Home » Newcomers » Newcomers » help in java application
help in java application [message #208417] Tue, 01 May 2007 13:27 Go to next message
Originally posted by: avnit_m.walla.co.il
hi!
I am doing a java panel, with text line.
I don't know how to control the size of the text line.
I tried to use setPrefrableSize but it didn't
help.
Thanks in advance.
Re: help in java application [message #208488 is a reply to message #208417] Tue, 01 May 2007 20:04 Go to previous messageGo to next message
Avnit wrote:
> hi!
> help.
> Thanks in advance.
It might help if you could be more specific. Are you using a SWING or SWT?
Are you using a layout? If so, which one? What control are you using? Are
you concerned with (a) the display size of the widget or (b) the number of
characters that can be entered? Answers to these questions might allow
someone to give you some help. HTH. Mark Dexter
Re: help in java application [message #208520 is a reply to message #208488] Wed, 02 May 2007 01:01 Go to previous messageGo to next message
Hi Mark,
Thank you.
In an answer to your qestions: I am using SWT and a Border layout.
I don't think that the control here is relevant,because I am just
interesting in the display size of the Text area.
Can you tell me how to get a smaller Text area?
Thank you in advance.
Avnit.
Re: help in java application [message #208606 is a reply to message #208520] Wed, 02 May 2007 09:53 Go to previous messageGo to next message
Avnit wrote:
> Hi Mark,
> Thank you.
> Avnit.
Are you sure you're not using Swing? I believe a BorderLayout is a Swing
class. If so, here is a link to the Java Tutorials that might be helpful:
http://java.sun.com/docs/books/tutorial/uiswing/components/t extfield.html
HTH. Mark
Re: help in java application [message #208848 is a reply to message #208606] Thu, 03 May 2007 12:09 Go to previous message
thanks Mark.
Avnit
Previous Topic:A little help please
Next Topic:Build with Subclipse, #2
Current Time: Mon Oct 27 03:44:28 EDT 2025
Powered by FUDForum. Page generated in 0.08893 seconds
