Home » Modeling » GMF (Graphical Modeling Framework) » GMF and OAW completion
GMF and OAW completion [message #209397] Fri, 24 October 2008 04:31 Go to next message
I would like to have the completion working on the xpand template
contained in the plugin org.eclipse.gmf.codegen.
I have check out the project and tried to put the "templates" folder as
source folder, but this isn't working.
How can I have the completion in these templates ?
My configuration :
- Windows XP
- JVM 1.5.0_13
- Eclipse 3.4.0
- OAW 4.3
- GMF Tooling 2.1.0
- GMF SDK 2.1.2
- GMF 1.1.2
Thibault
Re: GMF and OAW completion [message #209578 is a reply to message #209397] Mon, 27 October 2008 07:15 Go to previous messageGo to next message
Hello Thibault,
AFAIK xpand editor used by GMF is available as a part of "gmf-sdk-experimental"
distribution. In other words, you should have "org.eclipse.gmf.xpand.editor"
plulgin installed as a part of your platform to have it running. All the
other necessary settings are already set for org.eclipse.gmf.codegen, so
if you check out it from CVS you should get it working.
Alex Shatalin
Re: GMF and OAW completion [message #209644 is a reply to message #209578] Mon, 27 October 2008 14:35 Go to previous messageGo to next message
Hello Alex,
thanks a lot, it was that.
I had already tried this editor, but didn't succeed in having the
completion for the path of other xpand files (xpt::diagram::...) and I
didn't try on variables...
Moreover the name of the editor is not very intuitive. I though it was
an older version of the xpand editor... So I didn't test it a lot.
Do you know if the filepath completion is available ?
Thibault
Alex Shatalin a écrit :
> Hello Thibault,
> "gmf-sdk-experimental" distribution. In other words, you should have
> "org.eclipse.gmf.xpand.editor" plulgin installed as a part of your
> platform to have it running. All the other necessary settings are
> already set for org.eclipse.gmf.codegen, so if you check out it from CVS
> Alex Shatalin
Re: GMF and OAW completion [message #209684 is a reply to message #209644] Tue, 28 October 2008 06:37 Go to previous message
Hello Thibault,
AFAIR, not..
Alex Shatalin
Previous Topic:How to get an org.eclipse.gmf.runtime.notation.view from an IResource?
Next Topic:How to set line colour of rectangles in GMF
Current Time: Thu Sep 04 04:51:23 EDT 2025
Powered by FUDForum. Page generated in 0.05804 seconds
