Re: JSF app no longer deploys class files [message #208102] |
Mon, 04 February 2008 12:03  |
Originally posted by: eclipse-news.rizzoweb.com
David Karr wrote:
> I have no idea how it got into this state, but after recreating the
> application from scratch (just copying the source files over after
> creating the skeleton), I see the differences in the metadata files that
> make the difference. In the
> ".settings/org.eclipse.wst.common.component" file, I needed to have the
> following line:
> <wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
> If this happens again, if it's less practical to recreate the project,
> at least I might be able to fix it by adding this line.
> I would think it would be a good idea to document the schemas for these
> metadata files. I couldn't find any documentation on this file, or
> others like it. I'm sure I just didn't know where to look.
Those files are probably not documented; they're not intended for user
modification as they are internal "state" of the WST tools.
Eric
Re: JSF app no longer deploys class files [message #208155 is a reply to message #208124] |
Mon, 04 February 2008 17:35   |
David Carver wrote:
> Eric, I would hope that there is some documentation somewhere about
> those files and what they are used for. Regardless if they are intended
> for user modification or not, documenting the usage of those files is
> important.
This is open source - if the WST development team didn't have reason,
motivation, time,...whatever... to document them, someone will have to
either a) open a bug report asking for it, b) do the work and submit it,
or c) both.
>>> project, at least I might be able to fix it by adding this line.
>>> these metadata files. I couldn't find any documentation on this
>>> file, or others like it. I'm sure I just didn't know where to look.
>> Eric
FUDForum. Page generated in 0.09688 seconds
