSimplePar" value="10"/>
<eLiterals name="JoinWTSimplePar" value="11"/>
<eLiterals name="AndSimplePar" value="12"/>
<eLiterals name="Incoming" value="14"/>
<eLiterals name="End" value="15"/>
</eClassifiers>
Alex Shatalin wrote:
> Hello Mattia,
> self.type = <desiredType2> then <y> else <z> endif)
> Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraint ingmfmap [message #209660 is a reply to message #209652] Mon, 27 October 2008 23:20 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Mattia,
The syntax for enumeration literals is like this:
self.type = TProcessorType::Start
Christian
> unsettable="true">
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
>> Hello Mattia,
>> if self.type = <desiredType2> then <y> else <z> endif)
>> Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209693 is a reply to message #209652] Tue, 28 October 2008 06:40 Go to previous messageGo to next message
Hello Mattia,
try "TProcessorType::Start" or (even better) "<modelPackage>::TProcessorType::Start"
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209735 is a reply to message #209693] Tue, 28 October 2008 11:46 Go to previous messageGo to next message
It doesn't work! If i only type this test: self.type =
TProcessorType::Start or self.type = process::TProcessorType::Start it's
always false.
Is there a way to see the value(what is) of self.type and
process::TProcessorType::Start on runtime? like a log.
Or something like an interpreter to use for testing my ocl code on my
model? Something that tell's what i am wrong.
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209743 is a reply to message #209735] Tue, 28 October 2008 12:31 Go to previous messageGo to next message
I discovered the Error Log window :).
If i i write an ocl test like:
the error is:
Expression problem:Unrecognized variable: (type)body:self.type =
and for this test:
self.outgoing->size() < 5
the error is:
(outgoing)body:self.outgoing->size() < 5
it don't find type and outgoing, but i am sure that type exist. Any idea?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209749 is a reply to message #209743] Tue, 28 October 2008 13:04 Go to previous messageGo to next message
Hello Mattia,
> idea?
Is it a LinkMapping.creationConstraints.sourceEnd/targetEnd constraitn or
LinkMapping.DomainSpecialization ?
(first option is correct).
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209758 is a reply to message #209743] Tue, 28 October 2008 13:06 Go to previous messageGo to next message
Hi, Mattia,
Probably, then, the constraint is defined on the wrong EClass? What is
your context EClass? (the type of "self") It seems clear that the
context EClass does not have a "type" attribute.
To test OCL expressions on your Ecore model, you will find the
Interactive OCL Console example very helpful. Install it from the MDT
OCL component's examples feature. It adds a menu action to Ecore and
UML editors that opens the OCL console. A quick guide to using it is in
the OCL SDK help documentation.
MDT OCL also provides tracing options for parsing and evaluation; see
the Tracing tab in the Run launch configuration dialog.
HTH,
Christian
> the error is:
> and for this test:
> the error is:
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209771 is a reply to message #209749] Tue, 28 October 2008 13:39 Go to previous messageGo to next message
> Hello Mattia,
>> idea?
> or LinkMapping.DomainSpecialization ?
> Alex Shatalin
I think the first but maybe i am wrong. I do link mapping -> link
constraint -> source end constraint.
If i write: self.name = 'zio'
and i set 'zio' as name in my element all work!
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209778 is a reply to message #209758] Tue, 28 October 2008 14:01 Go to previous messageGo to next message
Hi Christian,
My context Eclass is TProcessor class. surely there is an error in
something that i do but as you can see in this piece of my ecore there
is an attribute type in that class:
unsettable="true">
<eAnnotations
</eAnnotations>
the whole TProcessor element in my ecore:
<eClassifiers xsi:type="ecore:EClass" name="TProcessor"
eSuperTypes="#//NodesType">
<eAnnotations
<details key="name" value="TProcessor"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference"
name="cancellationArea" eType="#//TCancellationArea"
containment="true" resolveProxies="false">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="cancellationArea"/>
</eAnnotations>
name="processLogic" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String">
<eAnnotations
<details key="name" value="processLogic"/>
</eAnnotations>
name="sourceAndEdgeId" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//IDREF">
<eAnnotations
<details key="name" value="sourceAndEdgeId"/>
</eAnnotations>
name="supportedEvents" eType="#//TEventType"
unsettable="true">
<eAnnotations
<details key="name" value="supportedEvents"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="th"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Integer">
<eAnnotations
<details key="name" value="th"/>
</eAnnotations>
unsettable="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
thank a lot for this information!
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209785 is a reply to message #209771] Tue, 28 October 2008 14:17 Go to previous messageGo to next message
Hello Mattia,
This is a right type of constraint.
then try self.type = process::TProcessorType::Start
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209792 is a reply to message #209785] Tue, 28 October 2008 14:50 Go to previous messageGo to next message
it doesn' work. But maybe the problem is that in my link mapping the
source feature is a Connection.source:TProcess. Where TProcess is a
superclass for TProcessor. In TProcess there isn't the attribute type.
Is it the problem?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209815 is a reply to message #209792] Wed, 29 October 2008 04:42 Go to previous messageGo to next message
> Is it the problem?
I saw that self is considered only a TProcess and so i can access only
its attribute.
There's a way to cast self into another type in ocl? If there isn't, I
can write the constraint in java, right? Optionally i can do this into
the java classes. Which classes i have to touch?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209820 is a reply to message #209815] Wed, 29 October 2008 05:16 Go to previous messageGo to next message
I solved using
self.oclAsType(TProcessor).type = process::TProcessorType::Start
Thank for the precious help till now!!
I have another problem, if i want to set the max number of link that an
element can have i have to write:
self.oclAsType(TProcessor).outgoing->size() < 2
but outgoing doesn't exist. What's outgoing?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209821 is a reply to message #209820] Wed, 29 October 2008 05:32 Go to previous messageGo to next message
Hello Mattia,
I suppose TProcessor has a back reference enumerating all the outgoing links.
So, "outgoing" in my sample was just an EReference name pointing from TProcessor
to link element - there is no special "artificial variable" pointing to the
outgoing links.
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209844 is a reply to message #209821] Wed, 29 October 2008 08:44 Go to previous messageGo to next message
> links. So, "outgoing" in my sample was just an EReference name pointing
> from TProcessor to link element
How can i do a back reference like that? With an association and the
Eopposite attribute?
thank for the help, Alex
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209846 is a reply to message #209844] Wed, 29 October 2008 09:19 Go to previous messageGo to next message
Hello Mattia,
right.
Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209924 is a reply to message #209846] Thu, 30 October 2008 04:27 Go to previous message
> right.
perfectly! All works now! thank a lot Alex!
best regards,
Mattia
Previous Topic:Mapping in XML Schema.
Next Topic:Regarding Drag and Drop in GMF
Current Time: Tue Jul 22 13:08:49 EDT 2025
Powered by FUDForum. Page generated in 0.06397 seconds
