Home » Eclipse Projects » GEF » How to set Text in a Shape ?
How to set Text in a Shape ? [message #208591] Tue, 07 February 2006 06:20 Go to next message
Hello
I've been experimenting with the GEF Shape Editor Example.
I want to have Text displayed in the Shape according
to the properties and when the properties have changed the
Text in the shape should have changed. Does anybody
know how i can realize this ?
Thanks in advance for any answer.
Re: How to set Text in a Shape ? [message #208600 is a reply to message #208591] Tue, 07 February 2006 11:06 Go to previous messageGo to next message
Originally posted by: guen.my-lounge.net
Marcel schrieb:
> Hello
to get your figure connected to the eclipse property view try following
steps:
1. the model of the figure must implements IPropertySource
some code example:
public class ClassViewModel extends ModelPropertyChangeSupport
implements IPropertySource {
public static final String PROPERTY_NAME = "Name";
public static final String PROPERTY_NAME_ID = "name";
private String name;
private IPropertyDescriptor[] propertyDescriptor;
public Object getEditableValue() { return this; }
public IPropertyDescriptor[] getPropertyDescriptors() {
if ( this.propertyDescriptor == null ) {
this.propertyDescriptor = new IPropertyDescriptor[ 1 ];
this.propertyDescriptor[ 0 ] =
new TextPropertyDescriptor(
ClassViewModel.PROPERTY_NAME_ID,
ClassViewModel.PROPERTY_NAME );
return this.propertyDescriptor;
public Object getPropertyValue( Object id ) {
if ( id.equals( ClassViewModel.PROPERTY_NAME_ID ) )
return this.getName();
return null;
public boolean isPropertySet( Object id ) {
return true;
public void resetPropertyValue( Object id ) {}
public void setPropertyValue( Object id, Object value ) {
if ( id.equals( ClassViewModel.PROPERTY_NAME_ID ) ) {
this.setName( value.toString() );
this.firePropertyChange(
ClassViewModel.EVENT_PROPERTY_CHANGED,null,null);
2. the model must fire an event for the editpart to refresh visuals
some code example:
public class ClassEditPart extends AbstractGraphicalEditPart implements
PropertyChangeListener {
public void propertyChange( PropertyChangeEvent propertyChangeEvent ) {
if ( propertyChangeEvent.getPropertyName().equals(
ClassViewModel.EVENT_PROPERTY_CHANGED ) ) {
this.refreshVisuals();
protected void refreshVisuals() {
((ClassFigure)this.figure).setName(
(ClassViewModel)this.getModel()).getName() );
anyway, code code examples are on the folowing link
http://www13.plala.or.jp/observe/
even if i couldn't read the descriptions
Christian
Re: How to set Text in a Shape ? [message #208617 is a reply to message #208600] Tue, 07 February 2006 13:05 Go to previous messageGo to next message
I know this tutorial and it is by far the best description
how to implement a GEF Model(apart from the fact that i neither can read it). The refresh of the properties
works well but i can't get text in the Shapes of the
Shape Editor Example. I tried to adapt the code from the side without success.
Re: How to set Text in a Shape ? [message #208642 is a reply to message #208617] Tue, 07 February 2006 13:31 Go to previous messageGo to next message
try to give the figure a label for text
class ShapeEditPart ...
Label label = new Label();
protected IFigure createFigure() {
// add a label for text here
f.add( label );
// set the text here
label.setText( (Model?)this.getModel.getText() );
hope that will help you
Re: How to set Text in a Shape ? [message #208693 is a reply to message #208642] Wed, 08 February 2006 03:11 Go to previous messageGo to next message
I've tried that too but the Label didn't appear.
There is something missing. Maybe you can give me a hint !
Re: How to set Text in a Shape ? [message #208701 is a reply to message #208642] Wed, 08 February 2006 03:15 Go to previous messageGo to next message
I was blind ! One Minute after i posted the previous message
i got the solution. I had to return the label and not the previous figure.... arrgggg.....
Thank you all for your help !
Re: How to set Text in a Shape ? [message #208726 is a reply to message #208642] Wed, 08 February 2006 05:40 Go to previous messageGo to next message
I think i was a little bit to euphoric. Now i get
only the label because i return the label. But if i add the label to the figure it is not visible.
My question now is how i can make the label appear on the figure ?
Re: How to set Text in a Shape ? [message #208776 is a reply to message #208726] Wed, 08 February 2006 10:16 Go to previous messageGo to next message
Originally posted by: ingo.koch[nospam].sap.com
You have to add a layout manager to the figure holding the label. e.g.
XYLayout
"Marcel" <marcel.au@web.de> wrote in message
news:960357.1139395257467.JavaMail.root@cp1.javalobby.org...
Re: How to set Text in a Shape ? [message #208791 is a reply to message #208776] Wed, 08 February 2006 11:30 Go to previous message
Thanks all for the help !
Now it works.
Previous Topic:disable saving for GEF
Next Topic:model objects changing their identity
Current Time: Sat Jul 19 01:03:11 EDT 2025
Powered by FUDForum. Page generated in 0.04629 seconds
