Home » Modeling » GMF (Graphical Modeling Framework) » Arrows/decorations in the middle of a line
Arrows/decorations in the middle of a line [message #208266] Fri, 10 October 2008 08:49 Go to next message
Dear all,
Is it possible to put a shape/decoration in the middle of a line.
We have a suggested notation for a model with a double arrow (kind of
like the christmas tree in the mindmap example (but obviously smaller)
which would need to go into the middle of a line.
Can I set a polyline/polygon figure onto the middle of a connector/line?
e.g. in:
http://wiki.eclipse.org/GMF_Tutorial_Part_2#Graphical_Defini tion_2
"Returning to our graphical definition model (mindmap.gmfgraph), let's
right-click on our gallery and add a 'New Child > Figure Descriptor' and
to it a 'New Child > Polyline Connection'. Name it 'DashedLineOpenArrow'
and change 'Line Kind' to LINE_DASH. Then add a 'New Child > Polyline
Decoration' element to the Figure Gallery and name it 'OpenArrow'. The
default decoration will be an open arrow (while a Polygon Decoration
will be a filled triangle), but if you want to make one explicitly, you
could add three Template Point children to the OpenArrow with X:Y values
of -1:1, 0:0, and -1:-1. Finally, add the OpenArrow as a Target
Decoration to the DashedLineOpenArrow polyline."
All I need to do is to find the middle wrt the X:Y coords & create the
polygon/polyline decoration?
TIA
Adam
Re: Arrows/decorations in the middle of a line [message #208573 is a reply to message #208266] Tue, 14 October 2008 17:29 Go to previous messageGo to next message
Hi Adam,
You will need to get into the code a little. The GMF PolylineConnection
comes from GEF. The GMF Runtime only supports source and target decorations.
Since GEF supports a ConnectionLocator at the source, target and middle, you
should be able to extend the generated code to move the decoration to the
middle.
Cheers...
Anthony
"AdamF" <adam@softfab.com> wrote in message
news:gcnj11$53c$1@build.eclipse.org...
> Dear all,
> We have a suggested notation for a model with a double arrow (kind of like
> the christmas tree in the mindmap example (but obviously smaller) which
> e.g. in:
> default decoration will be an open arrow (while a Polygon Decoration will
> be a filled triangle), but if you want to make one explicitly, you could
> of -1:1, 0:0, and -1:-1. Finally, add the OpenArrow as a Target Decoration
> TIA
> Adam
Re: Arrows/decorations in the middle of a line [message #208818 is a reply to message #208573] Thu, 16 October 2008 06:12 Go to previous message
Adam
Anthony Hunter wrote:
> Hi Adam,
> middle.
> Cheers...
> Anthony
>> Dear all,
>> e.g. in:
>> TIA
>> Adam
Previous Topic:how to add a scrollbar for label
Next Topic:Relationships on Diagram Disappearing
Current Time: Wed Jul 23 23:31:10 EDT 2025
Powered by FUDForum. Page generated in 0.04382 seconds
