Home » Language IDEs » ServerTools (WTP) » Page Rendering Puzzle
Page Rendering Puzzle [message #209201] Thu, 28 February 2008 13:27 Go to next message
Originally posted by: gmrenak.topdownsoftware.com
Eclipse 3.3.1.1, Tomcat 5
I'm experiencing puzzling rendering behavior for JSP pages. These JSP
pages have image links and an href link to a certain .css file.
To describe this problem, let me focus on just two jsp pages: page 1 is
the home page at the root level of the Web application, page 2 is
another jsp page that happens to be down one level in a subdirectory off
the root level. Page 1 contains a link to page 2.
If I highlight page 2 within the Web project, then right-click 'Run on
Server', it is rendered correctly (that is, Tomcat seems to have found
the .css file, all linked images, and formatted the page as expected)
Now, if I highlight the project, then right-click 'Run on Server', I get
page 1 (the Web app's home page) rendered correctly (Tomcat found the
..css file and all linked images). However, when I click the link to page
2 from page 1, I find that it's not rendered correctly: as though Tomcat
couldn't find the .css file and linked images for page 2.
The paths to the .css and images are correct for both pages, before and
after rendering.
There must be something fundamental here that I don't understand.
If it matters, besides the HTML, page 2 also contains Struts2 'iterator'
tags.
Gary
Re: Page Rendering Puzzle [message #209252 is a reply to message #209201] Thu, 28 February 2008 20:16 Go to previous messageGo to next message
> after rendering.
> tags.
> Gary
Problem solved, although not yet entirely understood.
I constructed the jsp pages using Dreamweaver, which was configured to
treat paths as 'relative'. So, when I added a link to page 2 (which
resided in a subdirectory off the root directory) for the .css file, for
example, it constructed a link similar to '../css/abc.css', because the
..css file was in a separate subdirectory (css) off the root directory.
It appears, however, that when the jsp page is submitted to Tomcat for
rendering, it treats the submitted page as if it were in the root
directory (even though it resides in a subdirectory off of the root
directory), and so can't find '../css/abc.css'. When I changed the path
to 'css/abc.css' it found the file.
Why would Tomcat do that?
Gary
Re: Page Rendering Puzzle [message #209389 is a reply to message #209252] Mon, 03 March 2008 11:25 Go to previous messageGo to next message
>> is the home page at the root level of the Web application, page 2 is
>> off the root level. Page 1 contains a link to page 2.
>> get page 1 (the Web app's home page) rendered correctly (Tomcat found
>> the .css file and all linked images). However, when I click the link
>> to page 2 from page 1, I find that it's not rendered correctly: as
>> though Tomcat couldn't find the .css file and linked images for page 2.
>> and after rendering.
>> 'iterator' tags.
>> Gary
> Gary
For a "submitted" page in a subdirectory to appear as if it were in the
root of your webapp, it would seem to imply that the page is being
included by some other page, or is being forwarded to. Is this the case?
Larry
Re: Page Rendering Puzzle [message #209709 is a reply to message #209389] Wed, 05 March 2008 15:35 Go to previous message
>>> on Server', it is rendered correctly (that is, Tomcat seems to have
>>> found the .css file, all linked images, and formatted the page as
>>> expected)
>>> 'iterator' tags.
>>> Gary
>> for example, it constructed a link similar to '../css/abc.css',
>> because the .css file was in a separate subdirectory (css) off the
>> root directory.
>> path to 'css/abc.css' it found the file.
>> Gary
> Cheers,
> Larry
I think your insight about '..is being forwarded to' is probably the
solution. Yes, the page is indeed being 'forwarded to' in the sense that
the "result" of a Struts2 action (where the "result type" of the action
is to build a jsp page) identifies the jsp page to be rendered on
Tomcat. So I can surmise that Tomcat can't know about the relative
position of the jsp page when it is "submitted" in this way.
Thanks for your reply.
Gary
Previous Topic:Error "The requested resource is not available" when trying WPT Tutorial
Next Topic:Re: Create new DOM document from XSD schema
Current Time: Thu Jul 24 20:35:03 EDT 2025
Powered by FUDForum. Page generated in 0.03194 seconds
