Home » Eclipse Projects » GEF » Only when I deselect the figure, I get the the desired effect :-(
Only when I deselect the figure, I get the the desired effect :-( [message #209297] Mon, 13 February 2006 14:56 Go to next message
Originally posted by: ddv.certi.org.br
The code bellow is suppose to draw this figure
name |
When I change "name" to "n", this is what I get
n |
When I deselect the label, I get the desired behaviour
n |
If I call repaint, the desired behaviour also is achieved.
Any clues to why the horizontal line is wrong, but the vertical is
right? They both share the coordinate that is not working right.
thanks
protected void paintFigure(Graphics graphics) {
Rectangle nameLabelBounds = getNameLabel().getBounds();
Rectangle textBounds = getNameLabel().getTextBounds();
graphics.drawLine(bounds.x, nameLabelBounds.height + bounds.y,
textBounds.width + bounds.x, nameLabelBounds.height + bounds.y);
// repaint(); //XXX ddv solution to substitute repaint();
graphics.drawLine(textBounds.width + bounds.x,
nameLabelBounds.height + bounds.y, textBounds.width + bounds.x,
bounds.y);
Re: Only when I deselect the figure, I get the the desired effect :-( [message #209450 is a reply to message #209297] Tue, 14 February 2006 15:16 Go to previous messageGo to next message
really some strange behaviour.
Check if is not thrown exception. (I presume you have done.)
I can only see problem in draw2d or in bad use of draw2d. Where?
first is painted horizontal line
second is painted vertical line
first is badly drawn and second OK. Why? Maybe after first line is draw, textbounds changes to correct value(by some internal draw 2D update) and second line is drawn OK.
Try to compare textbounds before and after by console or by log or by debugging.
T.S.
Re: Only when I deselect the figure, I get the the desired effect :-( [message #209875 is a reply to message #209450] Mon, 20 February 2006 13:26 Go to previous message
Tryed that, but couldn't find the reason. Went for another solution that
worked for me.
thanks
Tomas Studva wrote:
> T.S.
Previous Topic:Accessibility deviation
Next Topic:How can I slant the figure ?
Current Time: Mon Sep 15 03:53:51 EDT 2025
Powered by FUDForum. Page generated in 0.05735 seconds
