Home » Eclipse Projects » GEF » How can I reverse the direction of the Y axis?
How can I reverse the direction of the Y axis? [message #208925] Thu, 09 February 2006 15:59 Go to next message
Originally posted by: geoff_crowther.uk.ibm.com
BlankIn the GEF examples (e.g. Logic) the origin (0, 0) is at the top right
of the editor window. Positive Y values are below this origin, and negative
Y values are above. Is there any way to change this direction, so that
positive Y is upwards, preferably also changing the default location of the
origin to be the bottom left of the editor window? This would allow the
editor to match the conventional representation of an X,Y coordinate system.
Many thanks for your help.
Geoff Crowther
Re: How can I reverse the direction of the Y axis? [message #208959 is a reply to message #208925] Thu, 09 February 2006 19:53 Go to previous messageGo to next message
GEF is consistent with SWT which is consistent with most OS windowing
systems which use the top left as a anchor for the point system. If you're
relying on some mathematic libraries or something that assumes different, it
should be a simple mapping to achieve the opposite (ViewPort extent - y
coordinate).
Steve.
"geoffc" <geoff_crowther@uk.ibm.com> wrote in message
news:dsga83$pko$1@utils.eclipse.org...
right
negative
the
system.
> Geoff Crowther
Re: How can I reverse the direction of the Y axis? [message #208982 is a reply to message #208959] Fri, 10 February 2006 04:03 Go to previous messageGo to next message
I think good solution is to create such conversion methods. Maybe you find a good class where to place these methods as static. But I think if you subclass yor root editpart, you can change it there and have these coordinates by default.
Tomas Studva
Re: How can I reverse the direction of the Y axis? [message #209045 is a reply to message #208925] Fri, 10 February 2006 10:48 Go to previous messageGo to next message
Rectangle rect = canvas.getClientArea();
Transform t = new Transform(Display.getCurrent());
t.translate(0f, (float)(rect.height - rect.y));
t.scale( 0f, -1f);
gc.setTransform(t);
> right
> negative
> the
> system.
> Geoff Crowther
Re: How can I reverse the direction of the Y axis? [message #210329 is a reply to message #209045] Sat, 25 February 2006 04:50 Go to previous message
Randy
Many thanks for your suggestion. Unfortunately I am new to GEF, and cannot
see where to hook this in to my application which is currently loosly based
on the "Logic" example application. Could you provide a few pointers for
me.
Thanks again
Geoff
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dsicl5$5ei$1@utils.eclipse.org...
> t.scale( 0f, -1f);
> gc.setTransform(t);
> > right
> > negative
> > the
> > system.
> > Geoff Crowther
Previous Topic:grid and background image
Next Topic:TextFlow doesn't return correct height from getPreferredSize()
Current Time: Thu Sep 18 23:31:55 EDT 2025
Powered by FUDForum. Page generated in 0.03875 seconds
