| Server not available on Run on Server [message #209265] |
Fri, 29 February 2008 12:17 |
Originally posted by: javaforyou.gmail.com
Hi all,
I have a customised application server that is created as a plugin and
integrated in the eclipse 3.3.1.1 build 20071023. After installing the
plugin, I can view the app server in the server view. I can select the
server, create a new server instance and also run it correctly.
1) The problem comes when I try to run it on Dynamic web project> Run on
Server; I do not get a option of running it on the existing server. The
dialog box asks me to create a new server instance.
2) If I select the new server (any app server)from the dialog box, and
point the application server directory to the my application server; it
works perfectly fine.
The plugin for the app server was developed and tested successfully on
Eclipse 3.1 with WTP 0.7 version. But on upgrade to Eclipse Europa
(Eclipse 3.3.1 build 20071023), i am facing this problem.
Is it due to the different WTP versions or some configuration files
missing at my end that were required for the Eclispse 3.3 plugin
envoirnment. (PS: I have already checked for the plugin migration guides).
Kindly help me resolve this issue.
Kind regards,
Roshani
FUDForum. Page generated in 0.04068 seconds
