Ant in Eclipse 3.1 [message #208230] |
Wed, 29 June 2005 19:00  |
Originally posted by: ray.allthisisthat.com
I installed the new Eclipse 3.1, and have a problem with Ant. I don't
know if it is a twitch in my installation, or a wider problem. Launching
a build file doesn't work, and no output goes anywhere. I was able to
create a "Builder" which runs my Ant build file as part of the Eclipse
build process, and the output goes to the Console View, and everything is
properly executed; but when I launch the Ant Build from the Ant View or
from External Tools, nothing much happens. The only indication that there
is any activity at all is a "jvm terminated" message across the top of the
Console View window. I've been using Eclipse for a couple years, and this
is definitely new behavior.
Any advice?
Ray Clough
ray@allthisisthat.com
Re: Ant in Eclipse 3.1 [message #208434 is a reply to message #208426] |
Fri, 01 July 2005 13:06  |
I asked our IT guys about port restrictions, and they say that there is no
firewall or other restriction on the local machine. Of course, the
corporate perimeter is protected, but not the local machine.
Why does the ant runner use sockets anyway? Seems like a fairly unusual
architecture, but I know nothing about Ant's or Eclipse's architecture.
Two days ago I was using Eclipse 3.0 with it's internal Ant plugin which
used Ant 1.6.2. Everything worked fine. Now, it is very problematic.
FUDForum. Page generated in 0.05008 seconds
